#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Ford Explorer Sport Trac Forums > 2001-2005 Explorer Sport Trac
Notices
2001-2005 Explorer Sport Trac All questions related to the 2001-2005 Explorer Sport Trac model.
04 Sport Trac XLT, fog light switch but no lights
Reply
Thread Tools
Old 12-23-2012, 01:37 AM   #1
hlenoble
SF Bay Area
'04 Sport Trac XLT, 4WD
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I just bought an '04 Sport Trac XLT and expect to learn a lot from you experts. My truck has the fog light switch built into the headlight switch and it ill intakes when turned on. But, there are no fog lights in the truck, only the bezels. Could the lights have been removed? Any other reasons there would be a working switch with no lights? Finally, is the fog light wiring built in to the '04s? I have read yes and no.
Thanks,
Hal
hlenoble is offline   Reply With Quote
( Join the Elite Explorers )
Old 12-23-2012, 07:14 AM   #2
Alwayssideways
Newington, CT
2003 Sport Trac
Vehicle Specs
Quoted: 1 Post(s)
sounds to me that they were removed
__________________
2003 4wd XLT ST. Painted Cladding, TT and AAL, Sony headunit, clear corner lights, blacked out euro tails.
2000 Escort ZX2 S/R. Pretty modded.
Alwayssideways is offline   Reply With Quote
Old 12-23-2012, 08:12 AM   #3
MidnightRebel07
Pittsburgh, Pa.
MidnightRebel07's Avatar
2003 Explorer Sport Trac
Vehicle Specs
Quoted: 286 Post(s)
Someone could've started my mod of installing a Foglight switched dash bezel but never got around to installing foglights. When you say there's bezels, on the front bumper cover are there holes where the lights go or are they still covered? It also could've been punched in the nose (in frontend accident) and they replaced the bumper cover without replacing the lights or with with an XLS cover that was foglight delete. I'd look behind the cover to see if there are foglight brackets, wiring, etc... If you can post a picture of the front bumper cover and behind the cover if possible so we can get a better idea of what's going on.
__________________
"If you're gonna be a bear, Be A Grizzly"
Trucks name: "Battle Born".
UNDER CONSTRUCTION: Dana 44 SAS, 8.8 SOA, unsure of gears yet, 351w V8, C6 trans, 1356 manual transfercase, bobbed bed, partial exxo, 37x12.50x16.5 on recentered military H1 double beadlocks, underbelly skid pan, snorkel, more to come. Stay tuned.
MidnightRebel07 is offline   Reply With Quote
Old 12-24-2012, 02:33 AM   #4
hlenoble
SF Bay Area
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Here is a pic of the front of my ST, it is hard to see but there are holes in the bumper covers with black plastic covers on them
image by hlenoble, on Flickr
If you enlarge this pic you can see the switch, which illuminates when turned on (pulled out)
Old 12-24-2012, 09:33 AM   #5
roamer37
Lincoln Park Mi.
roamer37's Avatar
2003 Sport Trac
Vehicle Specs
Quoted: 5 Post(s)
Fog light switch on a Sport trac Gen 1 is in the center stack on the right side of the radio! Your head light switch must be out of a older explorer
roamer37 is offline   Reply With Quote
Old 12-24-2012, 09:46 AM   #6
ncranchero
Co-moderator
Denver,NC
ncranchero's Avatar
'94 F150 4x4 SWB 4.9L
Vehicle Specs
Quoted: 27 Post(s)
Quote:
Not on the 04-05's. They have the fog switch integrated into the headlamp switch.
Hal, your front bumper cover has been replaced, most likely from a minor frontal impact, and the lights probably omitted. It doesn't match the side cladding and rear bumper cover. The wiring you'll find probably still in place. You can just cut out the fog lamp holes and purchase/install a set of lamps and be good to go.
__________________
'14 Transit Connect 2.5L 16 Valve DOHC Duratec
'02 Escape XLT 3.0L 24 Valve DOHC Duratec 160k
'94 F150 4x4 4.9L/5-speed 160K miles,
How to post photos
ncranchero is offline   Reply With Quote
Old 12-24-2012, 01:22 PM   #7
hlenoble
SF Bay Area
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Thanks Steve. I just ordered a set of OEM fog lights for my truck. They should be here next week and I will get them installed and post another pic. I bought a bed extender and trailer hitch already, and aside from replacing the radio or adding an aux i put I should be set.
