#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Under the Hood
Notices
Under the Hood Ford Explorer and Ranger, Engine, troubleshooting, modifications, performance and accessories.
Where is the horn? 1999 Ford Explorer Sport
Reply
Thread Tools
Old 10-12-2012, 10:43 AM   #1
chuckwagon101
Texas
1999 Explorer sport
Vehicle Specs
Quoted: 13 Post(s)
(Original Poster)
I CANNOT find the horn in my 1999 Ford Explorer Sport.
I was going to install an aftermarket horn but after several responsed I am going to try to FIX the existing horn.
I cannot locate the horn. Manual has nothing on it.
If you know where the horn is located, give me a heads up!
Thank you!
Chuckwagon
chuckwagon101 is offline   Reply With Quote
( Join the Elite Explorers )
Old 10-12-2012, 04:49 PM   #2
2000StreetRod
Greenville, SC
2000StreetRod's Avatar
00 Sport FI,03 Limited V8
Vehicle Specs
Quoted: 45 Post(s)
radiator support
left front of radiator support. I'm glad you decided to try and fix it.
2000StreetRod is offline   Reply With Quote
Old 10-12-2012, 08:41 PM   #3
chuckwagon101
Texas
1999 Explorer sport
Vehicle Specs
Quoted: 13 Post(s)
(Original Poster)
Do I go in from the bottom, top, front.
I have looked all around that area and do not see that horn.
Is it hidden behind anything?
If you can give me a clue on how to get to it......would be great.
I spent an hour this morning removing the shroud under the radiator, the left front tire......saw nothing but parking light and headlight connections.
Thanks for any more detailed help.
Chuckwagon
Old 10-12-2012, 09:21 PM   #4
swshawaii
Kailua-Oahu, Hawaii
'05 Sport Trac XLS (RWD)
Vehicle Specs
Quoted: 862 Post(s)
Do you have a sight shield (tool tray) above the radiator?
Horn may be directly under that, next to the hood latch.
http://www.trademotion.com/parts/199...Sight%20shield
swshawaii is offline   Reply With Quote
Old 10-12-2012, 09:33 PM   #5
chuckwagon101
Texas
1999 Explorer sport
Vehicle Specs
Quoted: 13 Post(s)
(Original Poster)
Yes, the vehicle has something that looks like that.
So I should just take out all the screws/bolts holding it on and look under there?
Will do that tomorrow for sure!
Thanks a lot! I'm excited!
I need to get that horn fixed ........PRONTO!
Old 10-12-2012, 09:39 PM   #6
swshawaii
Kailua-Oahu, Hawaii
Vehicle Specs
Quoted: 862 Post(s)
10-4. Also a good time to clean the crispy critters off the radiator.
Old 10-13-2012, 03:18 PM   #7
chuckwagon101
Texas
1999 Explorer sport
Vehicle Specs
Quoted: 13 Post(s)
(Original Poster)
Nothing under the sight shield.
Old 10-13-2012, 03:21 PM   #8
chuckwagon101
Texas
1999 Explorer sport
Vehicle Specs
Quoted: 13 Post(s)
(Original Poster)
Quote:
I find nothing in the left front radiator support.
Old 10-13-2012, 03:41 PM   #9
chuckwagon101
Texas
1999 Explorer sport
Vehicle Specs
Quoted: 13 Post(s)
(Original Poster)
I still cannot find the horn's location.
Here is what I did......I pressed the horn actuator button on the Master Key and the lights started flashing.
There was a clicking from the under-hood fuse box that kept time with the lights flashing. No horn sound.
I had a helper press the horn button and a "click" was heard each time from the under-hood fuse box.
Does this information help in any way as to why the horn will not blow?
I really need to find the LOCATION of that horn. This is frustrating.
Thanks for any info
Old 10-13-2012, 03:50 PM   #10
4pullingGM
Princeton, Illinois
Stand on it!
Vehicle Specs
Quoted: 25 Post(s)
It should be on the left side of the radiator support, but down towards the bottom. Easiest way to get to it would be from the wheel well. You'll prolly hafta pull the inner fender back a bit to get to it.
__________________
Wheeler; 97 Explorer Sport, 4.0 sohc, bw 1354 manual shift tcase, EB dana 44 front, 4.56's, both axles locked, 36x13.50 Irok's 12,000 lb milemarker winch.
