Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2006 - 2010 Explorer Mountaineer 4th Generation > Stock 2006 -2010 Explorers
Notices
Stock 2006 -2010 Explorers Stock 2006 -2010 Ford Explorer Forum. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
PCV Valve
Reply
Thread Tools
Old 07-30-2012, 04:26 AM   #1
k0t2004
2008 Explorer LTD 4.6L V8
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
PCV Valve
Hello
According to the service manual I need to change PVC valve sometimes. I've looked everywhere and can't find it. Also where is no PCV valve on fordparts.com for 4.6 engine. Does it ever exist? =)
k0t2004 is offline   Reply With Quote
( Join the Elite Explorers )
Old 07-30-2012, 02:54 PM   #2
Town
Ottawa, Ontario, Canada
2007 Lincoln Town Car
Vehicle Specs
Quoted: 2 Post(s)
In the Ford maintenance scedule the PCV is changed on most cars and light trucks except the 4.6 3v engine. The only service required is to check the PCV flow at 240,000 kilometers (150,000 miles). The PCV is located in the RH valve cover and is integral with it, so to change the PCV you need a new RH valve cover.
You should be able to see the PCV hose connecting from the air cleaner large tubing to the valve cover at the front of the engine. I will have to check my son's truck to confirm the hose location.
Good luck.
Town is online now   Reply With Quote
Old 07-30-2012, 11:33 PM   #3
k0t2004
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
By RH you meant passenger side? There are two PCV hoses on the passenger side (small one) and on the drivers side (big one). Checked the first one and it was dirty and oily inside. Other one was dry and clean.
thanks for the info.
Old 07-31-2012, 01:53 PM   #4
Town
Vehicle Specs
Quoted: 2 Post(s)
Yes, RH is the passenger side. Lcations are taken from the driver's point of view.
Old 07-31-2012, 06:42 PM   #5
Town
Vehicle Specs
Quoted: 2 Post(s)
The air flow through the crankcase starts at the black square box attached to the air filter tube between the filter and the throttle body. A hose from the black square box attaches to a port on the forward part of the RH valve cover and provides air to the crankcase through the PCV "valve" inside the RH valve cover. Air is extracted from the crankcase at the forward part of the LH valve cover through a hose that connects to the forward part of the intake manifold near the throttle body. This is the reverse flow compared to a typical PCV system.
Any oil laden air in the crankcase will be drawn through the LH valve cover and into the hose and burned in the engine. It is typical for the hose from the LH valve cover (in this case) to the intake to have some oily residue and this contributes to a high failure rate (hose cracking and splitting) causing engine vacuum leaks.
Sounds like your system is working.
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
Pcv valve wrap around pipe??? markedman450 Stock 1995 - 2001 Explorers 2 01-19-2011 11:53 AM
PCV valve replacement. andytyson1 Stock 1995 - 2001 Explorers 9 11-03-2010 08:23 PM
No Cost PCV Valve Replacement? pumpkin Stock 1995 - 2001 Explorers 8 10-30-2010 12:04 PM
Possible PCV valve or hose problem. kaotic01 Stock 1995 - 2001 Explorers 1 05-05-2009 12:26 PM
Uh-oh PCV Valve replacement gone wrong ok89 Under the Hood 4 12-14-2001 03:55 PM
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
