| Stock 2011 - 2014 Ford Explorer Discussion 2011 - 2013 Ford Explorer problem solving, maintenance, TSB, service bulletins, owner reviews, specifications, Ecoboost. |
Thread Tools |
#1 |
Wannabe Elite Explorer
Vaughan, Ontario
2011 Explorer
nail in tire - warranty in Canada
My 2011 Explorer, with 15K KM. I am in Toronto.
Just found out there is a nail in the left rear tire, I am wondering if it is covered by warranty. If no, should I go to dealership or Canadian tire to repair it ? What's the best method to repair it, is it patch or plug ? How much should it cost? thanks |
#2 |
Elite Garage Builder
McVeytown, PA
'11 XLT
Unless you purchased a road hazard warranty for the tires, why would it be covered under a warranty?
Plug and patch it. Should cost about $20-30. If it's in the sidewall, the tire is shot, just replace it. __________________ Moderator..Home Improvement/Explorer 911/2011 Explorer Forum You took my breath away....and now I want it back.... '66 Mustang Coupe, '04 Mustang Mach 1, '08 Focus, '11 Explorer XLT "Ex"plorer's: '92 Sport, '94 Sport, '01 XLS Our Crappy Website |
#3 |
Evil Asian
Elkridge, MD
91
no.. just get it fixed.. The warranty probably only covers, tread seperation, out of balance, etc but not roadside damage/debris.
#4 | |
Toyota Highlander Convert
Ottawa, Ontario area
2011 Limited AWD
Quote:
![]() Chances are it is not covered under warranty if it is just something that can be fixed with a plug. Where you take it is up to you. If it is in the sidewall, then the tire will have to be replaced, as JDraper mentioned. Since you don't show which model you have in your profile or in the Vehicle Specs I don't know which tire brand you have on the Ex. Your tire warranty booklet says that Hankook does not cover punctures. I'm sure the other manufacturers listed in it are likely the same. I had a puncture in a sidewall on my '09 Highlander but because I had purchased an extended warranty on the vehicle, the cost was fully covered by it. Peter __________________ Peter Explorer Limited White Platinum Tri-Coat,340A (Rapid Spec 302A).Previous rides;'99 Windstar; '02,'06 & 09 4WD Toyota Highlander Limiteds |
#5 |
SoCal Newbury Park
2006 4x4 XLT 4.6L V8
I have never paid to have a nail removed from a tire.
Most tire shops out here actually do that for free including the tire shop I purchase from.
__________________ James Brantley Gilbert - Country Must Be Country Wide http://www.youtube.com/watch?v=8peBU...feature=relmfu With the aerodynamics of a brick and the fuel economy of the space shuttle it makes me smile and brings the power on. Love it!! |
#6 |
Vaughan, Ontario
2011 Explorer
I went to the delaer, first they wanted to charge $50 for patch and plug, then later on said the hole is too big, and still leak after patching.
Now I have to order a new tire, and they ask for $275 + tax. I assume this is not covered either ? the oem tire is 245/65R17 Goodyear Fortera HL Edition |
#7 | |
2011 Limited AWD
Quote:
Do you have FWD or AWD? There will be some wear on the 3 original tires, and hopefully not too much. Just make sure the new tire is the same as the ones on the Explorer now. I see that Goodyear does offer a Fortera HL (P) tire for sale. Many OEM tires are usually not manufactured to the same standard as the same ones you can buy from a retailer. I looked up the Goodyear Canada site and their tire warranty also does not cover punctures. Good luck. Peter __________________ Peter Explorer Limited White Platinum Tri-Coat,340A (Rapid Spec 302A).Previous rides;'99 Windstar; '02,'06 & 09 4WD Toyota Highlander Limiteds |
#8 |
Vaughan, Ontario
2011 Explorer
Thanks Peter!
Ended up paying $350 to the dealer for tire/labor/tax at a Brampton Ford dealer. I used Bridgestone Blizzard winter tire, as it is the only tire I could find officially supports the new Explorer from the manufacturer's website. Also I only drove 8K on this all season tire, I am hoping it's not too much an issue. |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Need some advice from you guys | Rage1973 | Modified 1995-2001 Explorers | 38 | 02-15-2006 01:52 PM |
| NEVER FORGET | spiper | Exploring every thing under the sun!! | 26 | 02-13-2006 01:59 PM |
| weird PAYPAL email is this real???? | Charlie's_93EB | Exploring every thing under the sun!! | 17 | 01-07-2005 09:23 PM |
| Register here | GJarrett | Offroad 4x4 Runs Planning and Discussion | 2 | 08-29-2003 03:28 PM |
| Thread Tools | |
