Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Stock 2002 - 2005 Explorers
Notices
Stock 2002 - 2005 Explorers Questions related to non-modified 2002 - 2005 Explorers and Mountaineers. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. Sport Trac and Sport use the 1995-2001 forum.
fly weel screws wrench and torque question?
Reply
Thread Tools
Old 11-29-2012, 06:03 PM   #1
balston
ford explorer
Vehicle Specs
Quoted: 2 Post(s)
(Original Poster)
Hi guys i need to know which wrench type and size i need to remove the flyweel on my ford explorer 2003 4L xls...Also i need to know about how manyt torque does the bolts need.
balston is offline   Reply With Quote
( Join the Elite Explorers )
Old 11-30-2012, 01:25 AM   #2
Exproblems
Orchard Park, N.Y.
'05 Explorer XLT 4.0L
Vehicle Specs
Quoted: 85 Post(s)
Quote:
This is what the Haynes Manual says for the V-6 enigine on torque for the Flywheel/Driveplate. This is the way it is written in the Haynes manual:
Flywheel bolts:
Step 1: 120 inch lbs
Step 2: 52 ft lbs
Driveplate Bolts:
Step 1: 115 inch lbs
Step 2: 37 ft Lbs
Step 3: Tighten an additional 90 degrees
If you aren't sure about what you are doing down there, I would suggest you get a Haynes manual for your vehicle (around $25), because there appears to be a Flywheel bolt tightening sequence you need to follow and you need to make markings on the flywheel/driveplate and crankshaft, to ensure proper alignment during reinstallation. Can't help you on the wrench part of your question. Good luck! BTW, my Haynes Manual states it is for 2002-2010 Explorers or Mountaineers, the manual doesn't specify if it for "Explorer Sports" like yours and I do not know if the specs I gave you from it are the same for your vehicle. You might want to check into that before you do anything.
Exproblems is offline   Reply With Quote
Old 11-30-2012, 05:27 AM   #3
balston
ford explorer
Vehicle Specs
Quoted: 2 Post(s)
(Original Poster)
Thank you for your help i will check on a manual ...
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
Holiday Torque Wrench Special blmw Under the Hood 13 11-15-2012 10:47 AM
Torque Wrench Question... Glen4X4 Exploring every thing under the sun!! 10 12-27-2007 04:33 PM
Engineers: Torque Wrench Accuracy lonestar Exploring every thing under the sun!! 8 10-14-2003 07:52 AM
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
