Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Projects - Hobbies and Additional Topics > Projects - Hobbies - DIY > Ham Radio - CB - Trail Communications
Notices
Ham Radio - CB - Trail Communications I have found that fourwheeling and ham radio go hand in hand. Post any questions or comments about the great hobby of amateur radio here. Of course CB'ers are welcome also. Ray, AE6H and Joe, N1LVN both moderate this forum.
Antenna question?
Reply
Thread Tools
Old 07-29-2012, 12:09 AM   #1
1996BLKBauer
Harold Tellefsen
McHenry, IL
1996BLKBauer's Avatar
1996 Eddie Bauer AWD V8
Vehicle Specs
(Original Poster)
Question Various questions about CB radios from a noob, help?!?!?
OK, I was just sort of test fitting everything for my CB setup, and I have an older used 4' magnet mounted antenna. I noticed that with the antenna on the roof, that it is not very secure. So I was thinking about just adding some double sided tape around the outter ring of the mount. The magnet is in the center, and it has a plastic chrome piece that surrounds it, with a 1/4" surface all the way around that touched flush with the magnet to the metal on the roof. I know the double sided tape will lift it up slightly, but will this effect anything? I doubled up a rag to act as the tape and it does not seem to effect the magnet strength. but I am new to The whole CB world so I don't want to mess anything up.
__________________
Martha, My 1996 Ford Explorer Eddie Bauer Edition
Upgrades coming along nicely...
-Alpine stereo, with Alpine Doorspeakers and MTX Subs
-15x7 Cragar Soft 8's, On Hankook 235/75R15 Tires
-Upgraded CB Radio soon(Radio Shack Special now)
-POR 15 undercoat(Summer Project)
1996BLKBauer is offline   Reply With Quote
Old 07-29-2012, 08:05 AM   #2
The DB
St. Louis
2000 Limited SOHC
Vehicle Specs
On many magnet mounts the magnet itself is part of the tuning mechanism. Changing the distance between the magnet and the metal can actually throw off the low SWR/resonance point a bit. At the very least you would want to check your SWR's/resonance after the fact.
Also raising the magnet the strength will be affected. You may not notice it but when (not if) it hits something it will be easier to knock over.
What kind of antenna is this? Chrome on an antenna is a bad idea. I hope its not on any of the radiating components.
Also, since your new to "The Whole CB world" I suggest picking up the antenna and cleaning between the magnet and roof about once a month. You want to use a wet rag, and make sure both surfaces are dry when you put the antenna back on.
The DB
The DB is offline   Reply With Quote
Old 07-29-2012, 07:05 PM   #3
rizzjc
Scubajoe - Radio Mod
Garner, NC
rizzjc's Avatar
'97 AWD V8 XLT
Vehicle Specs
I'd be surprised if you lost the antenna due to the magnet, unless you actually hit something. Most of the magnets I've seen are pretty strong, and hold very well when used with the antenna it was designed for.
__________________
Joe, N1LVN
'97 XLT AWD V8 STOCK
Amsoil Synthetics throughout. Amsoil Ea air filter. Bilsteins. Scanguage.
Search ExplorerForum
rizzjc is offline   Reply With Quote
Old 07-29-2012, 08:45 PM   #4
1996BLKBauer
Harold Tellefsen
McHenry, IL
Vehicle Specs
(Original Poster)
I'll have to take some pictures and show you what I have. I am glad I asked before I did anything. This is a one of those situations where I always wanted a CB in my truck, and then my friend just happen to have an extra radio, and antenna for me. Since they are both used, that are not in perfect shape, but work good enough for me. If anything this antenna would be just a short time use, I really want to do a dual whip setup off the rear lights, but I need to find a length that will work for drive thrus, and that I can good range with.
A very basic, and most likely bad representation of the magnet setup on my antenna.
Also since I am new, and don't want to make anybody mad, how do you tune a CB? I am sure this is a very stupid question, but like I said I am very new to this, and don't want to mess anything up. I am pretty good with electronics, and understanding how stuff works, this is just something I never had to deal with.
__________________
Old 07-29-2012, 09:26 PM   #5
The DB
St. Louis
2000 Limited SOHC
Vehicle Specs
I've had my Wilson 5000 knocked off by tree limbs, mind you I was going about 35mph and it was a low branch. A friend of mine uses an older magnet mount antenna for traveling, it blows over at about 80mph, less if there is a headwind. You have to remember that the magnets themselves are clinging to a thin piece of metal. Sheet metal is simply to thin, so they have compensated especially in recent years by putting on larger magnets.
