Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Ford Explorer Sport Trac Forums > 2001-2005 Explorer Sport Trac
Notices
2001-2005 Explorer Sport Trac All questions related to the 2001-2005 Explorer Sport Trac model.
transmission shifting hard why?
Reply
Thread Tools
Old 07-02-2012, 10:14 AM   #1
dasport04trac
tx
2004 ford sport trac
Vehicle Specs
(Original Poster)
Dk Exp transmission shifting hard why?
it all started when my alternator went bad so i park my truck for 2 days with no battery in it after that i got a new alternator i put it in took it for a spin and i notice it is shifting hard it didnt used to do that could it be the computer maybe it reset it self or something ppl told me it might be in limp mode? help i have no idea what else to do im still using my truck but its shifting pretty hard still so if anyone know please tell me.
dasport04trac is offline   Reply With Quote
Old 07-02-2012, 11:48 AM   #2
05dakotatrac
Ellsworth AFB, SD
05 sport trac 4X4
Vehicle Specs
easy way to tell if its in limp mode is get to cruising speed 55MPH or more and if your RPM's are higher than 2000-2500 than your in limp mode
__________________
USAF active duty, 2A551 aerospace maintenance
05 sport trac: 4X4, 3.73 LSD, 2" torsion twist, 1.75" add a leaf, 265/75R16 MT, cb radio, overhead console, power mirror w/puddle lamps, 2nd gen radio bezel w/twin fog switch, kenwood ddx419 indash video/nav, factory explorer JBL sub mounted under seat.
ZAPV #26
05dakotatrac is offline   Reply With Quote
Old 07-02-2012, 12:20 PM   #3
phix-
96.5
Vehicle Specs
Unless your seeing a flashing OD light your not in limp mode. Did you replace the alternator wiring harness when you replaced the alternator? I can speak from experience that when the alternator goes bad its known to take out the 3 prong connector. I would check it out at the very least to see if its melted on the inside and go from there.
phix- is online now   Reply With Quote
Old 07-02-2012, 01:17 PM   #4
dasport04trac
tx
Vehicle Specs
(Original Poster)
ok i dont want to sound like a newbie but the prong connector your talking about are the one to the alternator right on the back of it
Old 07-02-2012, 01:30 PM   #5
dasport04trac
tx
Vehicle Specs
(Original Poster)
and no i didnt replace the wiring harness thank you for helping me i really appreciate it but i do notice when im going at 25 mph it limps like if there a gear broken in the transmission but then again if it was it wouldn't run right well idk a thing i replace the throttle position sensor and now the overdrive doesn't kick in i wonder if its because its a generic brand not the actual one it cost 25 buck at the Napa auto part store and at the dealer they want 75 bucks for it so could that cause my overdrive problem. well idk but this sensor kick in the overdrive when it want to go fast i guess cause when im not flooring it the overdrive kicks in and im like alright it kick it so i floor it and man i can rely feel the power of my truck but when a car gets in my way dam i have to slow down well anyways i forgot i was typing my problem and went into story mode but is cause of that
Old 07-02-2012, 09:38 PM   #6
phix-
96.5
Vehicle Specs
What your describing sounds like a ECC solenoid, I would start with pulling any codes via the OBDII port. Most transmissions shops will hook up and give you an idea of where to start.
Old 07-24-2012, 01:47 AM   #7
dasport04trac
tx
Vehicle Specs
(Original Poster)
the ecc solenoid where is it located hmm... very interesting
__________________
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
Help me please. 89 ranger Explorer & Ranger Transmissions, Transfer Cases, & Differentials 32 02-21-2013 03:51 PM
Manual transmission issue. It's very difficult shifting into gears. Expl0ring Explorer & Ranger Transmissions, Transfer Cases, & Differentials 21 02-08-2012 06:31 PM
ford manufacturer specific codes whale45714 Stock 1995 - 2001 Explorers 0 04-16-2011 10:03 AM
Ford Explorer transmission with a hard shifting problem. wdale Explorer & Ranger Transmissions, Transfer Cases, & Differentials 2 04-08-2011 03:12 PM
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
