Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1991 - 1994 Explorer Ranger Navajo 1st Generation > Stock 1991 - 1994 Explorers
Notices
Stock 1991 - 1994 Explorers For questions related to the base Ford Explorer. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. No modification questions.
Torque converter drain plug.
Reply
Thread Tools
Old 06-03-2012, 12:15 AM   #1
Naumann
Chula Vista,CA.
91 Ranger 4.0 Auto
Vehicle Specs
(Original Poster)
[SIIZE="4"][/SIZE] I just joined. I'm in the process of changing the transmission fluid in my '91 Ranger 4.0. I got the pan drained, but now I have to drain the torque converter. I can't find the drain plug on it. I pulled the starter and used a screwdriver to rotate the flywheel, but the plug isn't there. Do any of you know where the plug might be located on this transmission? The manual says there is an access plate on the lower left hand side, but I can't find it.
Thanks in advance.
Naumann
Naumann is offline   Reply With Quote
Old 06-03-2012, 12:25 AM   #2
rhauf
Ca
rhauf's Avatar
'93 and '91 explorer
Vehicle Specs
you know come to think of it, i don't recall ever seeing a drain plug on a4ld torque converters... looks like you'll just have to turn a blind eye to the fluid trapped in the converter.
__________________
Check out my Youtube page, many explorer and 4wheelin' videos
http://www.youtube.com/user/rhauf1
rhauf is offline   Reply With Quote
Old 06-03-2012, 02:42 PM   #3
arco777
Anchorage, AK / Little Rock AFB, Arkansas
arco777's Avatar
2x 1994 4x4
Vehicle Specs
Welcome to the forum!
There may not be a drain plug. I seem to recall talk of Ford "cheaping out" and not adding a drain plug to these TCs.
You could do a complete trans flush, or just change the fluid in the pan a couple times and call it good.
__________________
-1994 Explorer 2DR 4x4 - EE swaybars/shocks, Optima Yellow Top, modified throttle body, exhaust, intake. Paxton supercharger on the workbench...
-1994 Explorer 4DR 4x4 - exhaust, brush guard, modified throttle body, intake, 2" lift, 31.5" tires on 16" Sport Trac wheels.
-1989 Taurus SHO
-2008 Mustang GT Bullitt #5560 - Tuned
arco777 is offline   Reply With Quote
Old 06-03-2012, 08:02 PM   #4
rhauf
Ca
rhauf's Avatar
Vehicle Specs
or you could do it the really lazy way like i do... remove a trans cooling line (place end in bucket) start engine and let it run until the trans fluid all pumps out (but not any longer!)
works great and you don't have to drop the pan and get an ATF shower.
__________________
Old 06-03-2012, 11:50 PM   #5
Naumann
Chula Vista,CA.
91 Ranger 4.0 Auto
Vehicle Specs
(Original Poster)
rhauf:
I agree with you that there may not be a plug in the converter. Your suggestions for putting the hose in a bucket and running the engine sound good. However, my dilemma is knowing which line goes back to the transmission. Is it the top or bottom line? Do you know which line it is? Thanks!
Naumann
Old 06-04-2012, 01:32 AM   #6
wood1
North of Ottawa
wood1's Avatar
'93 XLT, Cayman Green RIP
Vehicle Specs
Top line on the transmission is the return, there is no drain plug on the converter.
I changed my fluid by letting it drain into a bucket and filled the pan through the dipstick tube as it pumped out the old fluid. I didn't let it run dry, didn't think that would be a good idea. Let it pump until it runs clean, adjust the level and you are good to go.
__________________
Ribs. I had ribs for lunch, that's why I'm doing this.
List of useful TTB Threads
wood1 is offline   Reply With Quote
Old 06-05-2012, 11:15 PM   #7
rhauf
Ca
rhauf's Avatar
Vehicle Specs
Quote:
Originally Posted by Naumann View Post
rhauf:
Naumann
yeah as wood said, top line returns to the trans.
so pull off the bottom line, put a short piece of old scrap garden hose over it and put the other end of the garden hose in the bucket. thats the easiest way.
remember almost all radiators pump the fluid from the bottom, to the top.
__________________
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
EEC-IV 2 and 3 digit trouble codes. BrooklynBay EEC IV 16 03-26-2012 09:46 PM
2011 Explorer Video/DVD In Motion Hack superwario 2011 - 2013 Ford Explorer In Vehicle Technology (IVT) Sync, MFT - MyFord Touch 35 08-22-2011 09:01 AM
2002 Torque Converter.. Feedback please bkcjames Stock 2002 - 2005 Explorers 1 10-26-2010 05:42 AM
Best Sealer for T-Case Drain Plug? my98nnj Stock 1995 - 2001 Explorers 3 07-07-2010 09:38 PM
Torque Converter questions??? rickvo Explorer & Ranger Transmissions, Transfer Cases, & Differentials 11 05-07-2006 12:03 PM
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
