| Need for Speed! Explorer, Ranger, Mountaineer 4.0 - 4.6 - 5.0 Nitrous, Superchargers, Camshafts, Head Work, Stroker Kits... DRAG RACING. Explorers, Mountaineers and Rangers CAN move! |
Thread Tools |
#21 |
Denver, CO
'92 Sport and AMG 300CE
I ran a 18.4 and yes the altitude does matter, our elevation is a mile over sea level. my reaction time was .707 and 2.79 60' 11.9 in the 1/8
__________________ 305/40r22 Nittos, KMC Rims, K&N, Granatelli MAF, BBK TB, Borla muffler & headers, Magnaflow Cat, 4" lift (Assorted Parts), 2 15" Eclipse Subs+Amps, 4.56 gear ratios, SCT 5 Program Chip, Warn Hubs, Paxton Supercharger SN2000, Port & Polished 95TM Heads+Lower Intake, 422 Cam, 30lbs Injectors, Snow Water Methanol Kit, Ready to Race!!! IF YOU GOTTA BE A MONKEY BE A GORILLA |
#22 |
Denver, CO
Oh and they did make v6 f150's
#23 |
va beach
92 SC
Whole different v6 and none was sc.you 60ft is not all that bad,i was expecting something crazy like 2.0 you just lost it on top end.what was your mph?yea alt has alot to do with it but if your tuned for it its not that huge,wouldn't think you lose a whole sec or more.if you run the track i would switch tires out to a lighter rim and does look like you need different gears
__________________ 92 xl 5.5"duff arms,3"BL,PJ 36x14.50,wrapped headers,side dump exhaust,.20 over,HF oil pump,422cam,45cc 95tm p+p 10.67:1 heads,p+p lower manifold,75mm TB,90mm maf,36lbs injectors,P+P GM M90 Supercharged & intercooled!!SCT tuned!!electric fan,4.88s aussie locked front & back!!next NOS&W/M
http://www.explorerforum.com/forums/...=double+vision |
#24 |
va beach
92 SC
#25 | |
Denver, CO
#26 |
va beach
92 SC
Where is you peak rpm?
#27 |
Denver, CO
well I have my dyno tune sheet from a mustang dynamometer from just over 2 years ago but i gotta say I've added water methanol since then. maximum power was at 4447rpm and torque at 3655rpm
#28 | |
Jackson, NJ
94 limited on 35's
Quote:
If you want a better 60', stage shallow. Roll into the 2nd beam very slowly and stop as soon as it flickers on. That will give you a few extra inches to gain speed before you leave the 2nd stage beam. Adjust your reaction time accordingly. __________________ 94 limited: 4.0l, 5spd swap, 6" skyjacker lift, 35x14.5 thornturds, 4.56s. 5.0 swap started (94 cobra 5.0, zf 5spd, np205) 95 xlt: stockish (SOHC swap, 30,000miles and I blew up the 3rd 4r55e...now collecting parts for a Cummins swap.) Cummins 4BT swap thread Ranger bed trailer build |
#29 |
Denver, CO
okay i not to smart on this, what is second stage beam?
#30 |
Jackson, NJ
94 limited on 35's
There are beams of light and sensors across your lane. The 1st beam of light that you drive into and block is the pre-stage beam. It turns on the 1st set of bulbs (pre-stage bulbs). The 2nd beam you block is the stage beam, it turns on the stage bulbs.
#31 |
Denver, CO
our local track will be shutting down soon, due to the snow season, but I'll try that next time i get a wednesday off, it sucks cause I work nights.... But I will start to get familiar with the track with the 5.0 I'm building up and gonna convert it into my benz, currently porting some gt40 heads in the basement right now for it.
#32 |
va beach
92 SC
I would take it back to the tune shop and have them write you a race tune and adjust the other two tunes for w/m.you should pick up alot of power after retune .do you have a way of measuring intake air temps?also i would only go down to 4.10 with that rpm range.
#33 |
Denver, CO
I really don't want to deal with that shop anymore. They kept telling me I need a new this and that over and over again throwing parts at it. I swear I spent over $3k dealing with themjust in tuning crap. They were wanting me to put my stock stuff all back on and 5hit like that. The few other places I been to act dumb when I tell them I have a supercharged v6 explorer. I'd love to have a forum Guy do it but I guess I am way too far for everybody
#34 |
Denver, CO
If I did change the gears would that affect the dynotune at all?
#35 |
va beach
92 SC
Nope.w/m does tho.
#36 |
Denver, CO
You know I gotta ask y?
#37 |
va beach
92 SC
Cooler intake temps.you can add more timing and fuel in safely .you could see alot more power.
#38 |
Supercharged OHV
Winnipeg, Manitoba
00 Explorer XLT 4.0 OHV
Here's a thread that has an interesting tire size/gearing chart link posted.
http://www.explorerforum.com/forums/...d.php?t=369386 __________________ Rebuilt 4.0 OHV with about 6000 kilometers. M90 Supercharged. Tuned by James Henson. 422 cam, dual rate springs, si valves, polished combustion chambers, Rebuilt lifters and 30 thou shaved heads. Headers, and custom exhaust. Water/meth injection. Aftermarket projector headlights w HID's. Electric fan. DELTA RV CAM FOR SALE. low miles on it. |
#39 |
Denver, CO
Wow that means 4.10 is the way to go, I guess most of us didn't notice the gap between 4.10 and 4.56, theres even another ratio between them.
#40 |
Supercharged OHV
Winnipeg, Manitoba
surprising.
Based on that chart, I have 342 gears. I need to climb underneath and have a look at what the tag says on my diff. It would be a great check for accuracy of the chart. __________________ Rebuilt 4.0 OHV with about 6000 kilometers. M90 Supercharged. Tuned by James Henson. 422 cam, dual rate springs, si valves, polished combustion chambers, Rebuilt lifters and 30 thou shaved heads. Headers, and custom exhaust. Water/meth injection. Aftermarket projector headlights w HID's. Electric fan. DELTA RV CAM FOR SALE. low miles on it. |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| EEC-IV 2 and 3 digit trouble codes. | BrooklynBay | EEC IV | 16 | 03-26-2012 09:46 PM |
| 1995 Ford Explorer XLT rear end replacement? | tikisurfgod | Under the Hood | 5 | 09-12-2008 09:33 PM |
| So i want to know my gear ratio (rear end) | Xan | Modified 1995-2001 Explorers | 1 | 05-28-2007 02:19 PM |
| 95 Ex front and rear end, What's it worth? | jeremy white | Explorer - Ranger Shocks, Suspensions, Lift Kits | 3 | 01-12-2003 02:37 PM |
| rear end higher than front after 2" lift from skyjacker : help | rocky | Explorer - Ranger Shocks, Suspensions, Lift Kits | 3 | 04-13-1999 03:19 PM |
| Thread Tools | |