To get you started on tuning try this thread. It should help you get your antenna to a fairly decently tuned.
The DB
Old 07-29-2012, 11:35 PM   #6
1996BLKBauer
Harold Tellefsen
McHenry, IL
Vehicle Specs
(Original Poster)
The DB
Thanks, just don't want it to be knocked off a lot. and that thread is WAY over my head right now. It was explained well, but I don't have the meter.
I am sure there are a lot of people like my friend, he told me to place the antenna in the center of the roof, and make sure to keep and metal below it. He said to route the cable away from high power consuming electronics, and to watch out for possible pinch points for the cable.
So if I follow what he said will it work well, and will I be making anybody mad, or myself for that matter?
__________________
Old 07-30-2012, 12:25 AM   #7
rrtdave
Nebraska
1998 XLT,4X4
Vehicle Specs
Radio Tuning
Also since I am new, and don't want to make anybody mad, how do you tune a CB? I am sure this is a very stupid question, but like I said I am very new to this, and don't want to mess anything up. I am pretty good with electronics, and understanding how stuff works, this is just something I never had to deal with.[/QUOTE]
http://www.rightchannelradios.com/cb...-swr-explained
Have fun !!
Dave 301 Nebraska
rrtdave is offline   Reply With Quote
Old 07-30-2012, 07:38 AM   #8
The DB
St. Louis
2000 Limited SOHC
Vehicle Specs
Quote:
Originally Posted by 1996BLKBauer View Post
...and that thread is WAY over my head right now. It was explained well, but I don't have the meter.
Seriously, get one, they are not that expensive. From the same web site that rrtdave linked to: $20 SWR meter
Those are excellent instructions to follow, but they do not tune your antenna in any way. There is one and only one best length for your antenna. The further away from that length you are the worse your antenna will perform. If you are to far away from that length not only will your transmission and reception be limited, but you may actually damage your radio as well. The antenna is by far the most important part of the radio, taking the time to make sure it is tuned is a basic necessity, and it isn't really that hard...
So just put it up there and hope it works? People have done that. I can also tell you that while these antennas seem to work, they never work as well as the person who put them up seems to think...
To bad you live 600+ miles away up in Chicagoland, if you were closer I would have been happy to tune that antenna for you for free...
The DB
Old 07-30-2012, 11:20 PM   #9
1996BLKBauer
Harold Tellefsen
McHenry, IL
Vehicle Specs
(Original Poster)
Been reading a lot, I mostly get how to tune the antenna. so That is good. I also was not forgetful and got pictures of my antenna. the brand is Hy-Gain, I cannot find a model number so I don't know much about it. but here it is.
Anybody know much about the company, or how well their stuff is built? They have a website, but it is straight out of the 90's and is very hard to navigate, with very little photos to see if anything looks similar.
The base of the antenna, no you can see the chrome thing I am talking about.
The magnet, see it is sort of small, why I would have a problem wit it staying.
how tall it is, I am thinking 3-4 Feet.
__________________
Old 07-30-2012, 11:23 PM   #10
LONO100
Bay Area CA
LONO100's Avatar
03 sport trac XLT
Vehicle Specs
if i were you, just invest 40-50 bucks and get a nice willy magnet mount antenna. remember, the most important part of your cb set up is the antenna. then the cable, and then the radio.
LONO100 is online now   Reply With Quote
Old 07-30-2012, 11:49 PM   #11
1996BLKBauer
Harold Tellefsen
McHenry, IL
Vehicle Specs
(Original Poster)
I know, but I am already dumping a ton of money in the stereo, like well over $1000. for some people it is excessive, but for me it is what I want.
All I really want is a good reliable setup, that I can use occasionally, which is what I am doing with my stereo. Later I most likely will invest in a new antenna, and a radio for that matter, but for now I just want something that works.
If anybody has had good suggestions for a magnet mount antenna, or some antennas I can mount off of the rear tail lights, which I eventually want to do for sure, please post them. Money is tight, and I am taking everything one step at a time, but in the end I just want nice reliable equipment.
__________________
Old 07-31-2012, 07:23 AM   #12
The DB
St. Louis
2000 Limited SOHC
Vehicle Specs
An old Hy-Gain? They were one of the better brands back in the day. I would love to get my hands on one just to play with it...
If its internals aren't in bad shape it should perform at or near as well as it did in the old days. Unfortunately it is hard to say if that is the case without examining it myself.
