Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
Vacuum Hose and Electrical connector ID help
Reply
Thread Tools
Old 06-08-2012, 10:10 AM   #1
Abbondanza
Long Island, NY
1996 XLT 4.0 OHV 170k
Vehicle Specs
Quoted: 3 Post(s)
(Original Poster)
Anyone know what this elbow connector is for? (a sensor?) It is green with a white stripe and exits the wiring harness where the throttle position sensor plug is located (they are actually taped together)..Any help is appreciated
Thanks again!
Abbondanza is offline   Reply With Quote
( Join the Elite Explorers )
Old 06-08-2012, 10:31 AM   #2
BradR
Novi, MI
'99 EX 4.0 OHV
Vehicle Specs
Quoted: 0 Post(s)
this is all from memory, i just chased down a vacuum leak with those hoses you have, if i recall, they're supposed to connect together!
as for the electrical plug #1 is it the level sensor for the washer fluid?
and plug #2 looks like the alternator wire.
now that i look again, in the first pic you have a yellow wire going into red, i don't recall seeing that under my hood?
__________________
'99 Ex XLT 4.0 OHV 195k
'00 Mounty 5.0 175k - SOLD
'00 Ex XLS 4.0 OHV 159k - Sis
'03 Windstar 3.8 - Moms
'02 E-450 6.8 Box - Dads
'04 Silverado 3500 6.0 Utility - Dads
BradR is offline   Reply With Quote
Old 06-08-2012, 11:02 AM   #3
Abbondanza
Long Island, NY
Vehicle Specs
Quoted: 3 Post(s)
(Original Poster)
Thanks figured the intake vacuum one out, the hose coming from the VMV was hidden and the diagram here http://www.explorerforum.com/forums/...43&postcount=3 helped me know to dig it out
Still trying to figure out where the black hose goes from the vacuum valve on the passenger side...
Not the washer fluid plug, that one is still plugged in.
The alternator ground is also already connected.
Thanks
Old 06-08-2012, 12:14 PM   #4
Abbondanza
Long Island, NY
Vehicle Specs
Quoted: 3 Post(s)
(Original Poster)
Any help on this plug would be appreciated
Old 06-08-2012, 01:03 PM   #5
bobflood
Powder Springs, GA
1997 Eddie Bauer V8 2WD
Vehicle Specs
Quoted: 95 Post(s)
Thanks
Is it a vacuum hose?? Black vacuum line goes from the manifold to a vacuum reservoir (looks like a black softball) inside the passenger front fender; second vacuum line leaves the reservoir and goes into the firewall. You have to remove the inner fender liner from below to access the reservoir.
__________________
1997 Ford Explorer, Eddie Bauer, 5.0L V8, 2WD, 295K+ miles, starting to show its age!
bobflood is offline   Reply With Quote
Old 06-08-2012, 02:14 PM   #6
Abbondanza
Long Island, NY
Vehicle Specs
Quoted: 3 Post(s)
(Original Poster)
Quote:
Thanks Bob yes, the one from the vacuum reservoir (black ball) was a vacuum line that needed to connect to the upper intake manifold.
I am currently stuck on this one which was routed closely to the throttle position sensor plug:
Old 06-08-2012, 02:47 PM   #7
bobflood
Powder Springs, GA
Vehicle Specs
Quoted: 95 Post(s)
Sorry - no idea on that one. And I have a 5.0 so I can't even go look.
__________________
Old 06-08-2012, 02:50 PM   #8
Abbondanza
Long Island, NY
Vehicle Specs
Quoted: 3 Post(s)
(Original Poster)
I checked the wiring diagram in chilton's...see no reference to a green/white wire? maybe the color of the stripe faded?
Old 06-08-2012, 03:12 PM   #9
bobflood
Powder Springs, GA
Vehicle Specs
Quoted: 95 Post(s)
Maybe. I looked at on-line wiring diagram. There is a dark green/orange wire that goes to a vacuum switch related to the manual AC system. Seems logical, as this wire is near the AC compressor and throttle body and I think this vacuum switch is related to the "WOT" subsystem. No idea where the vacuum switch is, however. Good luck.
__________________
Old 06-08-2012, 03:31 PM   #10
Abbondanza
Long Island, NY
Vehicle Specs
Quoted: 3 Post(s)
(Original Poster)
Thanks for trying...I see what you mean the diagram I'm looking at has a dark green/orange wire going to the Wide Open A/C cutoff relay.
