Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Ford Explorer Sport Trac Forums > 2001-2005 Explorer Sport Trac
Notices
2001-2005 Explorer Sport Trac All questions related to the 2001-2005 Explorer Sport Trac model.
02 Sport Trac Vibration Problem
Reply
Thread Tools
Old 06-27-2012, 04:58 PM   #1
soracav09
Vehicle Specs
(Original Poster)
I am trying to diagnose the problem with my Sport Trac and I could use some extra input. I have a significant vibration coming from the driver's side front wheel. I don't hear any noise when the car is driving outside the car, however the vibration is bad enough that it is loud inside the cab. Odd thing is that when I make right turns and the vehicle is weighted differently (rolls) the vibration stops until the road straightens or I come out of the turn. The vibration occurs at any speed as soon as the sport trac is in motion. I think it may be the bearing but wanted to see if anyone else had any ideas.
Thanks.
soracav09 is offline   Reply With Quote
Old 06-27-2012, 07:43 PM   #2
roamer37
Lincoln Park Mi.
2003 Sport Trac
Vehicle Specs
Bad Vibrations
Check your inner tie rods they get loose and allow the wheel to shimmy back and forth not a fun thing... Jack it up one side at a time and see if you can shake the wheel left to right with out affecting the other side..
roamer37 is offline   Reply With Quote
Old 06-28-2012, 01:57 AM   #3
05dakotatrac
Ellsworth AFB, SD
05 sport trac 4X4
Vehicle Specs
i had that same issue i made a left turn and it made a thump thump thump similar to a badly warped rotor. i had no typical bearing hum. i replaced both hub bearing assemblies and it fixed the issue.
easiest way to check is jack up one side and grab at 6'o clock and 12'o clock and push in and out if there is movement look around the backside while shaking and see if the ball joints move if they dont then its the bearing, next grab at 3 and 9' o clock shake it bck and forth if it moves then look behind the wheel and check the tie rod ends both inner and outer
__________________
USAF active duty, 2A551 aerospace maintenance
05 sport trac: 4X4, 3.73 LSD, 2" torsion twist, 1.75" add a leaf, 265/75R16 MT, cb radio, overhead console, power mirror w/puddle lamps, 2nd gen radio bezel w/twin fog switch, kenwood ddx419 indash video/nav, factory explorer JBL sub mounted under seat.
ZAPV #26
05dakotatrac is offline   Reply With Quote
Old 06-29-2012, 12:34 AM   #4
LONO100
Bay Area CA
LONO100's Avatar
03 sport trac XLT
Vehicle Specs
roamer just said exactly what i was thinking. check your tie rods. you can do this by jacking up the front and seeing if there is play in the wheel when you give it a good jiggle.
LONO100 is online now   Reply With Quote
Old 07-12-2012, 10:17 AM   #5
soracav09
Vehicle Specs
(Original Poster)
I replaced the front hubs his past weeke and the vibration is gone. Thanks for all the help as for now the ride is smooth and quiet.
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
2003 Sport Trac shifter link problem Smokedawg 2001-2005 Explorer Sport Trac 0 05-15-2012 09:48 AM
2004 Sport Trac Turn Signal problem ve1996 2001-2005 Explorer Sport Trac 1 11-12-2011 07:08 AM
05 Sport Trac brake problem myata92 2001-2005 Explorer Sport Trac 4 02-22-2011 08:01 PM
02 Sport Trac. I'm thinking of putting a 5.0L or a 4.6L in it, and I need help. jbellard 2001-2005 Explorer Sport Trac 12 03-20-2010 09:09 AM
Power Window problem - Sport Trac jmunday23 2001-2005 Explorer Sport Trac 6 11-07-2008 01:58 AM
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
