Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2006 - 2010 Explorer Mountaineer 4th Generation > Stock 2006 -2010 Explorers
Notices
Stock 2006 -2010 Explorers Stock 2006 -2010 Ford Explorer Forum. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
Intermittent Overheating (07 XLT, 4.0L)
Reply
Thread Tools
Old 08-22-2012, 11:24 AM   #1
sonza68
07 Explorer
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
A few weeks ago, I was on a short drive and noticed the loud rushing sound of the aux fan kicking on. I looked down and the temp gauge was just under the red. After only a few seconds, the temp dropped rapidly to normal and then sat there rock solid for the rest of the time I was driving. The repeated about 2 weeks later and then a third time about another week after that.
Each time it happened, it was as the engine was warming up from cold. Each time the aux fan was audible. Each time, the temp was only high for a few seconds before returning rapidly to normal. Coolant levels appear to be OK, and I have no major leaks (1 very minor one, but it only leaves a few drops after being parked overnight)
Does this sound like a sticking thermostat? Or, is there something else I should be looking into?
sonza68 is offline   Reply With Quote
( Join the Elite Explorers )
Old 08-22-2012, 05:30 PM   #2
spalmer1214
Vehicle Specs
Quoted: 0 Post(s)
It sounds exactly like a sticking thermostat. I would start with that. That is also the cheapest fix too
spalmer1214 is offline   Reply With Quote
Old 08-22-2012, 07:42 PM   #3
The Scott
Cincinnati
2008 Explorer XLT
Vehicle Specs
Quoted: 1 Post(s)
Yes, also not a bad time to change the coolant as well if it is original.
The Scott is offline   Reply With Quote
Old 08-23-2012, 10:33 AM   #4
sonza68
07 Explorer
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Thanks, I was pretty sure that's what it was.
Old 08-27-2012, 12:28 PM   #5
GIJeff
Owensboro, Ky
2007 Ford Explorer
Vehicle Specs
Quoted: 0 Post(s)
My '07 Explorer is doing exactly the same thing - started out exactly as you described, but over time now (a couple of months) it has slowly gotten worse, to a point now where it is more often than not overheating. The temp gauge fluxuates constantly, and the A/C doesn't blow cold air when it is hot. I've also noticed that it smells hot when it used to not.
Sonza, did replacing the thermostat fix your issue? If so, I'm about to do the same thing.
GIJeff is offline   Reply With Quote
Old 08-28-2012, 05:30 AM   #6
sonza68
07 Explorer
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I'm not sure yet, I just replaced it over the weekend. It's a really easy job though.
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
Help on a 95 xlt with loss of power and overheating? Eturpel Stock 1995 - 2001 Explorers 0 07-11-2011 02:04 PM
What transmissions will fit my 97 4x4 4.0L XLT Gannz Explorer & Ranger Transmissions, Transfer Cases, & Differentials 2 03-03-2011 08:04 PM
07 Ford Explorer XLT Fire/EMS POV SeanC898 Explorer Registry 1 12-20-2010 03:43 AM
towing with a 06 4.0l explorer xlt angioguy Tow Rig Forum 1 10-04-2010 10:16 AM
2004 XLT 4.0L SOHC Maintenance Manual adolfomantis Stock 2002 - 2005 Explorers 4 02-02-2009 08:08 AM
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