Hopefully someone with an OHV 4.0 can chime and help.
Old 06-08-2012, 03:49 PM   #11
Dono
V8 Limited and SC 4.0 OHV
Winnipeg, Manitoba
Dono's Avatar
00 Limited V8
Vehicle Specs
Quoted: 462 Post(s)
Is that a push on electrical connector? I have the 4.0 OHV, and I just don't recognize it. I should though, Ive spent enough time under my hood.....
__________________
00 Limited V8 rear mount turbo http://www.explorerforum.com/forums/...d.php?t=388599
and a Rebuilt SC 4.0 OHV.
Dono is offline   Reply With Quote
Old 06-08-2012, 05:31 PM   #12
Abbondanza
Long Island, NY
Vehicle Specs
Quoted: 3 Post(s)
(Original Poster)
Quote:
yes it is, I vaguely remember pulling it from somewheredown behind the power steering pump towards the engine block...I defintely could not see it directly I just leaned in and used my hands as my eyes to get it free. Now I can't reverse the process without knowing what I'm looking for to re-connect...ugh
Old 06-08-2012, 05:56 PM   #13
rickybobby
Battle Creek, mi
'97 XLT
Vehicle Specs
Quoted: 6 Post(s)
that is for the coolant temp sensor for the gauge IIRC
__________________
95 ranger "Wreck It Ranger
97 explorer "Green Bandit"
Quote:
Originally Posted by Joe Dirt View Post
It spatters at both the beginning and end of the stroke. .
Pro, but the dongle I had quit working.
rickybobby is offline   Reply With Quote
Old 06-08-2012, 06:24 PM   #14
Abbondanza
Long Island, NY
Vehicle Specs
Quoted: 3 Post(s)
(Original Poster)
Quote:
do you mean the coolant temp sensor that screws into the thermostat housing? It isn't for that, that one does have an elbow connector, but it has a red wire, and it is already attached on my truck.
Old 06-08-2012, 07:36 PM   #15
gonenuke
Virginia
1999 Explorer XLT SOHC
Vehicle Specs
Quoted: 0 Post(s)
Oil pressure switch maybe, sounds like you pulled it from the right place at least on a SOHC.
__________________
1999 Explorer XLT 4.0L SOHC 5R55E
Mostly all stock but New Moog ball joints,
02 Sport Thermostat Mod, New Valve Body
gonenuke is offline   Reply With Quote
Old 06-08-2012, 07:46 PM   #16
Abbondanza
Long Island, NY
Vehicle Specs
Quoted: 3 Post(s)
(Original Poster)
Quote:
I have a '96 OHV; if there's an oil pressure swtch with a connector like this on mine, I am sure I disconnected it when I installed my new heads.
I'll check into it, thanks for the idea.
***UPDATE: Turns out it was the connector for the oil pressure sender****
Old 06-08-2012, 08:57 PM   #17
rickybobby
Battle Creek, mi
'97 XLT
Vehicle Specs
Quoted: 6 Post(s)
on my 97 OHV it has a square connector, i had to add that style connector for my oil pressure guage mod, but come to think of it the color is about right
__________________
Old 01-19-2014, 05:04 PM   #18
stress301
Port Aransas Texas. Island Time....
01 Exp. xls 175000mi.
Vehicle Specs
Quoted: 0 Post(s)
I have a sohc. On mine it is a small vacuum line that goes on the top of the egr valve to the right of the throttle body.
stress301 is offline   Reply With Quote
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
96 5.0L P0402 but no DPFE Sensor? cbr rob Stock 1995 - 2001 Explorers 32 10-12-2015 11:04 AM
I need help replacing my valve cover gaskets. tommy boy95 Stock 1995 - 2001 Explorers 14 02-06-2015 04:50 PM
Mysterious Vacuum Line / Rough Idle Issue MarVelo Stock 1995 - 2001 Explorers 9 01-03-2011 12:20 AM
Is there a how to on v8 manifold replacement? Mbrooks420 Stock 1995 - 2001 Explorers 19 10-10-2010 07:31 PM
Vacuum leak, what part is this?? monkeydude3 Under the Hood 4 02-08-2005 04:00 PM
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
