Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1991 - 1994 Explorer Ranger Navajo 1st Generation > Stock 1991 - 1994 Explorers
Notices
Stock 1991 - 1994 Explorers For questions related to the base Ford Explorer. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. No modification questions.
headjob redux
Reply
Thread Tools
Old 09-15-2012, 07:13 PM   #1
tomjt714
Jefferson, PA
92Explorer XLT
Vehicle Specs
(Original Poster)
Roll headjob
Okay folks, I'll Just lay it out. Bought a '92 XLT, 4.0, 5 sp. Body beautiful. Stopped for fuel on way home, saw coolant leakage dripping down from back of engine. Ooooch. Wasn't that bad at time. Did the super radiator flush and leakage is medium steady. So, know it's either head gasket or lower intake manifold. When I investigated, hottest and wettest seemed to be at the join of the two (passenger side). Any thoughts as to it being just the lower intake? Also, with 175K would it be just as prudent to refurb heads as I'll be 90% there with lower intake. Operating on shoestring budget. Already got beat on truck, need all advice readily available. Also, what damage can I expect on getting heads shaves, boiled, etc.? By the way, piece of advice... Before buying used Explorer that looks good, pull hose off radiator overflow tank and make sure previous owner didn't epoxy it shut to camoflage probable head gasket problems.
By the way, no water in oil or exhaust. Runs on hi side of normal. Quits leaking when coolant level drops below some? point.
Thanks all.
tomjt714
tomjt714 is offline   Reply With Quote
Old 09-15-2012, 07:36 PM   #2
malohnes
SE Alaska
malohnes's Avatar
'91 xl m5 4x4
Vehicle Specs
Sounds familiar. Most likely a head gasket, but could very well be both loose LIM bolts and bad head gasket. Might also be a bad lower intake gasket as well.
My advice, is to replace head and intake gaskets, clean the heads, unless there is sign of damage and put it all back together. Just remember to obtain new head bolts and torque bolts to specs.
__________________
Peace,
Mark
91 XL 4x4 m5: KKM on BBK TB, 95tm, JBA headers, Magnaflow cats, Gibson exhaust, Duff shocks, Skyjacker 4" lift, 33" Duratracs. Plasma ignition, 97 disc rear end w/Aussie & 4:33 gears, 95 Ranger brakes spring/summer 2013.
malohnes is online now   Reply With Quote
Old 09-15-2012, 07:48 PM   #3
Anime
GREEN SCREAM!!
Hattiesburg, MS
Anime's Avatar
'93 Sport 4x4
Vehicle Specs
First make sure the leaking isn't just from the heater core/hose connection or something else. Then if you want to be sure where it's leaking from, use some engine cleaner and clean up the head/block area as much as you can, then inspect with the engine running and pinpoint your leak.
If it's not a head gasket and there's no oil/coolant leaks from the heads, you might just want to leave them alone. Generally if there is ANYthing wrong with the heads, it's best to just replace them with new, aftermarket heads. The stock heads, especially the 90TM versions on 91-92's, were not very thick or strong, and are known to crack if they ever get hot from cooling issues. New heads aren't all that expensive, ~$200 per side for a complete unit. If there's no cracks or damage though, you can just put 'em back on and just replace all the gaskets.
If you're doing anything to the heads you may as well replace the rocker arms as well, which causes the valve clatter noise from wear.
__________________
"I think man has always gone where he has been able to go, and I think that when man stops going where he can go, he will have lost a lot. Man has always been an explorer. To me, there's a fascination in thrusting out and going to new places. It's like going through a door because you find the door in front of you." - Michael Collins
Anime is offline   Reply With Quote
Old 09-16-2012, 01:40 PM   #4
tomjt714
Jefferson, PA
92Explorer XLT
Vehicle Specs
(Original Poster)
headjob redux
WaaaHOOOO. It WAS the lower intake manifold gasket. Now, does anyone out there have a good pic of just where to apply the RTV? Haynes does a piss poor job of detailing it. Also, does anyone know of a conversion factor from inch-lbs. to foot-lbs. I'm tore up and can't get anywhere til 2morrow to get a proper inch-lb. torque wrench to reinstall intakes. Have a whopper of a ft.-lb. though. Any ideas?
Did I really ask for inch/lbs - ft/lbs conversion? Sorry folks, I'm only THAT stupid when I'm killing myself to get something to drive to work the next day. Anyhoo, still got much to do. Lower intake says 16ft./lbs - I hit it at 20. Best reliable on me torker. I'll let you know how it turns out. Still got valve covers, Idler/tensioner assembly, godawful octopuss of vaccum-sensor-electrical, and radiator to get back in. Sounds like a sick Monday......
