Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
Heater blowing COLD air!
Reply
Thread Tools
Old 10-28-2012, 05:49 PM   #1
lbiermann77
St Louis, MO
2000 Ford Explorer ebauer
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Yikes! So yesterday was the first day that I was officially cold enough to turn on the heat in my 2000 Explorer Eddie Bauer, V6, 4.0L, SOHC. I've checked my fluids and they are good.
What should I be looking for? I've been told about some kind of "door" but nobody knows what it's called. I've also been told to look at a valve that you can access via the glove box. I do not have any fluids spraying all over the inside of my truck, so I think the core is probably not clogged.
The air blows perfectly fine, it just blows COLD. And it's almost November in Missouri, so I'm going to be needing my heat.
lbiermann77 is offline   Reply With Quote
( Join the Elite Explorers )
Old 10-28-2012, 05:56 PM   #2
stpierre
Laconia N.H.
2002 Explorer xlt V8
Vehicle Specs
Quoted: 0 Post(s)
You need a blend door.
http://www.ebay.com/itm/Ford-Explore...92a62e&vxp=mtr
stpierre is offline   Reply With Quote
Old 10-28-2012, 06:24 PM   #3
lbiermann77
St Louis, MO
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Thank you! I assume this is something I can fix myself as long as I can read directions!
Old 10-28-2012, 07:38 PM   #4
stpierre
Laconia N.H.
Vehicle Specs
Quoted: 0 Post(s)
Quote:
http://www.explorerforum.com/forums/...d.php?t=373255
Old 10-28-2012, 07:40 PM   #5
stpierre
Laconia N.H.
Vehicle Specs
Quoted: 0 Post(s)
Sorry the link I sent you is not what you want!!! I got it and it dint work.I got one from a auto parts for $54.
Old 10-28-2012, 07:40 PM   #6
deweyville65
Dewey,Az
96 EXPLORER XLT
Vehicle Specs
Quoted: 30 Post(s)
Can only be two things wrong here. Either hot water is not circulating through the heater core, or the infamous blend door. No circulation is either the heater control valve in the engine compartment, or possibly a bad thermostat, in which case the temp gage would show no heat. I am assuming you have a heater control valve, like my 96. The blend door is located in the heater A/C box behind the dash. I have never had any experience with it.
deweyville65 is offline   Reply With Quote
Old 10-28-2012, 07:44 PM   #7
stpierre
Laconia N.H.
Vehicle Specs
Quoted: 0 Post(s)
Sorry I have a 2002 not the same.
Old 10-29-2012, 06:53 PM   #8
rollinstone
1997 Ford Explorer XLT
Vehicle Specs
Quoted: 8 Post(s)
Try this link...worked for me. Go to Frame #18:
http://www.explorerforum.com/forums/...ght=blend+door
most of the time the problem is with the blend door, not the actuator. You can check the actuator by sitting in the driver's seat in a quiet place, turn off everything, put the ignition in "accessory" mode, then turn the heater reostat knob. If the actuator is working you should be able to hear it everytime you turn the reostat.
The connector on the blend door is a cheap piece of plastic hinge prone to breaking after years of use.
I did the cutout method. It's a PITA, but man will you be a happy camper when the job is done. I ordered the blend door kit from RockAuto for about $17 incl shipping.
Be sure when you put the new door in that it snaps into place on the actuator. If done correctly it should hang there.
__________________
Gary S. 97 XLT AWD 5.0L
rollinstone is offline   Reply With Quote
Old 10-29-2012, 07:01 PM   #9
bobberguy
tallahassee fl
93 ford explorer
Vehicle Specs
Quoted: 0 Post(s)
When you move the switch from cold to hot you should here something move you might be able to get under the hood and try to.manually switch it from cold to hot by the firewall
bobberguy is offline   Reply With Quote
Old 11-17-2012, 11:47 PM   #10
lbiermann77
St Louis, MO
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Thermostat replaced, still no heat. Thermo was bad, though, so that worked out. Blend door was jammed, and the motor that controls the actuator is burned up. Had door duct taped in the open position so that I was getting heat, but after 4 days, it's back to blowing cold air.
I think this is going to be a bigger problem than I am willing / financially able to fix. I smell a trade-in in my future.
Reply
Tags
baby it's cold inside, heater blowing cold
Similar Threads
Thread Thread Starter Forum Replies Last Post
HELP! Accidently hit the screen behind my grille and cold air is blowing out fast! ah bpl09 Under the Hood 17 08-07-2009 10:54 AM
95 Ranger Heater blows cold air crags Ford Ranger - Mazda B-Series Forum 6 12-08-2008 07:19 AM
Granatelli MAF CODE due to cold AIR Stanleyjd Modified 1995-2001 Explorers 7 12-22-2007 12:13 AM
Might this make your cold air intake... Colder?? Rayz2000Sport Modified 1995-2001 Explorers 18 11-24-2007 12:30 AM
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
