Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Ranger - Mazda B-Series Forum > Ford Ranger - Mazda B-Series Forum
Notices
Ford Ranger - Mazda B-Series Forum Ford Ranger and Mazda B Series forums. The Mazda B2300 B3000 and B4000 are clones of the Ford Ranger, with all systems the same. The only differences are trim and a few body parts. This forum discusses Ford Ranger and Mazda B series specific issues. Owners of the older Mazda B2000 B2200 and B2600 are welcome as well.
Mazda B2500 Overheats During Idle
Reply
Thread Tools
Old 06-27-2012, 08:52 AM   #1
sethmac
Vehicle Specs
(Original Poster)
I have a 1999 Mazda B2500 that is overheating while idling or when the air is on. Just started hitting 104 days here in Texas so I'm sure that isn't helping the situation.
When driving the temp meter is at 50% but when sitting idle the temperature steadily climbs to the red line. I can bring it down by shutting off the air and giving it gas in neutral.
- When I first noticed the problem, the coolant well was dry (I know...just had a baby so I've been a little off my game)
- The fan is mechanical I believe and appears to be running fine.
- The upper radiator hose is firm
- The valve on the radiator cap has some brown residue/liquid dried as if released around it
I'm a novice but can like to do my own repairs. Any advice on where to start diagnosing what is wrong? Should I attempt to flush it or is that mute at this point?
sethmac is offline   Reply With Quote
Old 06-27-2012, 12:58 PM   #2
buckwill
trona calif
1998 sport
Vehicle Specs
cupla things,, first,, i know this isnt the issue but lower rad hose is the one collapses but does so at speed, not at idle but good to check anyway, just buzz it up and watch hose, if it sucks close, replace it, but on to other more likely things, u sed brown residue at rad cap,, that indicates rust,, which sez that your coolant is low or no antifreeze, which suggests that most likely u have rust pooled in block or rad cores plugged,, first thing needed is a good block and rad flush followed by 50/50 coolant,,, check lower hose for rigidity and perhaps boil your thermostat for function, let us know, buck
__________________
if my memory was getting shorter would i know???,, disabled viet vet, retired navy,, 98 exploder sport sohc 4.0,, retired macinist,gas and steam turbine millwright,, ive arrested, stroked twice and i mispell lots,
buckwill is offline   Reply With Quote
Old 06-27-2012, 01:05 PM   #3
sethmac
Vehicle Specs
(Original Poster)
Thanks...finally got it home. I'm loosing coolant but can't tell where yet. Appears to be from the radiator but maybe a hose. Going to inspect further. It only appears to leak when running (not sure if thats relevant)
Thoughts? Approach?
Old 06-27-2012, 01:23 PM   #4
buckwill
trona calif
1998 sport
Vehicle Specs
take the water pump fan belt off,, run it in your drive till its hot watch to see where the waters coming from,, or use pressure pump on rad twster to see where the waters coming from,
__________________
Reply
Tags
idle, overheat, overheating, radiator
Similar Threads
Thread Thread Starter Forum Replies Last Post
Please Help with Rough Idle bpopp Stock 1995 - 2001 Explorers 26 08-22-2009 12:42 AM
Its bad for your car to let it idle in the morning? Chew_12 Exploring every thing under the sun!! 140 03-29-2006 01:07 PM
Raised Idle, still think IAC? Magicfan25 Under the Hood 3 12-26-2001 12:23 PM
98 SOHC wont idle at first start of the day.HELP! Magicfan25 Under the Hood 4 12-22-2001 08:22 PM
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
