Huskerbob
- July 8, 2012
- Concord, NC
- 2003 Explorer Eddie Bauer
2003 Eddie Bauer, 118,000 miles, 4.0 V6, totally stock.
Jack truck up and remove a front wheel.
Place jack stand under frame.
Remove stabilizer bar link from stabilizer bar and lower "A" arm.
Remove lower strut bolt. Punch it out if you have to. I didn't, just backed it out.
Remove 3 upper nuts on the top of the strut tower.
Hit the assembly with a dead blow hammer and it will fall down.
Grab ahold of the assembly and wiggle it out.
Pull the top out first and then pull the bottom through the hole in the lower frame. You do not need to compress the spring to do this.
Reassemble in reverse order.
Put the new assembly bottom down through the frame hole and then push it up so that the top 3 bolts go through the tower. Put nuts on these bolts finger tight. Tighten the nuts from above with a long extension to 22 ft. lbs.
You can't do it backward since the upper bolts are spaced so that 2 are closer together and one is off all by itself.
You may have to turn the lower end or move it back and forth to get it in the right spot. Jacking up on the brake rotor helps get the top nuts tight and then pushing down on the brake rotor helps and a long screwdriver put throught the lower hole to help line it up also helps.
Tap the lower bolt in carefully until you can get the nut started. Tighten this bolt to 280 ft. lb. if you can. I used a 250 ft. lb. wrench and gave it a couple of extra pulls.
Put in a new sway bar link or make sure the old one is good. If the rubber bushings are hard go ahead and replace the whole deal. Moog makes some good ones.
Put the wheel back on and drop it off the jack stand and the jack.
There you go. Repeat on the other side. Easy.
I used the Struttech complete assemblies and they are nice and inexpensive.
