AKHNTR
- October 30, 2012
- AK
- 1991 Ranger
Hello, we're troubleshooting a starting issue (no crank) and could really use a diagram (and simpleton explanation) showing wiring for the starting system. It's a 91 XLT 2.9L manual trans. New starter relay installed, newer batt checked out, all grounds and pos cables cleaned, starter engages/eng runs, when starter relay "jumped". Lights do not dim when in "start" pos. Do not have 12v at the small pin on start relay when start switch to "start". That's the problem, if I understand it?? Now trying to track the wires back to the faulty part/wire. I'm just not sure where that 12v pin power comes from/through on the way in...have a test meter. Suspect the ignition switch is faulty, how do you test this. I just installed new clutch master cyl assy. but this truck sat all last winter and then stopped starting before the mast. cyl r&r...this is my 16 yo daughter's first truck, trying to get her on the road, any help appreciated. Thanks
