Town
- July 3, 2012
- Ottawa, Ontario, Canada
- 2007 Lincoln Town Car
My son has a 2007 Explorer EB with the V8 and towing package with class 111/1V hitch and 7 pin plug. He wants to buy a trailer capable of handling a 3,400 lb payload. He is looking at a 5x10 tandem axle utility trailer with a GVW of about 4,400 lbs. In Canada brakes are required for a trailer GVW of 2994 lbs and above. Electrically operated brakes are usually recommended by the dealers. I have been helping him with his research, but I only ever towed a double snowmobile trailer without brakes.
The Ford electrical diagrams show a brake controller in the circuit to power the brakes. The module is tied to the BOO electrical circuit for the brake pedal, but no apparent input on brake fluid pressure. There is no explanation of how this works that I could find. In particular, how the amps sent to the trailer brakes are modulated. My concern is to prevent trailer brake lockups under varying braking loads or trailer weights (1,000 lbs empty or 4,400 lbs fully loaded). Does anyone know how the Ford unit works?
Aftermarket electronic brake controllers seem to be quite varied in their design and generally require the driver to set a couple of variables on dials to effect proportional braking with loaded and unloaded trailers. In the diagnostics in the manual, Ford says "The vehicle is supplied with wiring to support an aftermarket trailer brake control module". Is an aftermarket brake controller required where the trailer weight can vary significantly?
