Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1991 - 1994 Explorer Ranger Navajo 1st Generation > Stock 1991 - 1994 Explorers
Notices
Stock 1991 - 1994 Explorers For questions related to the base Ford Explorer. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. No modification questions.
Need help with popping sound and shaking coming from engine
Reply
Thread Tools
Old 08-05-2012, 06:02 PM   #1
Themightyquinn
Philly, PA
2007 Eddie Bauer 4.0L AWD
Vehicle Specs
Quoted: 39 Post(s)
(Original Poster)
I have a 1992 Ford Explorer XLT 4.0L OHV. I just got done replacing my fuel injectors(remanufactured), TPS, valve cover gaskets; repainting my valve covers; and cleaning my fuel rail, upper intake manifold, and throttle body. Now the engine runs like crap. When the engine runs, I hear a loud occasional popping sound coming from the engine compartment (not sure exactly where but almost sounds like a backfire) every 3 to 5 seconds and the engine will shake like its a bout to die. The RPMs do seem a little below average for idle, but by barely a hair. Also, a very strong rotten eggs smell coming from the exhaust.I pulled all 6 spark plugs, and all three on the driver side of the engine were very black and sooty and one of them, the arc was actually bent a little (I would post images, but i don't know how to). The other three however, had normal wear. The spark plugs only had less than 1000 miles on them. So I replaced all 6 plugs in the hope that they were the cure, but no luck. I installed them and the engine ran no different. I ran the engine for a few minutes and pulled the plugs. The 3 on the driver side were already kinda sooty, and the other 3 looked fine. When I performed the KOEO test, all i get is 111, meaning all systems ok. When I performed the KOER test and goose test, all I get is 116 (engine coolant temp sensor out of range). Really confused at this point. The engine ran fine before I worked on it other than the leaking valve cover gaskets. Any help is greatly appreciated. Thanks!
Also, when put into gear (auto trans) the engine dies.
Themightyquinn is offline   Reply With Quote
( Join the Elite Explorers )
Old 08-05-2012, 07:34 PM   #2
pteepee69
Lawrenceburg,Ky.
'94 XLT
Vehicle Specs
Quoted: 4 Post(s)
If it were me I would start with double checking my work first. Are all the plugs for your injectors on the correct injector. All plug wires in the right order on the coil as well as on the correct cylinder. Are all other electrical connections being made. MAF sensor plugged in. Fuel regulator vacuum line connected. All vacuum lines connected to vacuum tree. I know when I've had my top half off I had broken one of the rigid black vacuum lines going to my EGR vacuum diaghram. Double check it all and then go from there.
__________________
" dying ain't no way to make a livin' boy ". Josey Wales
'94 XLT;auto to Warn hubs,A4LD to M5R1,DynoMax cat back,Summit Soft 8's with 32x11.5 BFG AT TA's,3" Body Lift
pteepee69 is offline   Reply With Quote
Old 08-05-2012, 07:42 PM   #3
Anime
EF YEAH!!
Anime's Avatar
2016 EX Sport Concept
Vehicle Specs
Quoted: 181 Post(s)
Sounds like you hooked something up wrong or didn't hook something up that needs to be. The rotten eggs smell is the catalytic converter, it's either getting destroyed by too rich of a ruel/air mix if the fuel system is dumping in too much fuel, or they are overheating (or both). Re-check everything as suggested. It may be as simple as some unplugged connectors, or you may need to rip it apart and start over.
Did you 'burp' the cooling system as required, or are you just running it straight with air in the system? If you don't burp the air out of the cooling system before running it normally, the trapped air will stick the thermostat closed and the engine will overheat, sputtering and dying. If the coolant temp sensor is fried or dead, you could be overheating the engine but won't know it until it's too late because the gauge reading won't tell you what's really going on.
