Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2011 - 2014 Ford Explorer 5th Generation Explorer > Stock 2011 - 2014 Ford Explorer Discussion
Notices
Stock 2011 - 2014 Ford Explorer Discussion 2011 - 2013 Ford Explorer problem solving, maintenance, TSB, service bulletins, owner reviews, specifications, Ecoboost.
Samsung Galaxy 2 I777
Reply
Thread Tools
Old 07-09-2012, 10:41 PM   #1
Tavin
fORD EXPLORER 2011 XLT
Vehicle Specs
(Original Poster)
I have Samsung G II, and also to connect automatically when entering the vehicle, does not contact pictures, and play music with the phone can not change the songs or the screen or the controls on the steering wheel, with my old Nokia X6 performing these functions, my question is normal that works well with the Galaxy IBS?, someone with experience I could answer that phone?, thanks
Tavin is offline   Reply With Quote
Old 07-10-2012, 08:30 AM   #2
dutchman71
Vehicle Specs
Works fine with my Sprint SII. When it got upgraded to ICS (which I think will be available for you this week) it started working even better.
dutchman71 is offline   Reply With Quote
Old 07-10-2012, 09:43 AM   #3
harlenm
Shelton, CT
2013 Limited(lemon swap)
Vehicle Specs
Just root that puppy and put whatever you want on it. Been running ICS for months.
Contact pictures do not come across, but everything else works fine.
harlenm is offline   Reply With Quote
Old 07-10-2012, 09:46 AM   #4
harlenm
Shelton, CT
Vehicle Specs
Also adding, according to the compatibility chart, there isn't a single phone that works with photo ID's.
Old 07-10-2012, 07:31 PM   #5
VinceL
Spring, TX
2013 Explorer Limited
Vehicle Specs
Quote:
In my THREAD, so far 4 phones do that. I only wish more people took the time to contribute to the thread, it would be much more useful
__________________
We just bought American!
She got the 2013 Ex
Meet the Gray Ghost HERE
Check out the Gray Ghost on Fuelly.com
Average Mileage: 21.3
Best Tank: 26.5
VinceL is offline   Reply With Quote
Old 08-03-2012, 11:29 AM   #6
FordIVTteam
Official Ford Rep
Dearborn, MI
FordIVTteam's Avatar
Ford Explorer
Vehicle Specs
Have you looked at the Compatibility Chart recently, harlenm? There are 40 phones that will show Photo IDs. Here's the link if you want to check it out:
http://www.nsapp.fordtechservice.dea...N_iop_2_00.pdf
Quote:
Hi, Tavin!
Were you able to get your phone working properly? If not, reboot your phone and perform a Master Reset on MyFord Touch. Here are the instructions:
MENU > SETTINGS > SYSTEM > MASTER RESET
Let me know how it goes!
Rebecca
__________________
Ford In-Vehicle Technology Team
p: 800.392.FORD (Prompts 1 then 3)
t: @FordService @Ford
f: facebook.com/FordExplorer facebook.com/Ford
FordIVTteam is offline   Reply With Quote
Old 08-04-2012, 01:08 AM   #7
Tavin
Vehicle Specs
(Original Poster)
Thanks Rebecca, follow the steps recommended and the phone working fine, I'm happy, greetings to all
Old 08-04-2012, 01:31 AM   #8
bluex232
Iowa
2013 Ford Explorer XLT
Vehicle Specs
Rebecca has the Droid Razr always had photoID? I am assuming this means it shows your contacts photo from your phone? I know mine does not do this, I just got the ICS update about a month ago, would I have to delete my phone and re add it to get this to work or should this just automatically work? Also is it common for it to not read text messages most of the time. Mine announces them about 4 (random) days a month, lol. Thanks!
bluex232 is offline   Reply With Quote
Old 08-04-2012, 10:37 AM   #9
bluelion
Spring, TX
2012 EX Limited
Vehicle Specs
I have the S2 and recently got the ICS update...and it will not stop disconnecting /connecting itself from myfordtouch...i have unpaired the S2. And repaired it to sync..i have restarted my phone...and it keeps doing same thing...... It even does the same thing in my wifes focus..... so ill try the master reset ...hopefully that will work.
bluelion is offline   Reply With Quote
Old 08-04-2012, 12:41 PM   #10
bluelion
Spring, TX
2012 EX Limited
Vehicle Specs
Well...i did master reset and my S2 with ICS is still disconnecting on its own
Old 08-06-2012, 12:03 PM   #11
FordIVTteam
Official Ford Rep
Dearborn, MI
Ford Explorer
Vehicle Specs
Glad to hear it!
Quote:
You can try to Reverse Pair your phone (see below) to see if that helps. Since the Razr was only tested with GB, I cannot be sure if ICS has changed any of the compatibilities.
Quote:
I'd like you to try Reverse Pairing as well. Here are the instructions:
  • Go into your Bluetooth Settings on your phone and make sure Discoverable mode is set to always or ON.
  • Touch ADD A PHONE.
  • Touch FIND OTHER DEVICES.
  • When your phone shows up on the MFT screen, select it.
  • Type in the Pass-key of 0000 and touch ENTER.
  • Your phone will now ask you to enter in a Pass-key, type in 0000 and the equivalent of OK.
  • Both devices should now connect to each other.
Keep me posted!
Rebecca
__________________
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
Intel is going to replace the Pentium with the Core 2 Duo. BrooklynBay Exploring Computers!! 8 05-10-2006 12:38 AM
KickerKX1200.1 with 2 Kicker L7 12s Mista808 Explorer Audio & Navigation 23 01-30-2006 02:00 PM
final 2: pirelli's v. yokohama's alphabets13 Ford Explorer - Ranger Tires & Wheels 4 03-09-2003 08:36 AM
2 15w3s, 4 12w3s, or 2 12w7s?? Slick Explorer Audio & Navigation 9 10-31-2002 12:06 AM
Power for 2 hx2's ?? *look*!! Mike Explorer Audio & Navigation 21 10-29-2002 11:55 AM
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
