| Ford Ranger - Mazda B-Series Forum Ford Ranger and Mazda B Series forums. The Mazda B2300 B3000 and B4000 are clones of the Ford Ranger, with all systems the same. The only differences are trim and a few body parts. This forum discusses Ford Ranger and Mazda B series specific issues. Owners of the older Mazda B2000 B2200 and B2600 are welcome as well. |
Thread Tools |
#1 |
Wannabe Elite Explorer
Western North Carolina
'94 Ranger XLT 4.0L 4WD
'94 XLT brakes.
a front brake job was done right before I bought this one. trying to locate a vibration which turned out to be an out of balance and slightly bent r/front wheel I jacked up the front (4wd) to check lateral play and tie rods and behold the hubs were'nt as snug as should be passenger side way loose which I corrected useing on-line info (and experience I did a stint as a VW mechanic many years back) as a guide.
although the brakes are working (maybe not as sharply as should be) the ABS light is on (also Brakelight) and I'm thinking if I've read correctly the bleeding was'nt carried out very well. any brake techs here that could provide info on the light and bleeding front and rear? this set-up is different and newer than anything I've wrenched on. Last edited by Tom Norton; 07-17-2012 at 02:58 PM. |
#2 |
Moderator
Elite Ranger Omao, Kauai
'93 Ranger XLT 4X4
I'm NOT a brake tech, but I have a similar truck (93). Mine has a bleeder valve at an ABS? box tucked inside the driverside framerail roughly below the firewall. To do a full proper bleed, it's RR first, then LR, then that box, then RF and LF.
My year has only rear ABS, so maybe that box only applies to rear ABS? Do you know if your 94 has 4 wheel ABS? __________________ Bill Collins 93 Ranger XLT 4X4 "Beauty is only sheet metal deep." |
#3 |
thanks for the info. no I don't know if my '94 has all wheel abs. I checked the sticker on the door but no 'code' there I could find.
does have both the 'ABS' light in the lower righthand outer edge of the instrument panel and the 'brakes' light behind that on the gauge panel they are both on. |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Brake Problems on 94 Ranger XLT 4.0 | Aloha Ranger 94 | Ford Ranger - Mazda B-Series Forum | 9 | 11-05-2008 12:37 AM |
| 94 XLT wireless distr. install? | exploder~13 | Stock 1991 - 1994 Explorers | 2 | 12-09-2007 11:57 PM |
| Bleeding ABS Brakes 94 xlt | RJSwanson | Stock 1991 - 1994 Explorers | 1 | 08-29-2007 09:56 PM |
| roadtoad59 with 94 xlt electric issues | roadtoad59 | Under the Hood | 0 | 04-11-2007 12:33 PM |
| 96 SOHC XLT All Disc Brakes or? | Mista808 | Stock 1995 - 2001 Explorers | 3 | 10-14-2006 02:11 PM |
| Thread Tools | |
