Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Stock 2002 - 2005 Explorers
Notices
Stock 2002 - 2005 Explorers Questions related to non-modified 2002 - 2005 Explorers and Mountaineers. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. Sport Trac and Sport use the 1995-2001 forum.
Spark Plug Wire Removal Question
Reply
Thread Tools
Old 07-10-2012, 11:31 AM   #1
kruegerk
Portland, OR
2004 Explorer
Vehicle Specs
(Original Poster)
I attempted to change out the plug wires on my wife's 04 last night thinking it should be a 20-30 minute job like any other wires I've changed. Driver's side took 10-mins. I pulled plug boots on the passenger side and then got stuck trying to route the wires and the L shaped shield from around the alternator. After 20 minutes of cutting up the knuckles I put the old wires back on and gave up for the night. It looks like the alternator needs to come off and searching the forum others appear to cut the wires which doesn't seem like the right way to go about this. Does the alternator need to come off or can the old wires be removed without having to remove other parts?
Thanks in advance.
kruegerk is offline   Reply With Quote
Old 07-11-2012, 08:09 AM   #2
juicy-jj
Arkansas
2002 Ford Explorer
Vehicle Specs
Quote:
Thanks in advance.
Bump, I would like to know as well since I am getting ready to replace my plugs and wires on my 2002 X. Speaking of which, are the 2002 Explorers the same when it comes to the plugs and wires as the poster above?
juicy-jj is offline   Reply With Quote
Old 07-11-2012, 03:32 PM   #3
Exproblems
Orchard Park, N.Y.
'05 Explorer XLT 4.0L
Vehicle Specs
Thanks in advance.
If you have the V-6, you'll have to remove the alternator to get them out since cutting up your knuckles hasn't worked for you yet. There is no harm in cutting off the old wires and leaving 3-4 inches of them behind pinched behind the alternator. Won't harm a thing. You then run your new wires over the top of the old and down behind the alternator and then down along side the passenger side valve cover as they would normally be routed. Unless you plan on taking your Ex to some car show in the near future, who cares if a couple of old wire sections no one can see anyhow are left behind? Sure beats taking the belt and alternator off right, just to remove and route new 3 spark plug wires? In the future if you have to replace your alternator, you can remove the old spark wire sections at that time. Just look at your skinned knuckles and the decision should be an easy one for you.
Exproblems is online now   Reply With Quote
Old 07-11-2012, 03:37 PM   #4
Exproblems
Orchard Park, N.Y.
Vehicle Specs
Quote:
The 3rd generation Explorers run in years 2002-2005, so the plugs and wires would run the same for the V-6's or the V-8's, so it depends on what engine size you have. Make sure you post your engine size in your posts, it helps the people who are giving you advice on your vehicles problems.
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
How To: Install Signal Mirrors On 3rd Gen Ex BigRondo Performance Lighting 79 12-11-2012 06:27 PM
Ford triton V8 spark plug removal question dxgmmpa Stock 2006 -2010 Explorers 3 11-15-2011 11:55 PM
spark plug removal alan13henderson UK Explorer Owners Forum 7 08-19-2010 11:34 AM
New HU Install Alternative Method - Front Speaker Bypass zombie_fied Stock 1995 - 2001 Explorers 0 07-09-2010 01:47 AM
Broken Spark Plug Removal Burns Under the Hood 32 04-17-2007 12:45 AM
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