Old 09-16-2012, 01:43 PM   #5
waskly
Crooklyn NY!
Vehicle Specs
if its a 5.0l where the heads meet the block the corners should be silicone.
__________________
Quote:
Originally Posted by imp View Post
How do you get someone's "quote" to become your "signature"? imp
waskly is offline   Reply With Quote
Old 09-16-2012, 05:04 PM   #6
wood1
North of Ottawa
wood1's Avatar
'93 XLT, Cayman Green RIP
Vehicle Specs
Get a proper 1/4 torque wrench.
I smeared a skim of RTV around the water passages of the head and LIM before placing the gaskets. If you have cork gaskets for the front and back of the LIM discard them and use RTV. A good 1/4 bead and run it onto the head about 1/4 inch. It will smear out so don't worry. I had to trim a little bit of the LIM gasket so that the valve cover gasket would sit flat. Also a good smear at the corners of the valve cover gaskets. Also make sure you let it harden up before you start the engine. Over night should do it.
Great that it was the LIM gaskets and not the heads. Good for you!
__________________
Ribs. I had ribs for lunch, that's why I'm doing this.
List of useful TTB Threads
wood1 is offline   Reply With Quote
Old 09-16-2012, 10:13 PM   #7
malohnes
SE Alaska
malohnes's Avatar
'91 xl m5 4x4
Vehicle Specs
Good job! Glad to hear it was not a head or related issue. I followed Wood advice...works fine.
__________________
Peace,
Mark
Old 09-18-2012, 06:46 PM   #8
tomjt714
Jefferson, PA
92Explorer XLT
Vehicle Specs
(Original Poster)
Please read n help if possible
Part 3 of headjob. Found coolant leak at rear water jacket, passenger side LIM. Replaced gaskets from LIM up. Everything seemed fine. Old girl even ran I-79 for 16 miles @ 100+. No problems. Did final backflush 2day, put antifreeze/water 50% mix in, freeze plug back drivers side cylinder head pinholed. Am I chasing a ghost? Ready for gal gas/cig. Need vehicle in worst way, any/all thought appreciated. Pretty sure I can get old freeze plug out, replace with compression plug. But am I missing something?
'92 XLT, 4.0L, 5sp. manual
Thanks all.
Tomjt714
Old 09-18-2012, 09:29 PM   #9
Anime
GREEN SCREAM!!
Hattiesburg, MS
Anime's Avatar
'93 Sport 4x4
Vehicle Specs
You should keep all your related posts in one thread to get the most replies and useful help from the forum. Making a new post for every single step clutters up the forum and makes it so people can't help you out unless they seach for your previous theads. Make it easier on people to help you.
You can just replace the old freeze plugs with new ones. Get the yellow zinc ones if you can. Of course it would have been better to replace them with the cooling system already drained, and then you could have just flushed it that way.
__________________
Old 09-19-2012, 12:09 AM   #10
R&T Babich
Thousand Oaks, CA
'92 & '93 XLT 4DR
Vehicle Specs
Quote:
Originally Posted by Anime View Post
...You can just replace the old freeze plugs with new ones. Get the yellow zinc ones if you can. ...
Anime - any issues using brass freeze plugs?
I think most marine engines use them since they don't usually have antifreeze.
R&T Babich is offline   Reply With Quote
Old 09-19-2012, 09:03 AM   #11
Turdle
Old and in the way
Humboldt, Kansas
Turdle's Avatar
2000 Mounty
Vehicle Specs
I merged the 3 threads to help everyone stay on track. Please use one thread to avoid cluttering up the site, thanks!!
__________________
Jon
2000 Mountaineer
Turdle-gone
Vitamin D Wagon Sold also
Turdle is offline   Reply With Quote
Old 09-19-2012, 06:00 PM   #12
Anime
GREEN SCREAM!!
Hattiesburg, MS
Anime's Avatar
'93 Sport 4x4
Vehicle Specs
You can use brass freeze plugs, sure, but they are generally much, much more expensive than steel. Gold zinc plated steel plugs still give decent rust/corrosion protection without the expense of brass. Using engine primer/paint on plain steel plugs after installation is also a good cheap way of doing it.
__________________
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
headjob tomjt714 Stock 1991 - 1994 Explorers 2 09-15-2012 07:48 PM
Brakes redux, part 2! nitro71 Stock 1991 - 1994 Explorers 10 12-03-2009 12:00 PM
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
