Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Tow Rig Forum
Notices
Tow Rig Forum Towing, hauling, boats, campers, trailers etc... Trailer hitches, weight distribution, hitch ball, safety chains, tow bar and brake controllers. Discuss it all here!
Trailer Hub bleeding grease - frustrated
Reply
Thread Tools
Old 05-26-2012, 11:00 PM   #1
Flounder
Elite - Owns 10,000 Marbles
Pennsylvania
Flounder's Avatar
'04 Sport Trac
Vehicle Specs
(Original Poster)
I have a 2010 Sure-Trac 5x10 high side landscape. It has less than 1,000 miles on it. Bought it new.
One of the first times out, I noticed that the left side rim had some grease splatter on it. I wiped it off, towed, and it was back. So, I disassembled, removed the hub, and unpacked everything. The bearings were fine. Before I cleaned it out, it was filled with grease. I replaced the seals with new double walled seals, repacked, reinstalled. I also pumped a few shots into the EZ Lube zerk.
Today I carried a ton of topsoil with it. Got to my destination, and there's the grease again.
What the hell am I missing here? Should I replace the entire hub? I'm out of the warranty period (only one-year on the axle and 3 months on the trailer, for what's worth), and am a bit hesitant to take it to a shop as it's so easy to work on. Of course, if it might be an issue with the axle itself, then I'll have no choice.... probably also just trade it in on something else.
By the way, always, always, always overbuy slightly when looking at a trailer. I went with a fixed bed. It sucks hand emptying any material from it. My next one will be what I was torn to buy before--a 5x10 low riding hydraulic dump. That way I can carry the ATV, materials, and not curse the day when I have to empty it.
Flounder is offline   Reply With Quote
Old 05-29-2012, 06:19 AM   #2
MountaineerGreen
Towing Moderator
North East Arkansas
MountaineerGreen's Avatar
2012 F150 4x4
Vehicle Specs
Is the grease on the inside or outside of the wheel?
MountaineerGreen is offline   Reply With Quote
Old 05-29-2012, 11:03 PM   #3
dkchrist
I am here...I think
Ellsworth, KS
dkchrist's Avatar
'03 Ranger XLT 4x4
Vehicle Specs
The zerk could be bad.
Possibly the hub is overpacked Too much grease will push through seals as it gets hot.
__________________
My 2003 Ranger Deep Blue- My Registry
My Ranger for Sale
Daniel
dkchrist is offline   Reply With Quote
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
Built a utility trailer MountaineerGreen Tow Rig Forum 10 09-25-2011 09:17 AM
auto hub grease?? gogogsr Stock 1991 - 1994 Explorers 4 09-27-2010 02:49 PM
Extended Warranty Repair Quote Advice calylove Stock 2002 - 2005 Explorers 7 08-04-2008 08:19 AM
2002 XLT noticed grease and oil on lt. rear hub raymax Stock 2002 - 2005 Explorers 4 03-04-2008 03:01 PM
Trailer wheel bearings? J. Kennedy Exploring every thing under the sun!! 7 07-13-2004 03:24 PM
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
