| Stock 2011 - 2014 Ford Explorer Discussion 2011 - 2013 Ford Explorer problem solving, maintenance, TSB, service bulletins, owner reviews, specifications, Ecoboost. |
Thread Tools |
#1 |
Wannabe Elite Explorer
Washington DC Area
'11 Bordoux Red LTD
Do I have dry rot on my '11 tires already?
I was looking at the tires of my '11 explorer the other day and noticed cracks forming on all 4 tires at the sidewall/tread union covering nearly 80% of the circumference.
Is this dry rot or something else? ![]()
#2 |
Georgia
97 XLT and 91 Ranger
Looks like you're cornering a lil fast! Good job, glad to see someone else wearing the outsides
#3 | |
Toyota Highlander Convert
Ottawa, Ontario area
2011 Limited AWD
Quote:
I also have a 2011 with only 6500 miles on it and I had to have an alignment done a few months ago. My 3 previous Highlanders all had to have alignments done within 2 years of getting them. Peter __________________ Peter Explorer Limited White Platinum Tri-Coat,340A (Rapid Spec 302A).Previous rides;'99 Windstar; '02,'06 & 09 4WD Toyota Highlander Limiteds |
#4 |
Georgia
^ you can tell that isn't the alignment. Just simply pushing the sides of the tires down while whipping around turns
#5 | |
2011 Limited AWD
#6 |
Georgia
Good point, but it definitely doesn't look like an alignment issue to me. Maybe just wacking alot of curbs
#7 |
2013 Explorer Limited
those are call Ozone crack. I had them warranty replaced before on my wife's car. The crack occured on the sidewall near the rim.
The car had 6000 miles when it occured. Here's what i did. 1. I called michelin and told them about the issue and got a claim number 2. Went to michelin authorize dealer (discount tire) for confirmation and validation 3. michelin prorated me back the cost of the tires at 90%. Because the tire is a 65k mile tire and I drove 6k of it. 4. Got a new set of michelin. paid 10% + mounting and balance. Well, you can also start talking about firestone and explorer. They might think twice. You should check your Hankook warranty booklet. |
#8 |
New England
2011 Explorer xlt
I have not had an alignment on any vehicle in decades.......and During that time I have hundreds of thousands of miles
That picture above is driving way to fast into corners...... __________________ 2011 Explorer XLT Tri-White plat. Dual panel sun roof, Rapid spec 202a package, tan interior, 20" polished aluminum wheels, tow package, cross rails for roof, Husky mats throughout & Thule 2100. Built June 23rd |
#9 |
Georgia
no. that's not dry rot.
__________________ I reject your reality & substitute my own... 2001 Explorer Eddie Bauer 5.0L V8 auto 2WD 2000 Mountaineer 5.0L V8 auto 2WD 2000 Mountaineer 5.0L V8 auto AWD 2001 Explorer XLT 4.0L SOHC V6 auto 2WD |
#10 |
Chicago Area
2011 Explorer Limited
It's not dry rot.
It's not ozone crack. It's not an alignment issue. It is normal. I have it, too. I corner very hard at times. My tires have over 52,000 miles, and are doing great! |
#11 |
Washington DC Area
'11 Bordoux Red LTD
Driving in DC traffic I do tend to have to whip around to avoid getting run over. Thanks for all the feedback. Haven't done an alignment on the car since purchasing it but I'm sure it could use one.
As long as it doesn't look like an issue, I'll just keep an eye on the cracks to make sure it doesn't get worse. |
#12 |
Chicago Area
Maybe check your tire pressures.
#13 | |
2011 Limited AWD
#14 | |
2011 Limited
Quote:
#15 | ||
Chicago Area
Quote:
Quote:
The OP needs to be dilligent with checking tires pressures (35 PSI) and tire rotations (every 7-10,000 miles). |
#16 | |
2011 Limited AWD
Quote:
![]() Peter __________________ Peter Explorer Limited White Platinum Tri-Coat,340A (Rapid Spec 302A).Previous rides;'99 Windstar; '02,'06 & 09 4WD Toyota Highlander Limiteds |
#17 |
Washington DC Area
'11 Bordoux Red LTD
Just checked and pressure was down to 30-32 PSI in all the tires. Checking once a month doesn't appear to be often enough.
#18 |
Georgia
As temps drop outside so will the tire pressure. Also make sure the tires are cold when you check.
Regardless, that wear has nothing to do with tire pressure. |
#19 |
Winchester, VA
2011 XLT
#20 | |
Chicago Area
Quote:
As for #3, I disagree. The combination of lower than ideal tire pressures, combined with an aggressive driving style (hard corning and tail braking) will allow that tire shoulder to roll over more, and create that wear pattern. This is further enhanced by the Explorer's +6,000 pounds riding on a low-profile 20" tire. The tires never really get that hot either. For example with some of my sports cars, this wear is evident, but does not exhibite the "scaled" look. It's more "polished" and rounded because the tires can get very hot & sticky.....plus they corner better than an Explorer (thank God!).
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Continental tires..my experience | b33p3rmcg | Stock 1995 - 2001 Explorers | 7 | 05-02-2011 02:42 PM |
| FYI: KUMHO recall Venture HT and AT light truck tires | toypaseo | Ford Explorer - Ranger Tires & Wheels | 0 | 08-02-2006 06:41 PM |
| Help with bigger tires please?? | LOWPROEXPLORER | Explorer - Ranger Shocks, Suspensions, Lift Kits | 8 | 05-22-2006 04:17 PM |
| URGENT! Those who replaced Wilderness AT with tires not on the ford tire list | 97 Eddie Bauer v8 | Ford Explorer - Ranger Tires & Wheels | 21 | 10-04-2001 09:49 PM |
| Thread Tools | |
