2008 Explorer interior lights won't turn off | Ford Explorer Forums
CajunCharlie
Lafayette, LA
2008 Explorer XLT Ironman
I have a 2008 Explorer XLT Ironman Edition. The interior lights come on when you open the door, but instead of quickly dimming to off once engine is started, they will stay on up to 30 minutes. I can turn the engine off and leave the vehicle and they still will not shut off instantly. Also, they appear weaker than before.
Hello and Welcome!!! As far as your issue is concerned its a fairly common issue and you just need to replace you ignition switch, (not the part the key goes in). here is a link to the part! http://shop.advanceautoparts.com/we...9-p?navigationPath=L1*14920|L2*15005|L3*15657
And here is a link on how to fix it with the above part!!!! http://www.explorerforum.com/forums/showthread.php?t=368379&highlight=dome+light
You local part store should have it. Another good source that offers low priced parts is Rockauto.com
Fixed it!
Sorry for the lateness of this reply. I changed out the ignition switch just as polizi212 recommended. Everything works great now. Thanks for the help!
