#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Modified 1995-2001 Explorers
Notices
Modified 1995-2001 Explorers Questions related to modified 1995-2001 Explorer, Mountaineer, Ranger and 2002+ Sports (2dr). Aftermarket accessories and modifications. Bullbar, running boards, floor mats, cargo mat, DVD headrest, wheels, tires, stereo upgrade, headlights, mud flaps, torsion twist, lift kits, engine swap, transmission swap.
Transmission fluid level check question
Reply
Thread Tools
Old 08-11-2012, 05:43 PM   #1
jbouchard
California
1998 Ford Explorer Sport
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Hello.
To me, this seems like a no brainer question, but Im really serious. Why is it that when I try to check the transmission fluid level, sometimes I can easily tell where the level is at, and other times I cannot tell where the fluid level stops or stops?
To give some background, a few months ago I put in a transmission fluid temperature gauge following one of the tutorials on this site, and so Ive been keeping my eye on the fluid level because its dripping a little bit out of the fitting for the gauge. This site is great, by the way, and has helped me through several repairs on our 98 sport.
When I check the transmission fluid level, however, with the car running and when the transmission fluid has heated up, sometimes it is very easy to read, and other times its like there is parts of the dipstick where there is fluid but then as I look down the dipstick there will be a part with no fluid on it and then a little farther down there will be a consistent fluid mark....? Its not like checking the oil, where there is a very clear line of where the oil level it.
Does it have to do with the temperature of the fluid? If the fluid is very hot, does it slide off the dipstick easier and make it harder to find an accurate picture of the fluid level?
Im just curious, becuase like I said, I just put in that new tranny gauge and I also just recently changed the tranny fluid and filter, so I dont want to be running the tranny low on fluid.
Thanks.
jbouchard is offline   Reply With Quote
( Join the Elite Explorers )
Old 08-13-2012, 10:01 AM   #2
Sedition
Engine Repair Guy
Geelong, Australia
Sedition's Avatar
98 Explorer XLT SOHC
Vehicle Specs
Quoted: 40 Post(s)
I find the best way to check the Tranny fluid level is to have your Explorer parked on a level surface with the engine running in Park with a warm tranny. Remember, you have to drive something like 20kms to warm your tranny.
1~ pull the dip stick out.
2~ dry it really well on your shirt or something
3~ in one motion push the dipstick all the way in and immediately pull it back out
4~ examine dipstick end.
For some reason this is the best way to get an accurate reading, may be because the Transmission fluid is dripping down onto the dipstick when the trans is operating.
I burned my tranny fluid bad once, it looked like motor oil, so every month I drain the pan by pulling one of the cooler lines then add 4 litres of mercon V as not to shock the system too much. So I get plenty of practise checking the tranny fluid, lol.
__________________
98 XLT SOHC V6 Export - Busted tranny - Recently Rebuilt Engine For Sale
2002 Limited SOHC V8 - Bent Rod - Awaiting Repair
It's the all American SUV, I tell you w'hut....
Sedition is offline   Reply With Quote
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
General Maintenance Question stiffaknee Stock 2002 - 2005 Explorers 7 05-14-2014 03:02 PM
check the fluid in the transmission gustavo1256 Modified 2006 - 2010 Explorers 1 05-17-2010 01:51 AM
Transmission fluid Re-fill question SportsTrac2001 2001-2005 Explorer Sport Trac 2 04-12-2010 04:53 AM
Explorer Auto Transmission Diagnosis - Q & A FAQ Glacier991 Explorer & Ranger Transmissions, Transfer Cases, & Differentials 30 08-11-2009 12:05 AM
transmission fluid level check hc_spooky Stock 2002 - 2005 Explorers 11 08-15-2008 03:03 PM
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
