EF Swag Store 2013 Ford Explorer Forums Elite Membership Chat Room My Posts Reviews Explorer Photo Gallery
Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
Help Removing Steering Column From Rack & Pinion
Reply
Thread Tools
Old 06-06-2012, 11:51 AM   #1
Chris Harrach
Atlanta, Ga.
'97 Eddie Bauer 4WD
Vehicle Specs
(Original Poster)
Greetings all. Ive been informed that my Rack & Pinion needs replacing. Ive got a new one all ready to go in, but I cant figure out how to get the old rack loose from the end of the steering column. Does anyone know how to disconnect the steering from the old Rack & Pinion? Its located in a very tight space, and I cant see in there to locate or identify anything that looks like its holding it in place. Ive found a lot of great information including videos, showing how to remove the old rack, but nothing showing the location or the technique on how to disconnect this. Very frustrating. Any ideas?? Thanks in advance.
Chris Harrach is offline   Reply With Quote
Old 06-06-2012, 12:19 PM   #2
mr_valingo
rhinelander, wi
'95 sport
Vehicle Specs
There is a pinch bolt just under the joint on the steering shaft. I could get a socket on mine using a swivel and some extensions going right through the front by the power steering cooler
__________________
Custom winch bumper, xcr10 comp winch, tt, xl rear shocks, roof light bar, hella 500ff's, flowmaster 40, diehard platinum, 1354manual, 3" body lift, 31" retreads, air horns, and dual pink carseats dad tested, kid approved
mr_valingo is offline   Reply With Quote
Old 06-09-2012, 10:53 AM   #3
Chris Harrach
Atlanta, Ga.
'97 Eddie Bauer 4WD
Vehicle Specs
(Original Poster)
Quote:
Thanks for the reply mr_valingo . I still had a hard time locating it. So I went to the local Pull A Part , which I like to call my "Automotive Classroom", and found exactly where this pinch bolt was located, and what it looked like. Im hoping it wont be in there too tight when I try taking it out. I'll probably end up taking a lot of surrounding parts loose or off, just to make this as easy as I can. However, I'm still concerned about the steering wheel/column, when I remove the rack. I've read that its supposed to be kept straight and to tie it or secure it with the seat belt or a rope. But would'nt locking the steering wheel in place accomplish the same thing? I'm not thrilled at the thought of ruining the clock spring, during this process.
Old 06-09-2012, 11:11 PM   #4
mr_valingo
rhinelander, wi
'95 sport
Vehicle Specs
No problem. I just replaced the rack, pump, and intermediate shaft so its still fresh in my mind. Here's a link to a helpful thread with some pics.
http://www.explorerforum.com/forums/...d.php?t=150850
__________________
Old 06-17-2012, 01:59 AM   #5
Chris Harrach
Atlanta, Ga.
'97 Eddie Bauer 4WD
Vehicle Specs
(Original Poster)
Rack & Pinion: Mission Complete.
Finally got the rack installed in the truck. Man was that a struggle! (it was just me doing it) It really gave me a fight. All in all it took 3 days to do this in my front drive way. I also replaced the outer Tie Rods while I was at it. I also replaced the Camber/Caster bolts with a kit from Napa Auto Parts, as every place that I went to, to get an alignment prior to this, said that I needed the Camber/Caster Kit to do it. I still dont know why this has to be done in order to get proper alignment. Maybe someone on the forum who knows about this can let me know. But so far so good. No leaks, and the steering wheel is straight for the first time in months
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
Installed rebuilt steering rack and now have odd "drift" Evan6ardner 2001-2005 Explorer Sport Trac 6 04-01-2012 10:42 PM
Grinding, Squealing Steering Column DeadRedF150 Ford Ranger - Mazda B-Series Forum 4 05-26-2009 09:09 PM
How do you remove the steering rack & pinion? fex98 Stock 1995 - 2001 Explorers 6 04-12-2009 08:56 AM
Steering Column Replacement BT Stock 2002 - 2005 Explorers 2 02-02-2007 01:22 PM
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
