Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
Even OEM fob won't program! :/
Reply
Thread Tools
Old 11-07-2012, 05:37 PM   #1
newmission
Toledo, Ohio
99 Explorer XLT 5.0 AWD
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
First off, hello to everyone! It's a pleasure.
I just decided to switch SUVs from a Blazer, to an Explorer because I was tired to fixing everything that shook itself apart on the Blazer! So far the EX has been a beast!
My EX came with an aftermarket remote, and a single key. I personally like things to be as factory as possible for functionality, and resale purposes. So I ventured out and bought a set off fobs off Amazon.
Went through the procedure to program them, cycle the ignition eight times and press lock button on each remote. OK. Seemed simple enough, and worked without an issue.
However the only remote that "worked" was the aftermarket one. The other two (new) remotes would only cycle the lock on the driver's door, and when "locked" the THEFT light would stay on and no locks would actuate.
Great! ...So I called the dealer, got the part number, went on eBay and bought two OEM remotes. When they arrived, I programmed the same and got the same results. ...Unlocking only the driver's door, and when "lock" button was pressed, the THEFT light would stay on with no other actions.
So here's what I have. Anyone ever seen a remote like this? I know my 99 EX XLT has factory keyless entry because it does go into programming mode like it should.
newmission is offline   Reply With Quote
( Join the Elite Explorers )
Old 11-07-2012, 06:38 PM   #2
budwich
Ottawa, Ont
96 XL
Vehicle Specs
Quoted: 0 Post(s)
I think you need to press the unlock a second time... :-) I think one press equals driver's door, two press equals all doors.
budwich is offline   Reply With Quote
Old 11-07-2012, 07:47 PM   #3
newmission
Toledo, Ohio
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Quote:
Sound logical. However the aftermarket remote only requires one press for all doors. And that still leaves the question as to why the THEFT light stays on after pressing the lock button but nothing locks.
Old 11-07-2012, 08:14 PM   #4
budwich
Ottawa, Ont
96 XL
Vehicle Specs
Quoted: 0 Post(s)
cause locking the doors isn't connected "wire wise" to the light. Its an operation that the system doesn't know failed (or not), its "programmed" to start flashing the theft light. As for oem versus after market, I guess the aftermarket guys didn't read the ford operator's manual... :-)
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
Reprogram key fob? shagr15 Stock 1995 - 2001 Explorers 3 07-07-2011 01:29 PM
Programming a new FOB -failing at it. Dario Stock 2002 - 2005 Explorers 18 12-31-2010 04:03 PM
No key fob for my Explorer. Help please. mick9264 UK Explorer Owners Forum 9 11-12-2010 12:42 PM
OEM or aftermarket alternator for 2000 Mountaineer V6? heavymg08 Stock 1995 - 2001 Explorers 6 09-26-2010 02:52 PM
1991 - 1994 Ford Explorer 4x4 Auto Locking OEM 4wd Hub Pair 1ATony Explorerforum Vendors 0 08-31-2010 02:13 PM
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
