| Stock 2011 - 2014 Ford Explorer Discussion 2011 - 2013 Ford Explorer problem solving, maintenance, TSB, service bulletins, owner reviews, specifications, Ecoboost. |
Thread Tools |
#1 |
Wannabe Elite Explorer
Charlotte, NC
2013 Ford Explorer Limite
Weird beeping
Almost every day after I first begin driving I will get a series of quick beeps that last maybe 3-5 seconds. It happens randomly, only once, and within 2 miles of me leaving home. I see absolutely nothing on the console displays...if it was cross traffic alert it should have an alert there. I don't see the red lights flash with the collision warning. I'm thinking maybe it is something with MFT...but I don't know of anything that beeps like that. Like when it finishes indexing music for example? Does anyone have any ideas?
#2 |
Spring, TX
2013 Explorer Limited
Not sure what that could be. I haven't caught ours doing anything like that. Is it something you could catch on video and post?
__________________ We just bought American! ![]() She got the 2013 Ex Meet the Gray Ghost HERE Check out the Gray Ghost on Fuelly.com Average Mileage: 21.3 Best Tank: 26.5 |
#3 | |
Toyota Highlander Convert
Ottawa, Ontario area
2011 Limited AWD
Quote:
![]() Peter __________________ Peter Explorer Limited White Platinum Tri-Coat,340A (Rapid Spec 302A).Previous rides;'99 Windstar; '02,'06 & 09 4WD Toyota Highlander Limiteds |
#4 |
Anaheim, California
11' Explorer
Do you carry anything some what heavy in the passenger seat? Maybe it thinks someone is sitting there and its beeping to remind them to buckle up.
Do you hear anything else? such a voices in your head?
#5 | |||
Charlotte, NC
Quote:
Quote:
Quote:
#6 |
Charlotte, NC
It happened again this morning - within a mile of home. I took video with my phone but apparently it didn't record sound so it is useless...I may try again later with my camcorder. I noticed it went off right as I was slowing down for a car turning...so it is possible it is the collision avoidance system. However, I did not notice the LEDs flash nor did I see any message in the console.
Does anyone know if the LEDs flashing on the HUD should be visible in the daytime, and if there is an additional message on the console screens? |
#7 | |
Shelton, CT
2013 Limited(lemon swap)
Quote:
You can turn off the flashing lights in the settings menu, so it might be turned off, or it doesn't work. |
#8 | |
2011 Limited AWD
#9 |
Anaheim, California
11' Explorer
#10 |
Charlotte, NC
I am pretty confident this is the collision warning system that is beeping. I've never seen the HUD activate. I am hoping it will go off at night to verify but at this point I am pretty sure it is broke. I am going to schedule service to get them to check out the LED module
According to the manual, it should be beep or HUD or both... but there is nothing displayed on the 2 sync screens unlike some of the other systems (cross traffic, etc.) |
#11 | |
2011 Limited AWD
#12 |
Charlotte, NC
No I wasn't referring to the settings...I was referring to alert/notification. Cross traffic will popup something saying a car is approaching, etc. But collision system has no notices. I did already go in the settings and make sure chime and warning are on...but the LED HUD module never seems to activate
#13 | |
2011 Limited AWD
Quote:
![]() In any case your HUD should function if it is set to ON and should be visible even in bright sunlight. Peter __________________ Peter Explorer Limited White Platinum Tri-Coat,340A (Rapid Spec 302A).Previous rides;'99 Windstar; '02,'06 & 09 4WD Toyota Highlander Limiteds |
#14 |
Charlotte, NC
Unless the thing only lights for half a second, it is not functioning even in sunlight. It could be the cable is loose or maybe the module is defective. I notice when I toggle the settings that it does the beep - does it also flash the LEDs? If not then I know of no way to test other than almost rear-ending someone
#15 |
Spring, TX
When it goes off, there is no mistaking it. It is bright, and flashes a good number of times when activating.
#16 |
Charlotte, NC
#17 |
Spring, TX
I would imagine they go through some sort of testing, and LED's tend to be pretty reliable. Something might have been jostled loose during shipping. In any case, I would think it would be a pretty simple fix
#18 | |
2011 Limited AWD
Quote:
Do you still get the 'beeps' when the Collision Warning system is OFF? If, so then that is another issue. Good luck. Peter __________________ Peter Explorer Limited White Platinum Tri-Coat,340A (Rapid Spec 302A).Previous rides;'99 Windstar; '02,'06 & 09 4WD Toyota Highlander Limiteds |
#19 |
Charlotte, NC
I took a look at the service manual. The LED module may be disabled in direct sunlight or if the cabin is too hot in order to protect the LEDs. I do not think that is the problem in my case because I have never seen them go off either. It also says they should briefly illuminate when putting ignition into RUN. Plus you said they will indeed flash when toggling the settings.
The next thing I am going to try to do is check the wiring harness for it. If all looks good I'll take it to Ford since I can't do any of their diagnostics (having the module do a self test, checking the network, etc.) |
#20 |
Shelton, CT
You know it lights up when you start the car, right?
If it doesn't, something is wrong. |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Weird Problem...any ideas? | Lankhimself | Stock 1995 - 2001 Explorers | 12 | 06-26-2008 07:12 PM |
| door speaker problem, really weird | EliteConcept | Explorer Audio & Navigation | 6 | 06-18-2002 10:54 AM |
| Thread Tools | |
