Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
2000 ranger lean bank 1
Reply
Thread Tools
Old 11-10-2012, 06:08 PM   #1
stren_g
ne
2003, 2000
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I've done many searches previously for a lean bank 2 problem. I found a vacuum leak at the upper intake manifold, so I replaced the gaskets. Cool, cel went off for a while and then came back on with p0171 code. I read that this is lean bank 1, I couldn't find any vacuum leaks this time so I cleaned the maf and iacv, no dice. What could be causing this? Could it be o2 sensors, should I check fuel pressure, or...? Is there a way to check the o2 sensors?
stren_g is offline   Reply With Quote
( Join the Elite Explorers )
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
2006 keyless entry jgr1950 Stock 2006 -2010 Explorers 34 08-10-2012 12:47 PM
EEC-IV 2 and 3 digit trouble codes. BrooklynBay EEC IV 16 03-26-2012 09:46 PM
ford manufacturer specific codes whale45714 Stock 1995 - 2001 Explorers 0 04-16-2011 10:03 AM
2000 ex lean bank 1 &2 codes scanner readings joe doe Stock 1995 - 2001 Explorers 5 11-24-2006 07:14 PM
lean condition bank 1 ny50 Under the Hood 6 07-27-2006 09:53 PM
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
