Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Explorer & Ranger Transmissions, Transfer Cases, & Differentials
Notices
Explorer & Ranger Transmissions, Transfer Cases, & Differentials Transmissions, Transfer Cases. A4LD, 4R70W, 4R44E, 4R55E, 5R44E, 5R55E, M5OD, BW 1354, Control Trac, GEM, AWD. Ford 8.8", Dana 35
M5OD - Rebuild or replace?
Reply
Thread Tools
Old 06-28-2012, 10:56 AM   #1
masospaghetti
2000 Sport, 5M OHV RWD
Vehicle Specs
(Original Poster)
My M5OD is finally getting too crude to shift into first gear to leave it alone, so i'm looking at repairing it. Sometimes it shifts just fine, but sometimes it'll kind of "fall" into gear while grinding, with little resistance. If i leave the clutch depressed for a couple seconds before shifting it seems better but it only happens in first gear.
First off, does this sound like a clutch hydraulic issue? The fact that it's first gear only leads me to believe not.
Otherwise, it appears my options are to rebuild it myself, or replace it myself. Rebuild kits appear to be around $200 - what would be a reputable source of these?
For replacement, www.car-part.com has M5ODs with about 100k miles for $450, and M5OD-HD's for $500 with 64k miles.
Would you trust a junkyard M5OD or HD transmission without overhauling it?
Any insight or comments are appreciated. Thanks all.
__________________
2000 Explorer Sport, 4.0 OHV, straight drive, RWD, 166,000 miles
masospaghetti is offline   Reply With Quote
Old 06-28-2012, 12:37 PM   #2
rickybobby
Exploring Solid Axles
Battle Creek, mi
rickybobby's Avatar
'97 XLT
Vehicle Specs
it sounds like a bad 1-2 synchro, so you dont really need the whole $200 kit. you should be able to get just the syncro kit on ebay
__________________
http://www.explorerforum.com/forums/showthread.php?t=292915
Quote:
Originally Posted by Joe Dirt View Post
It spatters at both the beginning and end of the stroke. .
rickybobby is offline   Reply With Quote
Old 06-28-2012, 02:00 PM   #3
IAmTodd
Johnstown, PA
IAmTodd's Avatar
1994 Explorer XLT
Vehicle Specs
I wouldn't buy a kit until you have the trans out and apart. You need to replace only what is bad. My newly acquired M5R1 has a bad fifth gear (thinking syncro). I'm opting to purchase a newer M5R1-HD as the cost to rebuild a high mileage trans is going to be the same as purchasing a new low mileage unit.
Ultimately it's your call, how experienced you are and how comfortable you are with tearing down the M5R1.
__________________
1994 Explorer XLT | M5R1 swap | 2" Lift | 32" ProComp Mud Terrains
2006 Saab 9-3 Aero | 2.8 Full pressure turbo | 6MT | 280whp/325wtq
IAmTodd is offline   Reply With Quote
Old 06-28-2012, 11:24 PM   #4
4x4junkie
So.Calif.(San Fernando Valley)
'94 Ranger, '90 Bronco II
Vehicle Specs
I would think if the trans is not making any unusual noises (besides the grinding while shifting into gear), no gear whine, bearing racket, etc., a rebuild on it is probably the best plan (gear whine would indicate there is likely damage to the gears & cluster shaft, replacement is likely to be more cost-effective in such cases).
As for junkyard trannys, I would certainly pull the cover on one to inspect it, but if everything looked & felt OK, and the synchro clearances were good, I run it (infact, that's exactly what I did with the M5OD now in my BII. I think I got maybe about 8-10K on it since putting it in. JY claimed it had 123K, but I could've easily mistaken it for one having 50K, it looked pretty good inside. YMMV).
__________________
'90 Bronco II XLT
5" lift (Skyjacker jeep coils), locked D35 & 8.8", 5.13s, double T-case, 35x12.50s & cut fenders
'94 Ranger XLT
6" Skyjacker, ARB D44 front, Detroit 8.8" rear, Atlas 4.3, 33s
4x4junkie is offline   Reply With Quote
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
2000 Explorer SOHC dead - rebuild? replace? gmoore Under the Hood 9 02-04-2010 08:41 PM
A4LD rebuild or replace? ShadowdogKGB Stock 1991 - 1994 Explorers 12 11-06-2007 01:05 PM
when to rebuild or replace nmaineron Explorer & Ranger Transmissions, Transfer Cases, & Differentials 12 12-19-2005 08:19 PM
Define a tranny rebuild... Peter Westling Under the Hood 6 10-25-2005 02:38 AM
Fuel pump rebuild / replace ? G-96XLT Under the Hood 3 09-29-2005 08:41 PM
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
