#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
1999 Ford Explorer XLT Will NOT START! :(
Reply
Thread Tools
Old 05-31-2012, 10:19 AM   #1
ROBERIZER
Arlington,Texas
99 Explorer XLT 4.0L SOHC
Vehicle Specs
Quoted: 1 Post(s)
(Original Poster)
Hey everyone,
It's been a while... I have a 99 Explorer XLT 4.0L SOHC That will not start! It acts like its not getting any fuel but it has adequate fuel pressure and I can hear the fuel pump running. It has ran just fine and hasn't shown any signs of any problems, but yesterday I got off work and hopped in and it just won't start. It fires, tries to crank but like I said it acts like its getting no fuel. Unfortunately I havent been able to check if it is actually firing or not because its pouring down raining today, but any assistance would be great! I really need to get this thing back up and running.
Thanks,
ROBERIZER is offline   Reply With Quote
( Join the Elite Explorers )
Old 05-31-2012, 10:27 AM   #2
phix-
96.5
Vehicle Specs
Quoted: 2 Post(s)
You more than likely have a clogged fuel filter, you can test this by trying to semi-gently jarring the fuel filter around. For me I used a flat head screw driver and removed it from the bracket. You could also just replace it, but I had this issue and got my truck to start after I mucked with mine. I replaced it right after, also you might want to check your Crank Position Sensor, clean the connections with electronic connection cleaner.
phix- is offline   Reply With Quote
Old 05-31-2012, 10:30 AM   #3
budwich
Ottawa, Ont
96 XL
Vehicle Specs
Quoted: 0 Post(s)
get some quick start and spray it in the intake. That will likely tell you IF it is a fueling issue. You can then go from there as suggested.
budwich is offline   Reply With Quote
Old 05-31-2012, 10:31 AM   #4
ROBERIZER
Arlington,Texas
Vehicle Specs
Quoted: 1 Post(s)
(Original Poster)
Thanks, I will check the Crank Position Sensor and Clean it. I will also try the fuel filter and see if that could be the culprit, but wouldn't that cause me to have no fuel pressure?
Old 05-31-2012, 11:49 AM   #5
jremington59
Watertown, NY
jremington59's Avatar
1997, 99 and 2000 5.0's
Vehicle Specs
Quoted: 142 Post(s)
When you say adequate fuel pressure do you mean tested or just fuel at the rail? Although I assume if it's running the pump tthere's pressure there.
As Bud stated, a 2 second spray of ether into the throttle body will fire it, but don't make a habit of it, lol....
jremington59 is offline   Reply With Quote
Old 05-31-2012, 11:52 AM   #6
05explorer1974
2005 Ford Explorer XLT Sp
Vehicle Specs
Quoted: 0 Post(s)
They did have some fuel pump problems during that time. Does the fuel pump turn on when you the key to the on position?
05explorer1974 is offline   Reply With Quote
Old 05-31-2012, 12:26 PM   #7
ROBERIZER
Arlington,Texas
Vehicle Specs
Quoted: 1 Post(s)
(Original Poster)
By adequate I just meant fuel at the rail. I just assumed if it had fuel pressure at the rail, that the Pump was working. What stumps me is that it was so instantaneous... I would think that if it was an injector clog or something I would have some sign of trouble ahead of time. I also will check the Crank Position Sensor and clean it. Other than replacing the alternator this is the only issue I have ever had with this truck. I have been driving it much harder the past few months though, in comparison to previous years. I have been having to make frequent long distance trips twice a week. Hope this helps explain my situation.
Old 05-31-2012, 12:33 PM   #8
ROBERIZER
Arlington,Texas
Vehicle Specs
Quoted: 1 Post(s)
(Original Poster)
Quote:
I can hear it running but I'm not for sure if it's working.
Old 05-31-2012, 01:29 PM   #9
phix-
96.5
Vehicle Specs
Quoted: 2 Post(s)
Ok, do this. Turn the key 4 times to the "prime" position (this is where the fuel pump whines). Then have your fuel pressure gauge hooked up at the schrader valve (on the fuel rail). Have some crank the motor over and check the pressure, if you did this right there should be 40psi at the rail. If pressure is good, I would bet the fuel filter is clogged. Now you could also have bad injectors but that is a little more rare for all 6 to not work. If there is no pressure when you perform the test, your pump needs to be replaced (if you did not already check the fuel inertia switch in the passenger side).
Why the pump? It may be getting 12v but not supplying between 30-65psi needed to get things started and/or keep them that way.
Old 05-31-2012, 02:02 PM   #10
ROBERIZER
Arlington,Texas
Vehicle Specs
Quoted: 1 Post(s)
(Original Poster)
Thanks for the reply! I will definitely try this. I am hoping it is something simple like the fuel filter, that's for sure!
Old 05-31-2012, 03:00 PM   #11
05explorer1974
Vehicle Specs
Quoted: 0 Post(s)
If you do have to replace the pump also replace the filter at the same time. I agree I doubt all 6 injectors went a once.
