Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Ranger - Mazda B-Series Forum > Ford Ranger - Mazda B-Series Forum
Notices
Ford Ranger - Mazda B-Series Forum Ford Ranger and Mazda B Series forums. The Mazda B2300 B3000 and B4000 are clones of the Ford Ranger, with all systems the same. The only differences are trim and a few body parts. This forum discusses Ford Ranger and Mazda B series specific issues. Owners of the older Mazda B2000 B2200 and B2600 are welcome as well.
97 Mazda B-4000 Turn Signals and Hazard Flasher are out, not Fuses
Reply
Thread Tools
Old 10-25-2012, 01:15 PM   #1
cobrajocky
Orange County, CA
1997 Mazda B-4000 Xtr Cab
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
US 97 Mazda B-4000 Turn Signals and Hazard Flasher are out, not Fuses
I have a '97 Mazda B-4000, Xtra Cab, Automatic Trans (same as the Equiv Ranger w/ 4-Litre V6) and I have no Turn signals or Hazard light. Nothing else seems to have failed. I've pulled fuses at 21 and 22 in the dash driver side Fuse Box and both are fine, even checked them on a DMM. If I recall, this did not happened as a sudden total failure, I think a few times I put on the turn signals and they weren't working in between times they did work. The steering column turn "arm" does pop back to center position after making a turn and I hear a contact in the switch making a connection - but not signals. The Hazard flasher is also not functioning and I believe it went out at the same time, but can't be sure since I rarely used it. There is no signal ticking sound. All the turn signal bulbs are good.
I can't seem to find any information WHERE the Turn Signal Flasher Relay is at. The Chilton manual is useless, only refers to a location up to 1995 models. I've looked under the dash driver side and don't see anything. Does anyone know precisely where it is and how to replace it? Does it control the Hazard Flasher too?
Also confused about the "Multi Switch" - is that as separate module and where is it located, or is that actually the whole control arm assembly on the steering column??
Would appreciate some expert advice.
If you great helpers know what component has failed, could you add a part number or proper name so I can Google for the part, and suggestions where best to find it cheap? Money's tight in retirement ... or just living.
cobrajocky is offline   Reply With Quote
( Join the Elite Explorers )
Old 10-27-2012, 01:37 PM   #2
Jack Flash
Ethel, MS
(3) '88 BII's, '99 Ranger
Vehicle Specs
Quoted: 2 Post(s)
look up multifunction switch here: www.rockauto.com <---click on pic & it enlarges (somewhat)
__________________
Jack of All Trades
Retired From Most
www.internationalcuemakers.com
www.jimboarmy.com
Latest Project: '86 Ranger 4X4
Jack Flash is offline   Reply With Quote
Old 10-30-2012, 11:35 PM   #3
cobrajocky
Orange County, CA
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Turned out the it's a bad Hazard Flasher button assembly shorting out the whole Turn / Hazard flasher system. It's not the multi-function switch.
Old 04-04-2013, 04:20 PM   #4
rwtqq256
east providence
97 madza b2300
Vehicle Specs
Quoted: 0 Post(s)
97 mazda
If u look in the haynes manuel it will show that the turn singal flasher relay is located under the instrument panel to the tight of the steering column
rwtqq256 is offline   Reply With Quote
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
Tip: Hazard lights work, turn signals don't Kamel Stock 1991 - 1994 Explorers 4 07-22-2015 04:25 PM
97 XLT, no turn signals or hazards! DavidDulin Stock 1995 - 2001 Explorers 3 10-25-2011 09:51 AM
Help! No brake lights, turn signals or hazard lights. gsmann Aerostar Forum 4 10-27-2010 07:48 PM
Turn signals not working jimirig Stock 1995 - 2001 Explorers 6 08-13-2008 08:18 PM
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
