| Stock 2011 - 2014 Ford Explorer Discussion 2011 - 2013 Ford Explorer problem solving, maintenance, TSB, service bulletins, owner reviews, specifications, Ecoboost. |
Thread Tools |
#1 |
Wannabe Elite Explorer
Vermont
2013 Explorer Limited AWD
TPMS Pairing Method
Hi All. Can somebody direct me to any instructions on how to pair new TPMS sensors with the Explorer? I already have a universal TPMS triggering tool, but I assume the Ex needs to be put into "pairing mode" before it is ready to learn the new sensors? Every car I've had has had a different pairing process, so I'm sure the Ex is a little different. Thanks!
#2 | |
Toyota Highlander Convert
Ottawa, Ontario area
2011 Limited AWD
Quote:
I just have the dealer do it when I swap the All Season and Winter wheels so I'm not sure how they do it. Sorry that I can't help with that bit I'm sure someone will get back to you with the info. Peter __________________ Peter Explorer Limited White Platinum Tri-Coat,340A (Rapid Spec 302A).Previous rides;'99 Windstar; '02,'06 & 09 4WD Toyota Highlander Limiteds |
#3 |
Vermont
The sensors that came on the vehicle are already registered. But my plan is to buy a second set of wheels with TPMS sensors and snow tires so that I can swap them back and forth myself every season.
#4 | |
2011 Limited AWD
#5 |
Vermont
I usually just get a set of alloys from Tire Rack for not much more. They've got 17" alloys for $109 and I think the 18" are just a little more.
#6 |
Nova Scotia
2011 Limited & 2009 EB
I think I saw the instruction on how to put it in "pairing mode" on the Tire Rack website. I was planning to buy the tool from them and I think the instructions were in a manual or something there. (It was several months ago and I haven't gotten around to buying the tool yet. I had the vehicle at the dealer both times I wanted them changed so I got them to do it.)
#7 |
Anaheim, California
11' Explorer
Not sure about the Explorer, but I know on my Expedition, it was a series of brake pumps and key turns in a specific order that initialized the pairing mode.
#8 | |
Vermont
Quote:
http://www.tirerack.com/images/tpms/...lveMounted.pdf |
#9 |
Ontario
2012
when I bought my winter rims I ordered Ford sensors from my dealer parts counter, I gave the guy my VIN number and he ordered me the same frequency sensors as my summer rims. We never had to do any pairing , the truck started up and I drove away like normal.
#10 |
Vermont
That's odd. My Dodge works that way, but everything I've heard about the Ford system is that the new sensors need to be paired. Have you switched back and forth between the wheels in both directions?
#11 | |
2011 Limited AWD
Quote:
![]() I didn't know you could do that. It makes sense that if you can order new/additional sensors with the same frequency that there wouldn't be a requirement to have to do any programing. I'll keep that in mind for future reference. Thanks. Peter __________________ Peter Explorer Limited White Platinum Tri-Coat,340A (Rapid Spec 302A).Previous rides;'99 Windstar; '02,'06 & 09 4WD Toyota Highlander Limiteds |
#12 | |
Ontario
2012
Quote:
I should test one sensor by letting some air out to make sure they are working but I think they are fine as I've never had any warning light come on. |
#13 | |
Vermont
Quote:
It's quite possible that Ford has implemented a full auto-learning function, and I'd be quite happy if that's the case. |
#14 | |
Ontario
2012
Quote:
But I also followed the same procedure for my sister's Ford Edge, we bought the new sensors for her winter rims based on her VIN # and they matched the frequency to the factory ones and hers never had to be paired either. |
#15 | |
Vermont
Quote:
That being said, some cars have the ability to pair with new sensors automatically after driving on them for several miles. My Dodge Journey has this ability. I'm really hoping the Ford does as well. |
#16 |
Ontario
2012
I drive about 3 times the miles that the average driver puts on in a given year, in the the five months I used my winter rims I didn't have any warning light come on. Correct me if I am wrong but if the sensors aren't accepted by the vehicle it would throw a warning light, which then would require them being paired ?.
If you are going to buy sensors either way you might as well try to match up the frequencies. If you are having rims installed at a Ford dealer it probably doesn't matter, but if you are having them installed at an aftermarket tire shop it could save you a few bucks and a reduced trip to the Ford dealer. Just saying. |
#17 | |
Vermont
Quote:
My Dodge shows the tire pressure in each tire, so it's easy to tell when the auto-pairing switches over to the winter wheels. Since the Ford system only activates if a tire is low, that would be the only way to test it. |
#18 | |
2011 Limited AWD
#19 | |
Vermont
Quote:
I'm planning to buy winter wheels, tires, and TPMS sensors from Tire Rack. I'll see if they pair themselves this winter. If not, I'll follow the procedure outlined to pair them to the Ex. Either way, it will be much cheaper than buying them from a Ford dealer. |
#20 |
Vermont
Yeah, that's how most cars work, which is really unfortunate. All cars with TPMS know the exact tire pressure. But there are very few that actually display that info to the driver. It's probably because they don't want to have to use localized receivers to determine which tire is at which location. It's much easier to just report that one of the tires is low and let the driver figure out which one.
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Info On Tire Pressure Monitoring Systems (TPMS) | ExplorerDMB | Ford Explorer - Ranger Tires & Wheels | 110 | 04-21-2013 11:51 PM |
| TPMS or not? | cnsheets | Stock 2011 - 2014 Ford Explorer Discussion | 8 | 10-27-2011 03:49 PM |
| iPhone BT issues - Reverse Pairing | Vic | Stock 2011 - 2014 Ford Explorer Discussion | 2 | 07-26-2011 02:51 PM |
| New wheels for 2010 Explorer, swap oem tpms sensors or need new? | stranger706 | Ford Explorer - Ranger Tires & Wheels | 1 | 01-05-2011 05:14 PM |
| TPMS Woes | MunkeyTX | Stock 2002 - 2005 Explorers | 2 | 11-01-2010 08:48 PM |
| Thread Tools | |
