Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Stock 2002 - 2005 Explorers
Notices
Stock 2002 - 2005 Explorers Questions related to non-modified 2002 - 2005 Explorers and Mountaineers. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. Sport Trac and Sport use the 1995-2001 forum.
2003- replace dash lights
Reply
Thread Tools
Old 08-25-2012, 07:52 AM   #1
dennisward
Silver Spring , Maryland
2000 2wd XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Can anyone provide guidance on replacing burned out dash lights on FORD Explorer 2003 XLT.
I did this on a 2000 F xlt and there was a lot of screws and plugs to pull, but no real headaches, just time spent.
I was hoping that the 2003 had a better way to get to the back of the dash cluster .
dennisward is offline   Reply With Quote
( Join the Elite Explorers )
Old 08-25-2012, 08:59 AM   #2
BigRondo
USMC 1371
Worcester, MA
BigRondo's Avatar
2002 XLT V6 4x4
Vehicle Specs
Quoted: 94 Post(s)
Welcome aboard!!
Use this thread to remove the cluster: http://www.explorerforum.com/forums/...d.php?t=218636
The changeable bulbs are removed from the back of the cluster.
This picture is from my '02 cluster.
The color coding of the arrows is as follows:
White - High Beam Bulb
Red - Cruise Control Bulb
Green - Turn Signal Bulbs
Purple - Gauge Cluster Illumination Bulbs
Hope this helps out!
Please keep us posted as feedback helps others reading this post looking for a fix to the same or similar issue!
__________________
Rondo - USMC, Combat Engineer, 1983-1996
Click here for a list of my write-ups!
Quote:
Originally Posted by FIND on 4-22-13
Don't mess with Boston. They will drop everything, hunt you down, and then go on like you never existed once they are done cleaning up the mess.
BigRondo is offline   Reply With Quote
Old 09-15-2012, 11:46 AM   #3
JamesAtz
Kelowna BC
2003 Ford Ranger XLT
Vehicle Specs
Quoted: 0 Post(s)
Dashlight
The dashlight that illuminates the gas gauge and temperature gauge on my 2003 Ford Ranger is out. I just purchased it yesterday. Is it an LED light and do I have to remove the whole dash like BigRondo did? By the way, great posting! Jim
JamesAtz is offline   Reply With Quote
Old 09-15-2012, 08:34 PM   #4
extra-medium
Rockville, MD
2002 Mercury Mountaineer
Vehicle Specs
Quoted: 27 Post(s)
My message center on the bottom right is very dim, pretty much can't see it during the day. Is that something I could fix by changing one of these bulbs, or is it more complicated than that?
extra-medium is offline   Reply With Quote
Old 09-16-2012, 04:52 AM   #5
Nevea'sExplorer
Pittsfield, Ma
02 4.0 XLT 4x4 5R55W 3.55
Vehicle Specs
Quoted: 1 Post(s)
Quote:
It's a very common problem with the Explorer's. Here you can learn how to fix it yourself. http://www.explorerforum.com/forums/...rument+cluster It took me three try's at re-soldering it before I got it fixed.
Nevea'sExplorer is offline   Reply With Quote
Old 09-16-2012, 10:12 AM   #6
BigRondo
USMC 1371
Worcester, MA
BigRondo's Avatar
2002 XLT V6 4x4
Vehicle Specs
Quoted: 94 Post(s)
Quote:
Welcome aboard!!
I am not familiar with the Rangers. I guess they are pretty much the same as the Explorers. I know that in order to replace those bulbs in the Explorer, the cluster has to come out. I used this thread for removing the cluster: http://www.explorerforum.com/forums/...d.php?t=218636 You could also pose this question to the Ford Ranger - Mazda B-Series Sub-Forum. Click here to go there now.
Once you have the cluster out you can change the bulbs. I recommend changing all the bulbs while you have the cluster out!
Good luck with the fix.
__________________
Old 09-16-2012, 10:44 AM   #7
BigRondo
USMC 1371
Worcester, MA
BigRondo's Avatar
2002 XLT V6 4x4
Vehicle Specs
Quoted: 94 Post(s)
Welcome aboard!!
Like Nevea'sExplorer said, this issue is very common to the 3rd Gen's. I had to fix my cluster & the Mounty cluster I installed in my Ex. I got the soldering iron at Walmart for $10.00, complete with solder: http://www.walmart.com/ip/30-Watt-So...-Iron/16539504
Use this link for removing the cluster: http://www.explorerforum.com/forums/...d.php?t=218636
Good luck and be sure to let us know how you make out!
__________________
Old 09-17-2012, 09:42 AM   #8
JamesAtz
Kelowna BC
Vehicle Specs
Quoted: 0 Post(s)
Thank you!
Old 09-17-2012, 10:35 AM   #9
BigRondo
USMC 1371
Worcester, MA
BigRondo's Avatar
2002 XLT V6 4x4
Vehicle Specs
Quoted: 94 Post(s)
Thank you!
Your'e welcome. Good luck & be sure to keep us posted.
__________________
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
2003 Sport Trac dash lights replacement sljkansas 2001-2005 Explorer Sport Trac 5 02-05-2010 11:41 PM
02 Explorer - Installed New Radio now no dash lights jolly06 Explorer Audio & Navigation 2 08-26-2009 09:47 AM
NO dash lights, NO tail lights... YourNameHere Stock 1991 - 1994 Explorers 4 02-02-2009 07:25 PM
Headlights and Dash Lights Don't Work plug Stock 1995 - 2001 Explorers 10 02-02-2006 09:14 PM
Dash lights burnt... FireZeus Under the Hood 3 11-30-2001 06:48 PM
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
