Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > New Members - Photo Gallery- Explorer Registries - Features - Reviews > New Member Forum
Notices
New Member Forum The place for new members to introduce themselves to our family of Ford Explorer enthusiasts and to ask any questions about the message board software. Welcome aboard!!
coolant fluid leak out back of engine
Reply
Thread Tools
Old 07-20-2012, 10:04 PM   #1
sduran24
denver colorado
2000 explorer xls
Vehicle Specs
(Original Poster)
so my 2000 explorer XLS overheated on my wife today, i went to where she turned it off and noticed it was low on coolant fluid, i filled it up and had her start it and drive home, when we got home it started pissin all over the driveway. i peaked through the wheel well and saw it squirting out the back of the engine, problem is I cant see exactly where it is coming from. Is there a hose that comes out the back approximately where the head meets the block, if not I just hope the block is not cracked in the back. any help will be appreciated
sduran24 is offline   Reply With Quote
Old 07-20-2012, 10:13 PM   #2
swshawaii
Kailua-Oahu, Hawaii
'05 Sport Trac XLS (RWD)
Vehicle Specs
If you have the 4.0 SOHC V6, check the lower thermostat housing for leaks.
Remove the throttle body cover and use a flashlight and mirror. Very common.
http://bengrosser.com/howto/fordthermostat/
swshawaii is offline   Reply With Quote
Old 07-20-2012, 10:28 PM   #3
sduran24
denver colorado
2000 explorer xls
Vehicle Specs
(Original Poster)
thnx
first of all thanks alot. so that is back of the engine? i will look in the morning for sure thanks. what part of Hawaii? My sister lives in Maui.
Old 07-20-2012, 10:44 PM   #4
sduran24
denver colorado
2000 explorer xls
Vehicle Specs
(Original Poster)
it is the 4.0 OHV
Old 07-20-2012, 11:01 PM   #5
swshawaii
Kailua-Oahu, Hawaii
Vehicle Specs
Sorry, not familiar with the OHV. Use the '95-'01 "Search This Forum" box on the right.
Most auto parts stores rent coolant pressure test kits with a fully refundable deposit.
Call around for availability. BTW, I live on the island of Oahu in Kailua. Good luck!
http://www.explorerforum.com/forums/...play.php?f=100
Reply
Tags
back of engine, leaking coolant, overheating 2000 xls
Similar Threads
Thread Thread Starter Forum Replies Last Post
OBD-II Diagnostic Trouble Codes (DTCs) BobWiersema EEC V 8 03-26-2013 10:22 PM
TSB's, Where to get them free? nevr1zenuf Under the Hood 16 11-15-2012 01:30 PM
Pump out all tranny fluid? socci Stock 1995 - 2001 Explorers 8 10-29-2011 11:21 AM
1997 awd: coolant leak at rear of engine? cliche Stock 1995 - 2001 Explorers 4 08-09-2011 06:10 AM
Water leak at back of the engine - FIXED tieoneon Stock 1995 - 2001 Explorers 6 08-01-2008 07:01 AM
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
