itshotinjt
- April 6, 2011
- CA
- 1996 Explorer
So I went to start my 96 Explorer yesterday and it doesn't start. It turns over fine. The battery is only about a year old. When you turn the key one click, the engine makes a clicking sounds, but not that "electrical/mechanical" sound in normally makes before turning it all the way to start it. My husband is thinking fuel pump or maybe even fuel relay switch (or is it fuse? I forget). Any suggestions on how to check these things first before spending insane amounts of money changing things that don't need to be changed.
BTW, not sure if it matters much, but it has 257,000+ miles on it now. 2WD, 6 cylinder.
Thanks!!
**We just tried starter fluid. It starts with that, but dies as soon as we stop putting in the fluid. SO, where do we go from here? How do we check all of the other things now assuming it isn't getting fuel?
Thanks!!
