Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
Lubricating Squeaky Door Hinges
Reply
Thread Tools
Old 08-02-2012, 07:20 PM   #1
jimbo231
Vehicle Specs
(Original Poster)
I have a 1998 explorer with a squeaking door and wondered what do I use to lube the hinge and where do I apply it? Here are some pics of the upper and lower hinges.
jimbo231 is offline   Reply With Quote
Old 08-02-2012, 07:39 PM   #2
corkey
Elite Canuck, Eh ??
In the Great White North where winter never seems to end ,Ontario,, still ice fishing,,
corkey's Avatar
96xl,99xls,old Rangers
Vehicle Specs
on the round thing and pin on the lower hinge and on the pin on the upper hinge,
__________________
Log Roller,, Fox Coilovers 35's and others, ,
Truck of the month
Ranger Of Danger,,,project truck,
also look for Blues Traveller Elite registry, ,
corkey is online now   Reply With Quote
Old 08-02-2012, 07:43 PM   #3
jimbo231
Vehicle Specs
(Original Poster)
Quote:
What's the best thing to use and how do I get it in those tight spots? Do I spray on top of the pin hoping it works its way down or do I spray in between the 2 moving steel parts to get at the pin?
Old 08-02-2012, 07:52 PM   #4
deweyville65
Dewey,Az
96 EXPLORER XLT
Vehicle Specs
I would use a good penetrating oil ( liquid wrench) to begin with. Then use motor oil in a squirt can a couple days later. Lube ALL moving parts, and the hinges where the pins go through.
deweyville65 is offline   Reply With Quote
Old 08-03-2012, 01:05 AM   #5
mojoe
Oxbow, ME
'97 XLT
Vehicle Specs
oil will work but white lithium grease in a spray can will last longer
mojoe is offline   Reply With Quote
Old 08-03-2012, 02:43 AM   #6
BrianDye
Michigan
BrianDye's Avatar
04 CV LX Sport
Vehicle Specs
^This.
I used some White Lithium Grease spray with one of the red straws, and got all my hinges shortly after I bought my X, had it for over a year and the squeaks never came back. Wipe the excess off though, I left some runs, and they were a pain to clean after a couple weeks.
__________________
'13 Dodge Charger RT
BrianDye is offline   Reply With Quote
Old 08-05-2012, 10:40 PM   #7
briwayjones
Sykesville, MD
briwayjones's Avatar
'00 XLS, '03 Sport
Vehicle Specs
Since when are you in Michigan?
Quote:
Originally Posted by BrianDye View Post
^This.
__________________
2000 XLS, 4DR, 4x4, OHV, Manual ; 2003 Sport, 2DR, 2WD, SOHC, Manual
Mobil 1 & Amsoil Synthetic Fluids, 2WD switch Brown wire mod, KKM air intake, overhead console, lighted sunvisors, custom 2nd HU install, '03 Ranger Fog lights, Hurst short-shifter, 75MM MAF, BBK 66MM Throttle Body
My 2000 Explorer
briwayjones is offline   Reply With Quote
Old 08-05-2012, 10:43 PM   #8
BrianDye
Michigan
BrianDye's Avatar
04 CV LX Sport
Vehicle Specs
May of '92, why?
__________________
Old 08-06-2012, 06:32 PM   #9
briwayjones
Sykesville, MD
'00 XLS, '03 Sport
Vehicle Specs
I thought you lived in Alaska. I must be confusing you with someone else.
__________________
My 2000 Explorer
Old 08-06-2012, 07:03 PM   #10
GRNMACHINE
IL
95 Sport 4x4
Vehicle Specs
Used white lithium in a spray. Still squeaks not to mention it looks messy...
__________________
95 Sport 4x4, 3.73, tt/shackles, K&N FIPK, 33X12.50X15 BFG T/A, 15x10 DC-1's, Pro Comp ES9000 shocks, Flowmaster Catback, ARB OME Leaf Springs, 2" BODYLIFT
"Thy shall Not Leaveth Thou Chariot Stocketh" Explorer 2nd Genesis
GRNMACHINE
GRNMACHINE is offline   Reply With Quote
Old 08-06-2012, 07:21 PM   #11
Jstcruz
Deltona, FL
Jstcruz's Avatar
97 Ex XLT & 84 Ranger
Vehicle Specs
Is WD40 not also good to use?
If no please explain
Jstcruz is online now   Reply With Quote
Old 08-06-2012, 07:23 PM   #12
swshawaii
Kailua-Oahu, Hawaii
'05 Sport Trac XLS (RWD)
Vehicle Specs
Quote:
Agree. Always wondered why this stuff has to be white.
Anyone know of a clear or non white spray grease formula?
swshawaii is offline   Reply With Quote
Old 08-06-2012, 07:44 PM   #13
briwayjones
Sykesville, MD
'00 XLS, '03 Sport
Vehicle Specs
It's not really. WD40 isn't so much of a lubricant as it is a solvent and protectant. It'll temporarily stop a squeak but not for very long compared to a actual lubricant like lithium grease. And it doesn't really provide lubrication from wear like a regular lubricant.
__________________
My 2000 Explorer
Old 08-06-2012, 09:56 PM   #14
Jstcruz
Deltona, FL
Jstcruz's Avatar
Vehicle Specs
Quote:
Thank you for that info.
I just remembered, PB Blaster has come out with a dry graphite spray lubricant. It is either clear or white, I used it on some cable pulleys and it didnt make any mess that I noticed (I was up a ladder stuck in a dim corner a couple feet away from the pulleys) It didnt run or "paint" the area like the black graphite sprays do. Not sure if its better or worse. I can try it on my car door and let you guys know how it goes.
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
Squeaky Brakes......Again 2011 Ex Smoktya Stock 2011 - 2014 Ford Explorer Discussion 14 01-06-2013 10:23 AM
Squeaky Turning! :( fallenangel Stock 1995 - 2001 Explorers 7 08-03-2011 08:22 AM
squeaky door panel El Duque Stock 2006 -2010 Explorers 3 04-23-2011 06:29 PM
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
