Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Explorer & Ranger Transmissions, Transfer Cases, & Differentials
Notices
Explorer & Ranger Transmissions, Transfer Cases, & Differentials Transmissions, Transfer Cases. A4LD, 4R70W, 4R44E, 4R55E, 5R44E, 5R55E, M5OD, BW 1354, Control Trac, GEM, AWD. Ford 8.8", Dana 35
"Rebuilt" A4LD 1st gear slips, 40-45 mph shudder
Reply
Thread Tools
Old 09-09-2012, 09:23 PM   #1
arco777
Anchorage, AK / Little Rock AFB, Arkansas
arco777's Avatar
2x 1994 4x4
Vehicle Specs
(Original Poster)
94 A4LD. Supposedly rebuilt with new torque converter.
First gear feels like it is slipping, more so when trans is hot. Like you're pulling a trailer or something.
Also from about 40-45mph there is a shudder and the truck doesn't feel like it wants to accelerate unless you apply significantly more throttle; above that speed it's fine.
Done so far: New trans fluid. Bands adjusted. No codes thrown. TC stall speed checked OK, TC is locking/unlocking properly.
Trans pressure tester is in the mail. I'm willling to throw parts at it with recommendations (new servos, boost valve, shift kit maybe???).
Any help is greatly appreciated!
arco777 is offline   Reply With Quote
Old 09-16-2012, 04:37 PM   #2
wood1
North of Ottawa
wood1's Avatar
'93 XLT, Cayman Green RIP
Vehicle Specs
Slipping you say? The sensation of pulling a trailer and a slipping trans don't quite jive for me. If it was slipping and you press harder on the gas you should get a raise in engine rpm without an increase in vehicle speed.
You have the ATSG manuals for the A4?
If I was going to mess with the VB I would (and did) rebuild it completely using Glacier's thread.
__________________
Ribs. I had ribs for lunch, that's why I'm doing this.
List of useful TTB Threads
wood1 is offline   Reply With Quote
Old 09-18-2012, 05:02 PM   #3
arco777
arco777's Avatar
2x 1994 4x4
Vehicle Specs
(Original Poster)
Thanks for the reply Wood1. I don't have any manuals except the Ford TSP for the Explorer, which is useful and should be enough for a rebuild I think. I'll look into the valve body rebuild if I can get the free time.
As for slipping vs towing sensation... It's like trying to take off in second gear. Which I suppose it could be doing...
__________________
-1994 Explorer 2DR 4x4 - EE swaybars/shocks, Optima Yellow Top, modified throttle body, exhaust, intake. Paxton supercharger on the workbench...
-1994 Explorer 4DR 4x4 - exhaust, brush guard, modified throttle body, intake, 2" lift, 31.5" tires on 16" Sport Trac wheels. FOR SALE!
-1989 Taurus SHO
-2008 Mustang GT Bullitt #5560 - Tuned
Old 09-19-2012, 06:49 PM   #4
wood1
North of Ottawa
wood1's Avatar
Vehicle Specs
Have you tried selecting 1st rather than drive and starting off to see if you are starting in 2nd?
PM me your email address and I will send you the PDF of the ATSG manual. Very informative.
__________________
Old 09-19-2012, 07:13 PM   #5
wood1
North of Ottawa
wood1's Avatar
Vehicle Specs
Meant to ask you too if that shudder happens when the engine is cold or once it is up to operating temps. The converter does not lock until the engine is warm, helps it warm up quicker. Could be the converter shuddering when it locks.
__________________
Old 09-20-2012, 05:53 PM   #6
arco777
arco777's Avatar
2x 1994 4x4
Vehicle Specs
(Original Poster)
I haven't been driving that Explorer lately; but if I recall correctly, manually putting it in first didn't make a difference.
The shudder seems to be whether cold or warm. Anytime I manually unlock (tap brakes) the torque converter or notice it lock up, it does it smoothly.
__________________
-1989 Taurus SHO
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
92 a4ld grinds into 1st gear kraylake Stock 1991 - 1994 Explorers 21 02-04-2011 01:35 PM
A4LD scheeches then jumps into 1st gear kraylake Stock 1991 - 1994 Explorers 2 08-20-2010 06:43 PM
no 1st gear or overdrive - 4r44e Huricane Explorer & Ranger Transmissions, Transfer Cases, & Differentials 10 12-30-2007 06:40 PM
A4LD stuck in 1st gear custom20aj Explorer & Ranger Transmissions, Transfer Cases, & Differentials 13 08-09-2006 07:06 AM
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
