| EF Swag Store | 2013 Ford Explorer | Forums | Elite Membership | Chat Room | My Posts | Reviews | Explorer Photo Gallery |
| Elite Explorer 911! 911! is for situations where your truck is currently out of commission and the owner is in a crisis situation. Members will try to answer your questions asap, no time frame is guaranteed. Only Elite Explorers can post new threads in this forum |
Thread Tools |
#1 |
Lemoore CA
91 Navajo X 2
Oil Pan Drain Plug Hole Coiled Out. ( Pics )
Hello everyone,
I think i really messed it up this time. I looked around and couldn't find any information about this happening to another member. nothing fitting this at least. i just wanted to put that forward. I did an oil change a few days ago and noticed that i was leaking a considerable amount of oil. when i checked it out last night ( it was dark ) i saw i was leaking from the plug, it was not seated all the way. so i cranked it down a bit. i moved the truck over to make sure it would not leak in the same spot. When i came home from work today i looked again and sure enough there was a lot of oil on the deck. i crawled under there again and took a closer look in the light. and there was a piece of metal sticking out in between the oil pan and the plug. I took my other vehicle and picked up some more motor oil. i thought nothing of anything other than some debris was stuck. When i got around to doing the oil change it was dark again as you can see in the pics. Apparently i super stripped the oil plug when i reinstalled it. i got the plug out and the metal piece was just hanging there, i grabbed it with the vise grip and pulled.. I have another plug and it wont fit. (from parts engine) Is the coil coming out of there the thread from the drain plug hole. or was it sheered off the plug when i cranked it in? am i screwed? its too late to go to a parts store, and i have a train to catch tomorrow morning. i don't know what to say really. i got to hear another speech from the wife "Every time you go do something that will 'take 10 minutes' it ends up taking two weeks" |
#2 |
Wannabe Elite Explorer
Kailua-Oahu, Hawaii
'05 Sport Trac XLS (RWD)
Appears the threads had been previously damaged and repaired with a Heli-Coil.
If you are not the original owner that's probably what happened. Not a difficult fix providing you have the proper thread tapping tool and the correct parts. Good luck. http://www.google.com/search?q=helic...2&ved=0CEYQsAQ |
#3 |
Florida
2000 Explorer Sport
Ok, sorta on topic, my oil drain plug is stuck on my oil pan (apparently it's somehow formed onto the threads since the pan is aluminum and old), and I was wondering if I took it to a machine shop if they could do something like the helicoil thing rather than having to do a whole engine pull to replace the pan. Thanks
__________________ Sport (That's his name) 2000 Ford Explorer Sport Black / 4.0L V6 OHV / 2wd Automatic. -- Slowly being blacked out..very slowly haha -- Pioneer head unit and speakers -- Pair of Rockford Fosgate 12"s -- Grille Guard -- TT -- AAL -- |
#4 |
Lemoore CA
91 Navajo X 2
i work with heli coils at work. i suspected this was the case (that there was a heli coil in there) i just never seen it used in automotive applications.
its real easy to instal heli coils and it looks like you can buy all the tool / heli coil you need to do it yourself. it pretty much is a coil that fits into the jacked up threads of the oil pan and at the same time creates new threads for another bolt. you can get everything you need for less than 30 dollars. i plan on doing this tomorrow morning if i get the time. if not it will be on Sunday. |
#5 |
Northford, CT
97 Sport
Looks like the helicoil moved out with the plug during the oil change, as an alternative check out Napa and other parts stores. They have various oversize self tapping plus size drain plugs.
#6 |
98 Sport
For those who don't have the owners manual, you can download the owners manual in pdf form at the following link:
https://www.fleet.ford.com/maintenan...ls/default.asp |
#7 | |
Great State of Texas
1999 Sport
Just change the oil pan...
It would appear that you have a 2wd Explorer you can drop the oil pan without doing anything but unbolt the oil pan, the starter and 2 alignment bolts from the back of the block...
You can even use the same oil pan gasket if you are careful... Quote:
__________________ When in doubt, use a bigger hammer! 2008 Dodge Charger R/T 2003 Ford F-150 XLT Supercab 1999 Ford Explorer Sport [new playtoy] 1983 Ford Ranger V8 [soon to be gone] |
#8 |
Lemoore CA
91 Navajo X 2
What i ended up doing was purchasing a tap kit from autozone, its for spark plugs but it comes with new helicoils. Used the tap to widen and rethread the hole and put red locktight on the coil. Screwed in the coil and let it set. Now i can use a bigger oil plug to seal it up. It works.
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Oil pan drain bolt? | diverexplorer | Stock 1991 - 1994 Explorers | 5 | 03-16-2011 10:50 PM |
| Oil drain plug location on '06 Explorer | phillyfan | Stock 2006 -2010 Explorers | 1 | 07-24-2008 06:01 AM |
| Chewed up 02 oil pan drain plug o-ring | TPC11 | Under the Hood | 1 | 07-02-2004 09:17 AM |
| Thread Tools | |
