Pair of OEM positive/negative battery cables from a 93, should fit all 93-94 Explorers.
Used, but I've been using AGM batteries so there's no corrosion on them.
There is some bleuing of the copper though, and the negative terminal has a small crack.
$35 plus $5 priority shipping
I also have a slightly newer negative cable for a 93-94 (not pictured)
$15 plus shipping
Pair of OEM positive/negative cables, though I can't remember if they're from a 91-92 or a 95-00, but I think
they're out of a '98. These only have one wire going to the starter and one thick wire to the solenoid
on the positive cable, and the very short negative cable with connectors.
I was going to use these to relocate the battery or add a second but didn't go that way.
$25 plus $5 priority shipping
New Borg-Warner 10 inch universal negative battery cables.
$3/ea or take both for $5 plus shipping.
