Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Ranger - Mazda B-Series Forum > Ford Ranger - Mazda B-Series Forum
Notices
Ford Ranger - Mazda B-Series Forum Ford Ranger and Mazda B Series forums. The Mazda B2300 B3000 and B4000 are clones of the Ford Ranger, with all systems the same. The only differences are trim and a few body parts. This forum discusses Ford Ranger and Mazda B series specific issues. Owners of the older Mazda B2000 B2200 and B2600 are welcome as well.
93' Ranger High Idle Helppppppp!!!!!
Reply
Thread Tools
Old 07-08-2012, 09:21 PM   #1
danny910
Dunn N.C.
93' SPLASH
Vehicle Specs
(Original Poster)
Unhappy 93' Ranger High Idle Helppppppp!!!!!
Idles around 1500 with sitting still but when driven it will be as high as 2100rpm when I go to stop. By the way it is a 4.0 manual 2wd. When I stop & apply brakes fully the rpm falls back to 1500. I haven't found any valcum leaks & the only thing that has been done was a ecu replacement back in Feb. After the ecu replacement it ran great. Really need some help guys.............
danny910 is offline   Reply With Quote
Old 07-08-2012, 10:22 PM   #2
RangerX
Moderator
Elite Ranger
Omao, Kauai
RangerX's Avatar
'93 Ranger XLT 4X4
Vehicle Specs
So there's no missing caps or hoses on the vacuum tree?
__________________
Bill Collins
93 Ranger XLT 4X4
"Beauty is only sheet metal deep."
RangerX is offline   Reply With Quote
Old 07-09-2012, 08:06 AM   #3
danny910
Dunn N.C.
93' SPLASH
Vehicle Specs
(Original Poster)
no none at all.
Old 07-09-2012, 08:57 AM   #4
danny910
Dunn N.C.
93' SPLASH
Vehicle Specs
(Original Poster)
going to try to reset my emc to see if that helps any. will post results
Old 07-09-2012, 09:53 PM   #5
danny910
Dunn N.C.
93' SPLASH
Vehicle Specs
(Original Poster)
reset emc but very little difference
Old 07-09-2012, 10:02 PM   #6
Tbars4
Offroad Moderator
anaheim hills,california
Tbars4's Avatar
95 ranger 4x4/ 91 X 4x4
Vehicle Specs
..You could do a search on here for "Idle" or "High idle" while you wait for someone to answer your question..
__________________
I have Rocks in my head. What's in yours?
'95 ranger xl 4x4 2.3L std cab, 2 sticks Ranger RegistryThe Squirrel
'91 4x4=To much to list, much more to add.. Project "X" and more Pics & Mod's List
How to: Wheels,Tires, & Lifts...
Buy Explorerforum.com Items here
Tbars4 is offline   Reply With Quote
Old 07-23-2012, 05:00 PM   #7
Carguy3J
North East New Jersey
'99 4dr. XLT SOHC A4WD
Vehicle Specs
Try unplugging the IAC valve wire while it is running. If the idle drops , there's your problem. Fords are pretty well known for IAC failures. Don't bother trying to clean it, just get a new one.
I would also check to make sure that your throttle isn't sticking open. The throttle body could be gummed up, or the return springs could be worn and weak. This just happened to my Ranger, and I'll probably be buying a BBK replacement soon.
__________________
1999 Explorer XLT 4dr, 4.0L-SOHC, 5R55E Auto, A4WD
K&N FIPK Cold Air--XCAL3 w/ custom tunes from Henson Performance
On The Way: Gibson Cat-Back,U/D pulley,Professional Products Polished 70mm Throttle Body **Planned soon:80mm MAFS,Removal of the Cats,Electric Fan
Best Time 15.87 e/t @ 86.6MPH in the 1/4
Carguy3J is online now   Reply With Quote
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
Pitman Arm Questions ('93 Ranger 4x4) Carguy3J Ford Ranger - Mazda B-Series Forum 13 08-05-2012 11:35 AM
Can a bad cam sensor cause high idle issues? cconcepts Under the Hood 3 10-18-2009 11:25 AM
93' high idle? lydenw Stock 1991 - 1994 Explorers 1 03-10-2009 08:08 PM
94 Ranger idle high after 50 miles. tradar Ford Ranger - Mazda B-Series Forum 4 02-02-2009 07:10 PM
1994 Ranger 4.0L high idle tugboat94 Ford Ranger - Mazda B-Series Forum 2 01-29-2009 09:02 AM
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