Driver/tow rig; 97 F350 crew cab 4x4, 7.3, 305/70-16 BFG AT's, 9,000 lb winch, toolbox and a trailer hitch.
4pullingGM is offline   Reply With Quote
Old 10-13-2012, 05:41 PM   #11
ssobel80
New Jersey
2000 Ford Explorer XLS
Vehicle Specs
Quoted: 0 Post(s)
Maybe that is why it doesn't work? Cause it isn't there!
I don't know where it is but I am curious now gonna go take a look at mine and see if I can find it.
ssobel80 is offline   Reply With Quote
Old 10-13-2012, 05:48 PM   #12
swshawaii
Kailua-Oahu, Hawaii
Vehicle Specs
Quoted: 862 Post(s)
Sorry, I didn't realize there were different horn locations.
This is for the Sport Trac, thought they were the same.
http://www.mysporttrac.com/shared/ms...me=mysporttrac
Old 10-14-2012, 07:40 AM   #13
chuckwagon101
Texas
1999 Explorer sport
Vehicle Specs
Quoted: 13 Post(s)
(Original Poster)
I still have not found the horn's location.
My vehicle is a Ford Explorer "sport".
It is 4 wheel drive
6 cylinder .......SOHC
What shape is the horn? So far, all I have seen is the parking and headlight modules in the areas that various posters have suggested that the horn might be located.
I get a "sound" from the fuse box under the hood when a helper presses the horn button.....a definite "click".
Does this mean that my steering wheel connection is ok?
I feel that I can check out the horn with a jumper wire to the battery if I COULD ONLY LOCATE THE HORN.
Let me know if you have information that will help me find this horn.
Thank you, Chuckwagon
Old 10-14-2012, 08:44 AM   #14
scucci
98 Sport
Vehicle Specs
Quoted: 1 Post(s)
My 98 has the horn on the frame rail down under the battery. Easiest to get under the vehicle to replace it.
scucci is offline   Reply With Quote
Old 10-14-2012, 08:53 AM   #15
chuckwagon101
Texas
1999 Explorer sport
Vehicle Specs
Quoted: 13 Post(s)
(Original Poster)
Quote:
Do you have to remove the splash shield in order to see or remove the horn?
Old 10-14-2012, 03:56 PM   #16
swshawaii
Kailua-Oahu, Hawaii
Vehicle Specs
Quoted: 862 Post(s)
R & R may be easier said than done.
http://www.explorerforum.com/forums/...18&postcount=8
Old 10-14-2012, 04:09 PM   #17
chuckwagon101
Texas
1999 Explorer sport
Vehicle Specs
Quoted: 13 Post(s)
(Original Poster)
My vehicle is a 1999 Ford Explorer SPORT
There is nothing under my hood like what is in the diagram that you sent.
Thanks for trying.
I still cannot find the horn.
Old 10-14-2012, 04:14 PM   #18
swshawaii
Kailua-Oahu, Hawaii
Vehicle Specs
Quoted: 862 Post(s)
Have you physically looked behind the drivers side fender apron?
Old 10-14-2012, 04:18 PM   #19
chuckwagon101
Texas
1999 Explorer sport
Vehicle Specs
Quoted: 13 Post(s)
(Original Poster)
Have you physically moved and looked behind the drivers side fender apron?
Yes.....the front part only.....not the entire shroud in the fender.
I saw nothing that could be a horn.
Old 10-14-2012, 11:47 PM   #20
4pullingGM
Princeton, Illinois
Stand on it!
Vehicle Specs
Quoted: 25 Post(s)
The horns should look something like this, should be in the left front, ill get pictures of where mine are at tomorrow
__________________
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
2007 Explorer Sport Trac Press Kit Rick Auto Industry News 46 10-14-2010 07:42 PM
1999 Ford Explorer Sport seat belt & door ajar alarm keep beeping. djdavis Stock 1995 - 2001 Explorers 5 09-22-2010 12:27 PM
1999 Ford Explorer Sport, No Reverse. cobrasvt Explorer & Ranger Transmissions, Transfer Cases, & Differentials 4 02-18-2009 08:59 PM
2002 Explorer: Many refinements and new devices Rick Auto Industry News 2 03-08-2004 02:26 PM
1999 Ford Explorer Sport WillieChu Explorer Registry 0 08-10-2000 03:07 PM
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
