EF Swag Store 2013 Ford Explorer Forums Elite Membership Chat Room My Posts Reviews Explorer Photo Gallery
Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2011 - 2014 Ford Explorer 5th Generation Explorer > Stock 2011 - 2014 Ford Explorer Discussion
Notices
Stock 2011 - 2014 Ford Explorer Discussion 2011 - 2014 Ford Explorer reviews, problem solving, maintenance, TSB, service bulletins, owner reviews, specifications, Ecoboost.
Anyone running 265/65/18's?
Reply
Thread Tools
Old 07-09-2012, 11:23 AM   #1
iaonbb
Mile High
'11 Explorer XLT
Vehicle Specs
(Original Poster)
Wondering how big I can go without lifting. I know a 265/60 fits but still wanting something a little bigger. There's a lot of space to fill in there IMO.
Thanks!
iaonbb is offline   Reply With Quote
Old 07-09-2012, 12:24 PM   #2
peterk9
Toyota Highlander Convert
Ottawa, Ontario area
peterk9's Avatar
2011 Limited AWD
Vehicle Specs
Quote:
Thanks!
Welcome to the Forum iaonbb.
I assume your OEM tires are 245/60R18.
When changing tire sizes you want to stay within the recommended 3% diameter difference. A 265/65/18 has a difference of 6.31%, more than double what is recommended. Even the 265/60R/18 is over at 3.09%.
You can use the calculator at the following site to check.
http://www.1010tires.com/tiresizecal...?action=submit
__________________
Peter 2011 Explorer Limited White Platinum Tri-Coat,340A (Rapid Spec 302A).
Previous rides;'99 Windstar; '02,'06 & 09 4WD Toyota Highlander Limiteds
peterk9 is online now   Reply With Quote
Old 07-09-2012, 12:40 PM   #3
01STrunner
Reva, Virginia
01STrunner's Avatar
2001 Sport Trac
Vehicle Specs
But that can be alleviated through a module reprogram. Ford can do that for $100
__________________
Here's a link to my Registry
"This hobby begins as a search for the perfect setup, then gradually becomes the never ending discovery of the weakest link."
01STrunner is online now   Reply With Quote
Old 07-09-2012, 12:46 PM   #4
peterk9
peterk9's Avatar
2011 Limited AWD
Vehicle Specs
Quote:
The main concern about going over the limit appears to involve the ability of the brakes to handle it.
The warning that comes up says that exceeding the recommended limit could risk brake failure.
__________________
Old 07-09-2012, 03:59 PM   #5
iaonbb
Mile High
'11 Explorer XLT
Vehicle Specs
(Original Poster)
Yeah I have been checking out the 1010tires calculator. Great tool. I'm not too worried about the speedo being off or the brakes being able to handle it. Just looking for a beefier look. I've had several 4x4's in the past with larger wheel/tire combos and never had any problems. I LOVE the Explorer EXCEPT for the sunken wheels. Just doesn't look right being so wide on top and so narrow underneath. Most likely going with the 265/60's but just wondered if anyone has done the 265/65's with no lift.
Appreciate the responses!
Old 07-10-2012, 08:38 AM   #6
mech
Motorbike
Vehicle Specs
Diameter plays a factor on the increased load on the brakes, but you also have to consider the weight of the tire. Im not sure what tire you are thinking, but A BFG LT tire is gonna be a lot heavier than an equivilant sized all season radial. That extra rotating weight is harder to stop.
Overall though i wouldnt be too worried. Id love to see pictures if you do it.
mech is offline   Reply With Quote
Old 07-10-2012, 09:31 AM   #7
01STrunner
Reva, Virginia
01STrunner's Avatar
2001 Sport Trac
Vehicle Specs
I can attest to the heavier tires being harder to stop, mine are about 15% larger since i went from stock 31s to 35s. But if you just keep that in mind and increase your following distance to offset the extra braking time, the size increase works. It would really set your ex apart from a lot of the new ones.
__________________
Old 07-10-2012, 10:57 AM   #8
peterk9
peterk9's Avatar
2011 Limited AWD
Vehicle Specs
I agree with the last part, but, I would take safety over looks any day.
__________________
Old 07-10-2012, 11:30 AM   #9
01STrunner
Reva, Virginia
01STrunner's Avatar
2001 Sport Trac
Vehicle Specs
How big are the brakes on the 5th gen? I can think of lots of guys running 11" discs with 33s as their DDs. I have had to do a couple quick stops since I put bigger tires on and my 12" front discs and drum rears hailed it down to a stop at a good speed. However After being with the fire department most of my life I can understand any concern for safety.