The DB
Old 07-31-2012, 05:51 PM   #13
4x4junkie
So.Calif.(San Fernando Valley)
'94 Ranger, '90 Bronco II
Vehicle Specs
That looks more like an old 2M ham antenna to me than a CB antenna (CB antennas of that length would have a much taller plastic housing on the base for it's larger loading coil).
What is the radio you got with it? (brand / model)
__________________
'90 Bronco II XLT
5" lift (Skyjacker jeep coils), locked D35 & 8.8", 5.13s, double T-case, 35x12.50s & cut fenders
'94 Ranger XLT
6" Skyjacker, ARB D44 front, Detroit 8.8" rear, Atlas 4.3, 33s
4x4junkie is offline   Reply With Quote
Old 07-31-2012, 11:47 PM   #14
1996BLKBauer
Harold Tellefsen
McHenry, IL
Vehicle Specs
(Original Poster)
It is an older model Midland, I cannot remember the model number, but I will post it once I get the radio out of the garage. It's late here and everybody in the house is sleeping, so I am going to wait until tomorrow to grab it, sometimes I dislike having attached garages.
__________________
Old 08-01-2012, 06:41 AM   #15
The DB
St. Louis
2000 Limited SOHC
Vehicle Specs
It appears to be a Hy-Gain Hellcat 3.
Link to old Hy-Gain add.
The DB
Old 08-01-2012, 10:48 PM   #16
4x4junkie
Vehicle Specs
That definitely looks like it may be it, though notice where the coax comes out of the base is different on the Hellcat 3 vs. 1996's antenna (the Hellcat goes out above the lip of the base, 1996's comes out under the lip).
Probably the same antenna and the base design was maybe just revised.
I'd still want that SWR meter just in case it's got a bad coil or something though, you would know right away if there's a problem with it.
__________________
'90 Bronco II XLT
'94 Ranger XLT
Old 08-02-2012, 09:30 PM   #17
1996BLKBauer
Harold Tellefsen
McHenry, IL
Vehicle Specs
(Original Poster)
So I am ordering the meter tomorrow, yay! I also got the model number off the the radio I was talking about. it is a Midland Model 13-882B. I believe I found the owners manual online somewhere and printed it off.
I also, a while back picked up 3 other radios off a guy for $20, they all came with cords, mics, and even a 20ft extension for the antenna. I also got all the model numbers for those.
Blaupunkt Model BCB-5231
Eversonic (Did not have a model number anywhere)
Pearce-Simpson Puma 23C.
Anybody know if these are any good? I mainly picked them up for the mics, and extension cable.
__________________
Old 08-03-2012, 07:15 AM   #18
The DB
St. Louis
2000 Limited SOHC
Vehicle Specs
The older Midlands were better then the newer ones imho. That being said, depending on parts deterioration and use it is hard to say if it is in good condition without using them. I'm not a vintage radio guy. I am familiar with the other names you mentioned but don't really know much about them.
The DB
Old 08-04-2012, 12:43 AM   #19
1996BLKBauer
Harold Tellefsen
McHenry, IL
Vehicle Specs
(Original Poster)
The DB
I eventually want to upgrade to a much newer radio, but for now, like I said I just want something that works.
I also have one more question, but I am sure there will be many more.
I bought the SWR Meter today, but I did not buy the jumper cable, but I do have a 20ft extension cable, can I just use that, or will is mess up something?
I was also searching for Antennas today, and found This, but there is no review, and there is not even a brand name. but it is cheap, and has a spring, which would be nice for me.
__________________
Old 08-04-2012, 09:20 AM   #20
The DB
St. Louis
2000 Limited SOHC
Vehicle Specs
20' of coax is rather long for a jumper cable, but it should work.
I am unfamiliar with that antenna. It should work about the same as any antenna of that length. I wouldn't trust the $2.00 spring though. Just what people who run a parking garage wants, an antenna designed to drag across the roof and break their lights.
The brand is Astatic, they made some good microphones until another company bought them out and started using cheap components. The model is 82FL BK. I don't know that those are still being made anymore.
The DB
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
Power Antenna question? 1996BLKBauer Stock 1995 - 2001 Explorers 14 02-07-2012 11:31 AM
CB info amigodana Ham Radio - CB - Trail Communications 8 09-12-2010 07:16 AM
Help I can't remove my broken antenna on my '95 explorer mcholst Stock 1995 - 2001 Explorers 3 11-20-2008 11:54 PM
How to tune a CB radio antenna... Stompah Ham Radio - CB - Trail Communications 1 07-06-2004 10:13 AM
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
