Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Explorer & Ranger Transmissions, Transfer Cases, & Differentials
Notices
Explorer & Ranger Transmissions, Transfer Cases, & Differentials Transmissions, Transfer Cases. A4LD, 4R70W, 4R44E, 4R55E, 5R44E, 5R55E, M5OD, BW 1354, Control Trac, GEM, AWD. Ford 8.8", Dana 35
2000 Explorer 4.0 SOHC 4WD no reverse
Reply
Thread Tools
Old 12-18-2012, 03:56 PM   #1
VladTheHungarian
NEPA
2000 Explorer XLT4.0 SOHC
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I have a 2000 Ford Explorer XLT with a 4.0 L SOHC with 4WD, 5R44/55E trans, all my forward gears shift , (up shift and down shifts smoothly automatically and manually smoothly) but I have no reverse, it sounds like it tries to move, I can hear and feel it try but it will not back up. Put it in any forward gear and it move no problem.
Fluid is up to level, clean and has no burnt smell, this problem just happened, no warning, no slipping, it just stopped going in reverse, the shift lever moves smootly between gear, no cluncks, no whining, no grinding.
I'm at a loss, been a mechanic for 30 years worked on cars, bikes and boats so I'm no stranger to rebuilding engines and transmissions but this one kinda has me stumpped, any help or directions for trouble shooting would be appreciated.
Thanks in advance for your help, you folks have helped me before so I have faith that you'll be able to help me out again.
VladTheHungarian is offline   Reply With Quote
( Join the Elite Explorers )
Old 12-18-2012, 04:36 PM   #2
snoranger
Jackson, NJ
snoranger's Avatar
94 limited on 35's
Vehicle Specs
Quoted: 68 Post(s)
The most common failure point is the valve body gasket blown out around the reverse servo. Thats what happened to 2 of mine.
__________________
94 limited: 4.0l, 5spd swap, 6" skyjacker lift, 35x14.5 thornturds, 4.56s. 5.0 swap started (94 cobra 5.0, zf 5spd, np205)
95 xlt: stockish (SOHC swap, 30,000miles and I blew up the 3rd 4r55e...now collecting parts for a Cummins swap.)
Cummins 4BT swap thread
Ranger bed trailer build
snoranger is offline   Reply With Quote
Old 12-18-2012, 05:30 PM   #3
VladTheHungarian
NEPA
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Can I get to the valve body without droppin' the trans?
I gotta pull out my service manual look...
Old 12-18-2012, 07:07 PM   #4
snoranger
Jackson, NJ
snoranger's Avatar
94 limited on 35's
Vehicle Specs
Quoted: 68 Post(s)
Drop the pan.... Its staring you in the face.
Edit:
Read all the 5r55e stickies at the top of the trans section. Everything you need to know about the valve body is there.
__________________
Old 12-18-2012, 07:23 PM   #5
VladTheHungarian
NEPA
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Quote:
Edit:
Thanks snoranger, I see you're in Jackson, I grew up in Woodbridge and Oldbridge so I'm familiar with your neck of the woods, used to do a lotta 4wheelin' in the Pine Barrens backin the 80s.
1 last question, (I've been readin' the stickies for the last few hours) with a fully equiped garage with a lift, what kinda time frame am I lookin' at, (I'll have another mechanic I trust as much as myself workin' with me)?
Thanks again for the quick resonses.
Old 12-18-2012, 07:56 PM   #6
snoranger
Jackson, NJ
snoranger's Avatar
94 limited on 35's
Vehicle Specs
Quoted: 68 Post(s)
I grew up in Old Bridge.
It took me about 2-2.5 hours to pull the valve body, clean everything, replace the gasket and spacer with the upgraded, new filter, etc. (No lift, just really tall jackstands.)
__________________
Old 12-18-2012, 09:52 PM   #7
VladTheHungarian
NEPA
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I used to live by rt 34 by Cheesequake, Rural Auto body was across the st. and tommy's Angles was the Go Go bar next door, it was an old farm. now it's about 30 town homes.
BTW thanks for the info, I'll let ya know how I make out.
Old 12-18-2012, 10:53 PM   #8
snoranger
Jackson, NJ
snoranger's Avatar
94 limited on 35's
Vehicle Specs
Quoted: 68 Post(s)
I lived over by where rt18 and 516/527 meet.
__________________
Old 12-31-2015, 12:34 AM   #9
McMuddy
Vancouver, B.C.
2000 Explorer XLT
Vehicle Specs
Quoted: 1 Post(s)
So Guys....it's been three years since this post originated and I am curious if the VB Gasket fixed the problem? I have the same Explorer/spec's and problem seems to be the same and need to know what I'm up against here. Do I scrap it or rebuild or just put the effort into a gasket and hope it fixes my problem. I have a very limited time and $ budget to expend on this truck and need to weigh all options very carefully.
Your fix/solution to your problem might just be the answer for me as well so if you could reply, it would be greatly appreciated.
Thx
McMuddy
McMuddy is offline   Reply With Quote
Old 01-17-2016, 06:01 PM   #10
bluestream1
Waterloo Ontario
2000 XLT 4.0 SOHC 4X4
Vehicle Specs
Quoted: 77 Post(s)
I doubt it, most likely a broken reverse band. Why people dont have the courtesy to come back and explain the problem so others can learn is beyond me...
__________________
2000 Ford Explorer SOHC 4X4 310,000KM
2000 VW Beetle 1.8
1991 BMW 735iL
bluestream1 is offline   Reply With Quote
Old 01-19-2016, 04:34 PM   #11
McMuddy
Vancouver, B.C.
2000 Explorer XLT
Vehicle Specs
Quoted: 1 Post(s)
Thanks Bluestream....
I hear you, it would be nice but I guess once people have the problem fixed, going back is too much effort.
In any event, my truck issue is weird in that I have intermittent times when it will go into reverse and then nothing again for thirty or forty times trying and then once again and then nothing. Can't seem to figure out exactly how to make it go into reverse other than perhaps the slope I'm sitting on at the time, or the fact that the truck is cold perhaps or ????? Anyway, I'm surviving with just going forward in my life and never letting myself get into a situation where I have to reverse......it's just going to bite me in the ass one of these days.
Thanks for the input though....
McMuddy
Reply
Tags
automatic transmission removal, no reverse, shift issues
Similar Threads
Thread Thread Starter Forum Replies Last Post
HELP!!!! Explorer Sport 2wd 4.0 SOHC Manual iBangKaty Modified 1995-2001 Explorers 22 12-29-2014 11:35 PM
ford explorer 4.0 sohc ...no power, stalls and sputters ect. mkj Stock 1995 - 2001 Explorers 9 02-06-2014 12:42 PM
Wanted 2000 explorer 4.0 SOHC motor double_u_4 Parts and Vehicles Wanted 3 11-08-2012 09:01 AM
2000 Ford Explorer 4dr 4.0 - No Auto, No 4WD Sakojake Explorer & Ranger Transmissions, Transfer Cases, & Differentials 1 10-30-2012 12:29 PM
1998 Ford Explorer 4.0 SOHC - Engine Replacement. upnorth22172 Stock 1995 - 2001 Explorers 3 04-19-2010 10:05 AM
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