__________________
Hal
'04 Sport Trac currently
'03 Explorer XLT and '95 Explorer Sport previously
Old 12-24-2012, 03:00 PM   #8
ncranchero
Co-moderator
Denver,NC
ncranchero's Avatar
Vehicle Specs
Quoted: 27 Post(s)
I doubt the fog lights will come with the attaching bolts/clips. You may locate an Auveco dealer and grab some of these before your lights get here.
You DID look and make sure your lights weren't back there didn't you? Probably not or surely they would have just cut out the holes. A hole saw works great for that.
__________________
How to post photos
Old 12-25-2012, 02:21 AM   #9
hlenoble
SF Bay Area
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Good advice Steve. I did check, and there are no lights there, but the wiring is.
__________________
Hal
Old 01-05-2013, 02:18 AM   #10
hlenoble
SF Bay Area
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Steve, I bought the mounting hardware and the lights came this week. They are MUCH larger than the covered holes. Do you know what the diameter is for the correct size lights? Do you have any sources?
__________________
Hal
Old 01-05-2013, 06:38 AM   #11
ncranchero
Co-moderator
Denver,NC
ncranchero's Avatar
Vehicle Specs
Quoted: 27 Post(s)
This help?
__________________
How to post photos
Old 01-05-2013, 10:26 AM   #12
hlenoble
SF Bay Area
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Sure does, thanks.
__________________
Hal
Old 04-24-2013, 02:17 AM   #13
Dauntless76
Ames, Iowa
2001 Sport Trac 4x4
Vehicle Specs
Quoted: 21 Post(s)
Just got my fog lights today and am going to install them in the next couple days. Zero wiring but have a factory switch (after doing a bezel swap). Two questions for the forum gods: what is the best method/tool to cut out the fog light covers in the bumper since mine didnt ever have holes, and can I simply buy a fog light wiring kit from autozone or oriellys or something? I havent ever wired lights from scratch before and these have zero instructions. Oh and these fogs have the led halo rings in them, if that makes any difference to wiring them. Thanks.
__________________
“If a man does his best, what else is there?”
-Gen. George S. Patton
My Registry
Dauntless76 is offline   Reply With Quote
Old 04-24-2013, 01:27 PM   #14
Dauntless76
Ames, Iowa
2001 Sport Trac 4x4
Vehicle Specs
Quoted: 21 Post(s)
I wondered, looking at these fogs why the mounting structure looked SO different from what I know to be the mounting necessary in the bumper. So I took it out today to start the install process and guess what: Ford Explorer fogs not sport trac. Kinda peeved, looked at my order and it is indeed for 01-04 Sport Trac. They sent me the wrong ones. And it still took like 2 weeks to get them.
__________________
My Registry
Old 04-07-2014, 01:29 AM   #15
arturo.c
2005 Sport Trac XLT
Vehicle Specs
Quoted: 0 Post(s)
Thanks everybody for all the very valuable info in this thread about fog lights. I own an '05 Sport Trac XLT without fog lights and just bought a couple of them on eBay, but have no idea about the bolts, switch and wiring required for them.
Any suggestions on what to do next?
arturo.c is offline   Reply With Quote
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
04 sport trac xlt 2wd air lift cowboy3dc 2001-2005 Explorer Sport Trac 5 09-23-2012 10:57 AM
3rd Brake Light For 03 Sport Trac Xlt XVX_MARK_XVX 2001-2005 Explorer Sport Trac 1 05-01-2008 05:17 PM
E-Brake light on, and fog lights don't work toddious Stock 1995 - 2001 Explorers 8 04-12-2007 07:46 PM
Fog lights and Head light issues Tcole96 Stock 1995 - 2001 Explorers 0 01-06-2006 11:07 PM
Fog light switch mod 1996explorerxlt Modified 1995-2001 Explorers 5 01-04-2006 04:47 AM
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
