Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Explorer & Ranger Transmissions, Transfer Cases, & Differentials
Notices
Explorer & Ranger Transmissions, Transfer Cases, & Differentials Transmissions, Transfer Cases. A4LD, 4R70W, 4R44E, 4R55E, 5R44E, 5R55E, M5OD, BW 1354, Control Trac, GEM, AWD. Ford 8.8", Dana 35
95 Explorer V6 4WD 1-2 Shift Flare and Part Found in Transmission Pan
Reply
Thread Tools
Old 07-30-2012, 08:57 AM   #1
Eagle22
1995 Explorer XLT 4WD
Vehicle Specs
(Original Poster)
I’m a new member of this great site. This is my first post.
My 95 Explorer 4.0 6-cylinder 4WD with 165K miles will not shift from 1st to 2nd without me backing off the accelerator until engine RPMs fall back to about 1200. I understand this is called a shift flare. After reading many posts regarding shift problem cures on this site, I proceeded as follows:
1. Pulled OBD-I codes. Only key on engine off (KOEO) code was 123 for throttle position sensor (TPS). Checked sensor resistance and voltage, resistance fine, but top end voltage was low, 4.7V vs. 5.0V per Haynes manual. Replaced TPS. Engine runs smoother, but 1-2 shift flare still there. No key on engine running codes.
2. Dropped the transmission pan. Fluid was red, did not look or smell burned. It had been 90K miles since fluid and filter were changed. See the image below of a part I found laying in the pan. I did not know what this part was or figure out how it could have come down from higher up in the tranny. No other bits and pieces in the pan, other than very fine stuff on the pan magnet. Since I was already in there, I pressed on.
4. Removed the 6-solenoid valve body. No gasket blowouts as described in other posts on shift flare problems. I did not take the whole valve body apart to clean out the bores and other things. Installed new gaskets, TransGo shift kit valve body parts and a new EPC solenoid purchased from Transtar. Made sure all balls and other parts were intact before closing the VB. Installed the VB, torqued body bolts to 80 in-lbs. Installed new filter and pan gasket, 7.5 qts Mercon V fluid. No change to the 1-2 flare.
5. Adjusted the intermediate band to 120 in-lb, then backed off two revolutions. The 1-2 flare is now different in that the shift now takes place at about 1500 RPMs instead of 1200, and I can now slightly feel the 2-3 and 3-4 shifts. I did not adjust the overdrive band.
Does this picture show an apply strut for one of the bands? If so, is it possible for me to see where it came from by flashlight, mirror or borescope?
If it's not possible to see where this came from, is a rebuild in order?
Thanks in advance,
-Mike
Eagle22 is offline   Reply With Quote
Old 07-30-2012, 09:59 AM   #2
JK080
North Ga
Vehicle Specs
Yes that is a band strut for the band, most likely the intermediate band. These bands are known to break and would cause the strut to fall off. The intermediate band is your second gear, so if the band cant apply then you will not have second gear.
You will have to remove the trans and take it apart to replace the band.
JK080 is offline   Reply With Quote
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
2011 & 2012 Ford Explorer TSB's JDraper Stock 2011 - 2014 Ford Explorer Discussion 0 01-20-2012 10:58 AM
Superlift Install Instructions-Ranger-BII-and Explorer 83-97 Tbars4 Explorer - Ranger Shocks, Suspensions, Lift Kits 0 01-21-2010 02:20 PM
Fat cat Dennis F Transaction Feedback 13 01-17-2009 12:06 AM
1993 explorer door hinge/pins&bushings? jjt52 Stock 1991 - 1994 Explorers 5 11-29-2006 01:14 PM
Love my Explorer karrymiller Stock 1991 - 1994 Explorers 9 11-07-2006 10:27 PM
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