__________________
Old 07-10-2012, 07:37 PM   #10
VinceL
Spring, TX
2013 Explorer Limited
Vehicle Specs
Now you just sound like an old fart, Peter!
__________________
We just bought American!
She got the 2013 Ex
Meet the Gray Ghost HERE
Check out the Gray Ghost on Fuelly.com
Average Mileage: 21.3
Best Tank: 26.5
VinceL is offline   Reply With Quote
Old 07-10-2012, 07:58 PM   #11
peterk9
peterk9's Avatar
2011 Limited AWD
Vehicle Specs
Quote:
Yup, you got that right Vince. I'm an official old fart. I've gone through all the other stages of life.
It's all downhill from here! Watching all the store flyers now for Senior's Days.
__________________
Old 07-11-2012, 05:24 PM   #12
iaonbb
Mile High
'11 Explorer XLT
Vehicle Specs
(Original Poster)
Very helpful thoughts. I have no problem being extra cautious as I find myself falling intothe old fart category a little more each day!
BTW, I'll be going with the P-metric Revo.
Old 07-11-2012, 05:32 PM   #13
corkey
Elite Canuck, Eh ??
In the Great White North where winter never seems to end ,Ontario,, still ice fishing,,
corkey's Avatar
96xl,99xls,old Rangers
Vehicle Specs
weight is not the only factor gentleman,,
sure a heavier tire will exceed the brakes,
BUT,,
i bigger tire tire will also be further from the center to outside edge thus having more mechanical advantage like a longer lever turning the brake rotor, and overpowering the brakes as well, the combination of the weight and the bigger lever could make trouble pretty fast,,
__________________
Log Roller,, Fox Coilovers 35's and others, ,
Truck of the month
Ranger Of Danger,,,project truck,
also look for Blues Traveller Elite registry, ,
corkey is offline   Reply With Quote
Old 07-11-2012, 07:01 PM   #14
mech
Motorbike
Vehicle Specs
BUT,,
Corky,
Could you please explain your assertion? If you are referring to the additional distance between the axle and the outer circumference of the tire, that has already been discussed. The 3-6% diameter increase that was previously mentioned has covered your concern. If you are referring you additional width creating additional lateral distance from the rotor, then you are incorrect. The additional distance laterally from the rotor is largely insignificant with regards to braking load.
Old 07-11-2012, 07:38 PM   #15
01STrunner
Reva, Virginia
01STrunner's Avatar
2001 Sport Trac
Vehicle Specs
He's referring to our talk about the extra weight of larger tires. We ignored the fact that the radius of the weight is also increased and because torque is a force tangential to a circle you must not only think about the added weight but the fact that the rolling weight has added extra torque due to the larger radius.
__________________
Old 07-11-2012, 10:06 PM   #16
01STrunner
Reva, Virginia
01STrunner's Avatar
2001 Sport Trac
Vehicle Specs
I think the brakes would be fine with that size tire. It's not even a 32. Plus the wider patch on the road will offset some loss in stopping distance.
__________________
Old 07-12-2012, 05:46 AM   #17
mech
Motorbike
Vehicle Specs
Gotcha. I made the mistake of assuming that if additional radius is stated as creating additional load, and additional weight is stated as creating additional load, then it would be self evident to all readers that the combination would also create additional load.
I guess corky wanted to make sure we gentlemen understood that.
I still want to see some photos.
Old 07-12-2012, 05:06 PM   #18
corkey
Elite Canuck, Eh ??
corkey's Avatar
Vehicle Specs
yes Sir,
i looked at this in a strictly engineering point of view, i do also know that tolerance factors are built into most systems, like a possible overage in the addition of bigger tires or heavier tires,,
like a stock brake system will have say a 35 % tolerance to account for weight inside the vehicle with say 4 or 5 people, which adds to the weight of the vehicle loaded, as opposed to with just a driver,, so there is a maximum weight allowed,, which is posted on the door sticker,,
using a heavier tire will decrease allowable interior weight , so yes, you should be safe if you run the bigger heavier tire, but keep the weight inside the Explorer down to say the driver and 1 passenger,,until you also hook up a trailer,,
there are alot of variables in designing a vehicle to take into account, as well as the customer factor, and the possible overloading of the vehicle,,
looking at the variables as you did is commendable , as not most people would,,
hats off to you Sir,,
__________________
Truck of the month
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
Replaced computer, still running rich mupmanyu EEC IV 10 06-16-2008 10:34 AM
91 4.0 running horrible Dannyboy Elite Explorer 911! 5 05-20-2008 11:00 AM
2001 explorer sport running boards question jamienfld Stock 1995 - 2001 Explorers 0 03-10-2008 08:21 PM
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