__________________
"I think man has always gone where he has been able to go, and I think that when man stops going where he can go, he will have lost a lot. Man has always been an explorer. To me, there's a fascination in thrusting out and going to new places. It's like going through a door because you find the door in front of you." - Michael Collins
Anime is offline   Reply With Quote
Old 08-05-2012, 08:56 PM   #4
Themightyquinn
Philly, PA
Vehicle Specs
Quoted: 39 Post(s)
(Original Poster)
@Anime, thanks a lot for the reply. I was not aware of the coolant burp. how exactly is it performed? And where exactly is the coolant temp sensor? Thank you.
Old 08-05-2012, 09:35 PM   #5
Anime
EF YEAH!!
Anime's Avatar
Vehicle Specs
Quoted: 181 Post(s)
Quote:
Fill the system, but leave the cap off the radiator. Shake the vehicle to remove the big bubbles, and refill as the level goes down. Again, leave the cap off or just half on (first click, half on) and crank the vehicle. Turn the heat on high. Once the engine gets warm enough and the temp gauge needle rises to about the middle, then drops a bit, the thermostat has opened. Turn vehicle off. Let engine cool. Remove cap, refill radiator. Fill the overflow tank and let the engine run with the heat on for a few minutes again, with the cap on halfway as before. Heat up to normal temp, until the gauge drops from the thermostat opening. Turn vehicle off. Next morning when the engine is completely cool again, recheck the coolant level in both the radiator and overflow tank.
Tighten radiator cap and you're done.
Note, if the engine temp climbs rapidly after getting to the middle of the gauge - TURN IT OFF! Thermostat is stuck closed and needs to be replaced.
Quote:
There are 2 coolant sensors, one for the computer and one for the gauge. The Gauge one is a straght shot if you move the clamp on the heater hose out of the way first. The other one is a bit harder as part of the thermostat housing is in the way. So long as the engine is cool you should not have much if any fluid come out as both are at the very top of the engine.
Quote:
When replacing, have your new one ready and taped so you can put it in immediately.
Unscrew your old one and put that one in as quick as possible and you won't hardly lose any coolant.
Quote:
On an Explorer with the 4.0 L OHV engine, the coolant temperature
sending unit for the temperature guage is located on the intake manifold
just to the left of the thermostat housing when standing in front of the
vehicle. The larger sending unit on the right is for the EEC system.
Might be the larger sending unit for the EEC system rather than the sensor for the gauge.
You might also need to replace the thermostat itself if you have not already done so.
__________________
Old 08-05-2012, 10:43 PM   #6
Themightyquinn
Philly, PA
Vehicle Specs
Quoted: 39 Post(s)
(Original Poster)
@pteepee69 Thanks for the reply. I feel like an idiot. I had the spark plug wires on the left side of the engine in the wrong order. Lol. After that she purred like a kitten. Thanks 4 your assistance. Next stop ball joints! Any helpful hints as I have never replaced them before?
Old 08-05-2012, 10:44 PM   #7
Themightyquinn
Philly, PA
Vehicle Specs
Quoted: 39 Post(s)
(Original Poster)
@Anime. Thanks a lot. I will give this a shot tomorrow.
Old 08-06-2012, 02:46 AM   #8
Anime
EF YEAH!!
Anime's Avatar
Vehicle Specs
Quoted: 181 Post(s)
Quote:
http://www.explorerforum.com/forums/...d.php?t=218254
__________________
Old 08-08-2012, 11:35 AM   #9
Bill O'Rights
Omaha, NE
'94 XLT
Vehicle Specs
Quoted: 0 Post(s)
Not to worry. Every single one of us has done something as or more embarrasing than that. If they say they haven't, they're either lying or have never done any type of repair/maintenance work.
__________________
________
[_l_|_,\___\,__
l---__---_[=lllllll=]
()_)' `()_)--''--)_)
Bill O'Rights is offline   Reply With Quote
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
Engine or electrical problem earnbud Stock 1995 - 2001 Explorers 8 07-03-2011 02:09 PM
2000 Ford Exp. 4.0 V6 OHV Engine Too Loud ramoan Under the Hood 3 12-27-2010 08:38 AM
NEVER FORGET spiper Exploring every thing under the sun!! 26 02-13-2006 01:59 PM
busted starter & engine shake BonesDT All Other Makes and Models 1 02-24-2004 07:08 PM
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
