Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2006 - 2010 Explorer Mountaineer 4th Generation > Stock 2006 -2010 Explorers
Notices
Stock 2006 -2010 Explorers Stock 2006 -2010 Ford Explorer Forum. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
Warranty Repair Issues -Help with Code P0420
Reply
Thread Tools
Old 09-17-2012, 11:44 AM   #1
carbonmark
2007 Explorer EB V8
Vehicle Specs
(Original Poster)
Thumbs up Help with Code P0420 - 2007 Explorer (fixed)
I have a 2007 Explorer EB that has a check engine code p0420 showing. I believe the issue is with the catylitic converter but I am not sure. I have talked to the Ford dealership and was told the warranty was expired.
The part itself cost $1300 from Ford so any ideas on other fixes?
carbonmark is offline   Reply With Quote
Old 09-20-2012, 01:21 PM   #2
carbonmark
2007 Explorer EB V8
Vehicle Specs
(Original Poster)
Issue Resolved. After doing some more online research I found out that the Emissions Defect Warranty covers this vehicle for up to 8 years or 80,000 miles. Oddly enough, I talked to 2 different dealerships and Ford HQ customer service and none of the people were aware of this warranty. Luckily, after finding the info online, a tech at the service shop was able to help me. I will now be getting the cat put on at no cost.
For any others that may find this thread looking for some direction, here is what I learned in the process.
1) P0420 - the code by itself will most likely reference a bad cat. There is also a chance it is an O2 sensor, vacuum leak, or manifold issue I believe. A good way to see if it is an O2 sensor is to switch the sensors, clear the code, and see if it comes up on the opposite side. If it stays on the same side then the sensor is not the problem.
2) The cat is a very expensive piece. I personally would have been more likely to replace the exhause with aftermarket cats and MIL eliminators had it not been for the warranty coverage.
3) Cleaning the cat might be an option. Do some searches online about cleaning the cat. I was able to find a process that used hot water and a chemical in the bathtub. Some people had success with this. It would be worth a shot if you are trying to save the money.
Hopefully this helps someone in the future.
Old 09-20-2012, 06:47 PM   #3
waskly
Crooklyn NY!
Vehicle Specs
cali emission is 8/80 all other is 7/70. just a fyi.
__________________
Quote:
Originally Posted by imp View Post
How do you get someone's "quote" to become your "signature"? imp
waskly is offline   Reply With Quote
Old 09-20-2012, 11:08 PM   #4
carbonmark
2007 Explorer EB V8
Vehicle Specs
(Original Poster)
That is not my understanding. 8/80 should be everywhere. For instance, I am in Kansas.
Old 09-21-2012, 10:20 AM   #5
Town
Ottawa, Ontario, Canada
2007 Lincoln Town Car
Vehicle Specs
Quote:
I think you are correct. The US Federal emmissions warranty requires Ford to cover Catalytic Converters for 8 years or 80,000 miles (whichever comes first). The California emmissions warranty requires Ford to cover catalytic converters for 7 years or 70,000 miles (whichever comes first).
Here is the reference site for Ford owner's manual, maintenance and warranty information: https://www.fleet.ford.com/maintenan...ls/default.asp
Town is offline   Reply With Quote
Old 09-21-2012, 04:37 PM   #6
waskly
Crooklyn NY!
Vehicle Specs
one more time, if the vehicle is build with cali emmision its 8/80 if its federal 7/70.
does not mean you have to be in cali to get 8/80 it means it was built to cali emmisions.
your understanding is wrong. its based on the car not location.
if it was a toyota it would be based on location.
__________________
Old 09-21-2012, 11:29 PM   #7
carbonmark
2007 Explorer EB V8
Vehicle Specs
(Original Poster)
I see what you are saying now. What I meant to notate in the first post was that the 2007 explorer is covered, not to confuse that with all makes and models.
Old 09-22-2012, 12:02 AM   #8
waskly
Crooklyn NY!
Vehicle Specs
all vehicles, under 7500 lbs or 8500 lbs emissions coverage is 7/70 or 8/80
the same way restraint is 5/50 or 6/60.
alot of this are still in warranty after the 3/36.
__________________
Reply
Tags
cat, catylitic, converter, p0420, warranty
Similar Threads
Thread Thread Starter Forum Replies Last Post
code p0420 low cat efficiency snicklfritz Stock 1995 - 2001 Explorers 17 08-30-2012 09:59 AM
PO420 code issues. Bob Brown EEC V 4 01-10-2009 10:11 AM
01 x, 4wd wont engage offrdsnwbrd4 Modified 1995-2001 Explorers 10 05-17-2006 12:18 AM
ex not idling, p0420 code....related? mcompton1973 Under the Hood 7 01-04-2005 01:32 PM
Ford Cuts Back on Warranty Repairs Stephen Ford Industry News 12 06-20-2000 08:40 PM
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
