Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
vacuum regulator?
Reply
Thread Tools
Old 07-27-2012, 05:31 PM   #1
redreatta
Columbus,Ohio
96 Explorer XLT
Vehicle Specs
(Original Poster)
vacuum regulator?
Hello all.
just got my explorer back from the dealer, they replaced the vacuum regulator and as soon as i got in it the a/c will only work on defrost mode only.is there a vacuum line that would have been touched and made it this way?i know it runs off of a vacuum line but are these connected or is this a fluke?
redreatta is offline   Reply With Quote
Old 07-27-2012, 05:33 PM   #2
Turdle
Old and in the way
Humboldt, Kansas
Turdle's Avatar
2000 Mounty
Vehicle Specs
Good call!
http://www.explorerforum.com/forums/...eat+ac+defrost
__________________
Jon
2000 Mountaineer
Turdle-gone
Vitamin D Wagon Sold also
Turdle is online now   Reply With Quote
Old 07-30-2012, 12:12 AM   #3
glockman
Utah
1998 Sport
Vehicle Specs
the easiest way to check is pull the vacuum lines on the passenger side kick panel. Put a vac gauge on the port there and see if you have vac. The most common leaks are in the lines under the hood. Mostly from the vaccum reservior on the passenger side under the air box to the firewall. Hope this helps.
glockman is offline   Reply With Quote
Old 07-30-2012, 12:51 AM   #4
Howard
Moderator
Milton Keynes
Howard's Avatar
1998 SOHC UK SPEC
Vehicle Specs
It sounds like they have plugged the lines in to the regulator the wrong way around. I had this and swapping them over (they are a push fit) solved my problem.
__________________
"Be nice to nerds. Chances are you'll end up working for one." Bill Gates
My Explorer
Moderator : Exploring Computers!!, Computer Gaming, Digital Explorations, UK Explorer Owners
Howard is online now   Reply With Quote
Old 07-30-2012, 10:58 PM   #5
redreatta
Columbus,Ohio
96 Explorer XLT
Vehicle Specs
(Original Poster)
well....went back and they had broken a line by the spark plugs. they fixed at no charge. thanks guys
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
Window regulator replacement Dr_Z Stock 2002 - 2005 Explorers 64 05-08-2013 12:27 AM
How to: Replace Fuel pressure regulator 1995- 2001 Ford Explorer 2nd Gen artgod33 Stock 1995 - 2001 Explorers 1 01-06-2010 04:14 PM
First gen Explorer and others alternator full testing X-North Technician's Tips and Tech 3 08-18-2008 02:36 PM
Vacuum questions Rogers-Explorer Stock 1995 - 2001 Explorers 1 04-01-2007 12:40 PM
Let's Talk Vacuum rjc Under the Hood 6 02-26-2002 10:30 PM
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
