| Modified 1995-2001 Explorers Questions related to modified 1995-2001 Explorer, Mountaineer, Ranger and 2002+ Sports (2dr). Aftermarket accessories and modifications. Bullbar, running boards, floor mats, cargo mat, DVD headrest, wheels, tires, stereo upgrade, headlights, mud flaps, torsion twist, lift kits, engine swap, transmission swap. |
Thread Tools |
#1 |
Wannabe Elite Explorer
Westchester, NY
'99 Explorer Sport
4.0L OHV Turbo - Not Building Boost!
I did a custom turbo setup on my 4.0L OHV (in my 99 exploder sport) and Im having trouble with it. Its simply not building boost.
Specs: Small turbo from a mid 80's Mercedes Turbo Diesel (not sure exactly what size) - internally wastegated and set at 7 lbs Custom manifold piping and downpipe Custom charge pipe with blow-through MAF and blow of valve (before the MAF). Apexi air fuel controller Stock injectors 66mm (i think) throttle body (its the aftermarket BBK one) Now, I have the turbo running off only the passenger side bank. All the plumbing is done right, but the turbo won't spool. No boost leak, I would hear the air escaping. The a/f ratio is perfect, as we monitored it with an air fuel meter while tuning. Intake turbine is not spinning on the shaft. The wastegate is not stuck open. So far Ive narrowed it down to the possibility of a vacuum leak (the car doesn't idle that well) as well as my EGR stuck open. However, I don't understand why I wouldn't see at least a little boost (even a pound or two). I plan on getting rid of the EGR and smoking the vacuum system this weekend to see if that fixes anything. If there are any turbo gurus on here, please give me some input or point me in the right direction. Im getting very frustrated with this build. PICS: ![]() ![]() ![]() ![]() ![]() And the truck
#2 |
Westchester, NY
'99 Explorer Sport
Sorry, the BOV is not pictured in that top pic, but it is between the MAF and the turbo
#3 |
Westchester, NY
'99 Explorer Sport
bump
#4 |
Plymouth, CT
1995 Ford Explorer/SHO
Probably not enough, or a consistent flow of air off JUST the passenger side. Not only that but your changing back pressure and flow characteristics of the motor.
What car exactly did you get it off of? __________________ -1995 Ford Taurus SHO 3.0 5 Speed-A.K.A Tori 17x7 Kazera KZ-U/Nitto NT 555 235/45/17, 11.6" Brake upgrade, SHO Source equal length Y-pipe and full exhaust, Koni Adjustable strut/Intrax spring, Rear strut tower bar, Sub-frame connectors, poly/reinforced everything. -1995 Explorer 4x4-Rusty |
#5 | |
Westchester, NY
'99 Explorer Sport
Quote:
i believe it came off of an 86 mercedes 300, but I'm not entirely sure. my turbo guy had it on his shelf for a while and when he heard exactly what my project was (and that i was only running off one bank, or 2 liters) he thought this turbo would be a good match and he rebuilt it for me. |
#6 |
Johnstown, PA
1994 Explorer XLT
The turbo on a 3.0t was more of a restriction than anything. It wasn't even equipped with a wastegate it was so useless.
__________________ 1994 Explorer XLT | M5R1 swap | 2" Lift | 32" ProComp Mud Terrains 2006 Saab 9-3 Aero | 2.8 Full pressure turbo | 6MT | 280whp/325wtq |
#7 |
Likes Math!
Vermillion, SD
99 XLT V8 AWD
That turbo on the OM603 was barely big enough for for the OM603, it is not big enough to feed a 4.0. Turbos aren't just about the amount of boost they make. The CFMs they deliver is what you need to pay attention to. Find it's long lost twin and you will get enough air to your engine.
#8 |
Washington State
96 sport 4.0 ohv
I assume that the turbo has been checked to see that the compressor side impeller does indeed turn?
It does seem odd that a turbo especially what looks to be a large turbo, doesn't supply *any* measurable boost.. Does the intake have any cracks and are the gaskets in good shape? Have you ran the truck without the air filter on it to see that the impeller is turning? Do you have another turbo to try? |
#9 | |
Likes Math!
Vermillion, SD
99 XLT V8 AWD
Quote:
But yeah really, Diezel Benzs are really popular in Finland, and those guys will tell you the first thing they have to do to make any power is change turbos, then change plungers in the injector pump. __________________ I strongly abide by the motto, "Safety third." Last edited by FIND; 09-19-2012 at 09:07 PM. |
#10 |
Westchester, NY
'99 Explorer Sport
Did a smoke test on the vacuum system yesterday.... there are no leaks whatsoever. Got about halfway through removing the egr (installing new drivers side tubular manifold with egr plugged) and after breaking 3 of the 6 studs, i called it quits for the weakend haha.
im picking up an intake plenum from a 94 ohv (the aluminum one) without an egr hole, so once i get that ill finish everything up and try again. |
#11 | |
Westchester, NY
'99 Explorer Sport
Quote:
We have a t3/t4 lying around, so were going to try to modify as little as possible while bolting it on to see if it changes things. |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Questions about performance on an OHV 4.0L engine. | Marx4.0 | Aerostar Forum | 14 | 05-21-2012 11:10 PM |
| 4.0L OHV to SOHC conversion | ZNathan130 | Under the Hood | 43 | 03-09-2012 08:43 AM |
| 97 4.0L OHV swaping to a 05 Mustang 4.0 SOHC need help | jelder | Stock 1995 - 2001 Explorers | 8 | 02-20-2012 03:07 PM |
| Engine questions: 4.0L OHV and 5.0L V8 | TennTechMan | Modified 1991-1994 Explorers | 10 | 01-31-2009 07:32 PM |
| Another 4.0L OHV Build Thread (with 95TM heads) | TennTechMan | Modified 1991-1994 Explorers | 61 | 05-14-2008 01:50 PM |
| Thread Tools | |
