Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Stock 2002 - 2005 Explorers
Notices
Stock 2002 - 2005 Explorers Questions related to non-modified 2002 - 2005 Explorers and Mountaineers. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. Sport Trac and Sport use the 1995-2001 forum.
4.6 Timing Chain repair - 1st time/Newbie Mechanic SUPPORT NEEDED!
Reply
Thread Tools
Old 07-28-2012, 08:06 PM   #1
PrettyAzzNouka
College Point, NY
2002 Explorer LTD 4.6
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Hey guys,
I have a 02 Explorer with the 4.6 (Romeo) motor. It has a right timing chain noise. Either the tensioner or guide either way Im going to replace everything. I see that theres a little opening in the timing cover from where the chain has been hitting it.
I've done some research from the forum, autozone's manual, alldata, and youtube. I feel 80% confident to do this job. By no means am I an experienced mechanic but I can turn a tool or 2. I've gotten my hands dirty for a couple of big jobs on my old cars alone and with help from my buddy.(Motor swaps,HG job, ect) This would be the first major job I will do alone (but with my buddy on standby for advice).
I already have the radiator/consensor moved out of the way
Questions:
I ordered a timing kit with water pump. Should be here next week.
Should I order the valve cover gaskets? I know I need to order the timing cover gaskets as they are unusable.
How can I hold the cams and crank without the OTC holding kit? I really dont want to buy the kit for 100 bucks to use only once fior this job. Money's tight right now. Moving out of state next month!
Can I reuse the crank pulley bolt once its taken off? (Going to use a breaker bar/motor crank trick)
I know the motor should be at TDC if I remove the chain. Never done this before; but from what I know so far is that the copper link of the chain around th smaller sprocket where the crank is should be at the 6 o'clock position. Correct me if im wrong. I'm still learning, forgive me lol
Feel free to chime in with any tips. Im not afraid to tackle this job. This is just the beginning!!!
Thanks!
PrettyAzzNouka is offline   Reply With Quote
( Join the Elite Explorers )
Old 07-28-2012, 08:51 PM   #2
waskly
Crooklyn NY!
Vehicle Specs
Quoted: 4 Post(s)
um
your not taking the heads off.
all you are doing is guilds and tentioner
just lock the chains to the cams, use zip ties, change parts, remove zip ties. dont touch the timing.
also lock the chains around the lower sprocket.
you need the tool to reset timing, if you dont remove the timing, just change guilds.
__________________
Quote:
Originally Posted by imp View Post
How do you get someone's "quote" to become your "signature"? imp
waskly is offline   Reply With Quote
Old 07-28-2012, 10:28 PM   #3
JW
Valencia, CA
JW's Avatar
2003 Limited 4x4 4.6L
Vehicle Specs
Quoted: 3 Post(s)
It's not a terribly difficult job. I have a write-up on how I did it here. I've done this same basic procedure on a 4.6L and a 5.4L that got a double head gasket transplant. I've read that you're not supposed to reuse the crank bolt but I reused mine on both engines. I've never had to crank the motor to break the crank bolt loose.
But, if you're not pulling the oil pan to clear it and the oil pump of debris, you're wasting your time. You'll see in that post that I said I didn't clear the oil pan/pump. My engine blew shortly after I wrote that. Here's the tough part - you have to pull the engine to pull the pan, unless you have a two wheel drive (maybe even then, not sure).
__________________
JW
Ceramic White 2003 Explorer Limited 4x4 4.6L: JBA headers, Steeda underdrive pulleys, K&N FIPK, Cougar/Thunderbird electric fan/Flex-A-Lite Controller
Medium Wedgewood Blue 2004 Explorer XLT 4x4 4.0L Raven Black 1994 Ranger Supercab STX 4x2 4.0L
JW is offline   Reply With Quote
Old 07-30-2012, 09:30 AM   #4
PrettyAzzNouka
College Point, NY
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Ugh, I didn't think I had to drop the oil pan. I read that you should do a low mileage oil change to rid debris if any...
Old 07-30-2012, 09:56 AM   #5
JW
Valencia, CA
JW's Avatar
Vehicle Specs
Quoted: 3 Post(s)
I think it depends on how advanced the guide wear is. In my case, a hundred oil changes wouldn't have made a difference. Maybe wait what it looks like when you get in there.
__________________
JW
Old 08-02-2012, 10:16 PM   #6
jayton
Jefferson, GA
02 XLT V8
Vehicle Specs
Quoted: 0 Post(s)
I didn't realize that. I can confirm however, that 2wd does not require pulling the engine to drop the pan.
Yes get new valve cover gaskets.
The crank pulley bolts are so cheap, why not replace? I've heard stories both ways, some say it is fine to reuse, and some say they have seen them break. I got 3 of them on my last Tasca order just to have lying around.
__________________
jayton
2002 Explorer XLT, 2WD, 4.6L SOHC
1996 Mustang GT, Convertible, 4.6L SOHC (I have two of these)
1993 Grand Marquis
2001 BMW 325i Sedan
jayton is offline   Reply With Quote
Reply
Tags
3rd gen explorer, 4.6, timing chain
Similar Threads
Thread Thread Starter Forum Replies Last Post
SOHC V6 Camshaft Timing 2000StreetRod Under the Hood 35 04-27-2016 06:41 PM
Rear Timing Chain Tensioner Replacement 2000StreetRod Under the Hood 111 02-01-2015 04:09 PM
Clutch replacement and timing chain andre74 Stock 1995 - 2001 Explorers 0 07-10-2010 04:52 AM
Timing chain broke; dealer saying TS. Need some help. Jeff Under the Hood 1 12-02-2001 07:21 PM
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