Old 05-31-2012, 03:11 PM   #12
ROBERIZER
Arlington,Texas
Vehicle Specs
Quoted: 1 Post(s)
(Original Poster)
Ok, I sprayed starting fluid into the intake and it starts...almost! It dies like it is not getting any fuel so I am under the impression that It is my Fuel filter or pump? I don't have a fuel pressure gauge but I can surely tell the pressure at the rail seems low.
Old 05-31-2012, 07:45 PM   #13
phix-
96.5
Vehicle Specs
Quoted: 2 Post(s)
Once agin, given the amount of effort it will take you or $ to pay someone to do the fuel pump is greater than trying to replace your fuel filter. If you have never done it before I will advise taking about 2hrs to do it. It CAN be a simple job but it can also have you cursing the truck till you figure out the method of removal for the fuel filter that works for you. You will need a 5/16 quick disconnect tool.
Old 05-31-2012, 08:02 PM   #14
Turdle
Move along people
nothing to see here
Turdle's Avatar
2000 Mounty
Vehicle Specs
Quoted: 647 Post(s)
Does the theft light flash while cranking the engine over?
__________________
Jon
9 mile skid, on a ten mile ride. Hot as a pistol but cool inside.
2000 Mountaineer
1998 Mountaineer "Turdle"-gone
1993 Convertible "Vitamin D Wagon" Sold also
Turdle is offline   Reply With Quote
Old 05-31-2012, 08:17 PM   #15
2000StreetRod
Greenville, SC
2000StreetRod's Avatar
00 Sport FI,03 Limited V8
Vehicle Specs
Quoted: 45 Post(s)
Ford Explorer Engine No Start Procedure
2000StreetRod is offline   Reply With Quote
Old 06-01-2012, 03:24 PM   #16
ROBERIZER
Arlington,Texas
Vehicle Specs
Quoted: 1 Post(s)
(Original Poster)
Quote:
Originally Posted by 2000StreetRod View Post
Thank you for this resource!
Old 06-04-2012, 09:40 AM   #17
ROBERIZER
Arlington,Texas
Vehicle Specs
Quoted: 1 Post(s)
(Original Poster)
*UPDATE*
Ok, Friday after work I pulled the gas tank and installed a new fuel pump and filter.
Upon completion the old Explorer was running like a top! I drove a good 45 miles Saturday to see my Family, drove back home Sunday, no problems.
I got in the car to come to work this morning... WONT START! It is once again acting like it is getting no fuel!
It may just be circumstantial but I can here an odd "clicking" sound every 2 to 3 seconds coming from the front and rear of the vehicle even when the key is off. I have never heard this before.
Old 06-04-2012, 09:46 AM   #18
phix-
96.5
Vehicle Specs
Quoted: 2 Post(s)
Could be the relay under the hood on the driver side. You can try jumping it with a screwdriver or checking with a volt meter while some cranks the motor. I forget the voltage your supposed to see. I look around see if I can find the procedure.
Old 06-04-2012, 11:29 AM   #19
budwich
Ottawa, Ont
96 XL
Vehicle Specs
Quoted: 0 Post(s)
Quote:
Originally Posted by ROBERIZER View Post
*UPDATE*
I think that's one of those jokes about "what's that noise" related to the guy with the chain saw complaining to the store that it took too long to cut a tree down.... you know the rest I hope... :-)
Anyways, you got it in a no start condition again :-( get your meter out and check the voltage going to the pump at your inertia switch (its the easiest place)... confirm the voltage. Then as a last attempt, run a 12v wire directly to the pump, it should run "forever"... don't drive with this, just see if it starts. Go from there.
Perhaps your connection at the fuel pump are loose... :-(
Old 06-04-2012, 03:06 PM   #20
bobflood
Powder Springs, GA
1997 Eddie Bauer V8 2WD
Vehicle Specs
Quoted: 89 Post(s)
*UPDATE*
When you say you replaced the "filter" - do you mean the round cannister filter inside the frame rail under the driver's door?? Or do you mean the sock on the end of the fuel pump? If you didn't, you really need to change the external filter.
__________________
1997 Ford Explorer, Eddie Bauer, 5.0L V8, 2WD, 285K+ miles, starting to show its age!
bobflood is offline   Reply With Quote
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
2011 + Explorer TSB's JDraper Stock 2011 - 2016 Ford Explorer Discussion 22 11-10-2015 09:18 AM
97 ford explorer XLT wont start sometimes?? tosh Stock 1995 - 2001 Explorers 0 06-27-2009 04:49 PM
98 Ford Explorer XLT being a pita to start HELP!! :) thanks! quasarsky Under the Hood 1 06-26-2006 01:34 PM
1999 Ford Explorer XLT questions 99FEXLT Stock 1995 - 2001 Explorers 8 01-02-2006 11:38 PM
2002 Explorer: Many refinements and new devices Rick Auto Industry News 2 03-08-2004 02:26 PM
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
