Front Upper Control Arms Bushings: ¿Individually available? | Ford Explorer Forums - Serious Explorations
iharting
Caracas
'07 Eddie Bauer
Hi!
My ´07 EB needs new front upper control arms bushings, so I´m looking for them and would like to know if anyone has replaced them with Moog´s K200356 bushing kit or I will have to buy the whole UCA´s.
Best regards!
Eeeeeeeerrrrrrrrrrrrrrrrrrrrrrr... Already bought one pair of UCA´s...
But still I´m thinking installing the Moog UCA bushing kit would be a good idea...
Don´t mind, just talking to myself!
Thanks swshawaii!!!
Yes, since I´ve already ordered a pair of new UCA´s, I´ll take the old ones to the shop with the bushings to install them and keep a "reserve pair". I asked because I´m curious about the Moog bushing kit, cause I´m used to change the bushings and not the entire control arm. ¡Sign of the times we´re living!
Best regards!
The problem with replacing the factory upper control arms is the usually required
camber adjuster kits and wheel alignment by far exceeds the cost of both UCA's. :mad:
i replace arms, new upper ball joint is the perk with it.
